本帖最后由 lovelijizhi 于 2013-8-8 13:50 编辑 ; |: Q0 }, l8 [; `# o
: L: }" {1 k; W
张湘岳 发表于 2013-8-6 14:49 0 I V" P. a1 V5 q* h$ m
first,you should place a "snap point"in your board.
# V8 O# {& F2 _" ^& w: Rwhen you select the objects,you should right ... 8 Q* C- g( r& O0 Z
" K9 } O) R" n, S7 [, LI update the working method of using Edit>Circuit Move &Copy.
6 q: [8 F+ j, B8 Z- c0 k1 @ " o! M: E8 y, A/ Z
Step1:Edit>Circuit Move & Copy
: S" M' Z+ G3 F+ v1 o: R7 t/ L: Z/ E
9 h( R+ ?2 B2 O/ {Step2:In the popped Selection Filter Window, Mark Parts, Test points and Traces.
3 ^$ r5 q/ E6 ~+ i4 g
. d9 @. s! [% B8 }: z, @Step3:3.1Select the components and traces which I want to move., C" q/ c4 R( m& S& @5 h
: I5 m% x+ B& i) T; G1 A 3.2Click the right mouse button in the selected items,then select Set Origin from the popup menu that displays and set the origin as same location as the origin of the board.9 |/ H5 x# W |! f. d
$ c/ x2 }3 X+ L 3.3Set the Custom Grid 6mm.
" {: m2 C* Q% r( @0 G$ r2 b
* U3 B5 P# N- Z$ E2 U* E E8 }Step4:Move the selection, then I find I can move accurate 6mm. |
