感谢楼主分享,已更新到Hotfix_SPB16.60.061补丁
6 h4 m; D3 M& c但是有一个问题,出gerber的时候会弹出下面的这些警告,是不是可以忽略?( b% ?# D, y( r
Results from parameter file ...
0 }& b' _2 x0 j+ j: v5 h6 m DEVICE-TYPE GERBER_RS274X/ s7 ~# w1 T! F1 _6 u
OUTPUT-UNITS INCHES
|' N3 L9 s# j9 c6 l/ s s( v6 L FILM-SIZE 2400000 1600000
9 o8 z3 O8 R# N# f) |& { FORMAT 3.5
% z2 J1 `2 G3 \9 Q h ABORT-ON-ERROR NO
% S& }- l7 u. k* |+ ] SCALE 1# P: H0 X" ^7 n
SUPPRESS-LEAD-ZEROES YES
V' K+ o" s* P9 N' W1 v! X SUPPRESS-TRAIL-ZEROES NO
0 B$ [9 ]$ D3 p3 S* f SUPPRESS-EQUAL YES8 X) X' I5 X% ^( I. I3 g" E
UNDEF-APT-CONT NO' A, b V9 k7 x; @ I/ z
. ?$ E, u* S# I# x: v q- H6 B% p7 ^4 \; k6 T2 G+ C7 O
; w: Z; i( o: s================================================================
$ G1 p1 d% r: ^: D. W4 g# ] PROCESSING FILM < BOTTOM >: H6 r" K2 V2 Q( o" k
TO FILE < E:/GZ/QCA9533_A/test/BOTTOM.art > ...
4 Z0 u, O5 I: z5 P4 U3 `* A================================================================4 U1 ^, Q( x0 i2 Y
3 D# ]5 F( \" ?* i
FILM PARAMETERS :/ ^# Z; D4 ^) `2 g v
---------------------------------------------------------! v- H9 s+ g( ~$ Z# ^3 A9 E, U
Undefined line width 6.000
! ^7 z; w& e! K7 A Mirror code NONE
$ l2 P: [1 O0 v6 I: u Rotate angle NONE
+ z* ^; w0 [ h$ g( X$ ^. D/ [ Offset x: 0.0002 T/ _2 h) L$ D7 a7 N: U* _
Offset y: 0.000
% }# |* s+ t/ n4 D7 _ Plot negative NO* f5 R [3 H s" F. e/ G t
Suppress unconnected internal pads NO/ y4 n& X$ \3 t
Draw holes only NO- F9 z0 t! X3 ^0 H
0 |9 K% p2 g @
WARNING: Film contains objects with associated DRCs (2). |6 `- e8 u+ K; M8 `
In the design editor view this film and enable visibility for the
5 |1 {! b2 O0 [! E @ associated DRC layer. Verify the DRCs are approved exceptions to your rules.& ~' l3 R; p4 j* c, W/ G- n
WARNING: Segment with same start and end points at& E+ w3 B5 c( D; `! ^ h' a" n
(1145.787 1178.850) will be ignored. Increasing output
! u5 _# _/ z' F! g& F- i4 I accuracy may allow segment to be generated." ^+ o. m9 U9 x W8 F
1 k. G0 K3 }8 T& q' n6 w
! U! S. F- S$ `' q (930.854 1681.550) will be ignored. Increasing output/ w% f$ H5 Q* E |/ |1 P) t
accuracy may allow segment to be generated.0 r1 \% A" s. G0 D! q3 x( Q
) v+ h6 t* T- ?4 e, @# R WARNING: Segment with same start and end points at
& a i% |: M; W (906.850 1681.548) will be ignored. Increasing output8 a/ ]& `; D3 R5 y! Q6 j" a
- I3 j5 Y) W* i4 E& m3 P
8 l7 t6 d/ S4 I. h$ q q' m; @' U% P WARNING: Segment with same start and end points at' J6 }$ P% t* y/ S; \
(904.250 1734.998) will be ignored. Increasing output
3 S1 k5 _, M" k" m' p+ c accuracy may allow segment to be generated.# L' u$ Q( S g+ l3 S$ G6 {) W- L
/ Z, L! W( p; }2 ]: d: a WARNING: Segment with same start and end points at; h; r( B2 @; Y: A9 I
(904.249 1753.002) will be ignored. Increasing output: F( ]$ e }* r. C6 f
accuracy may allow segment to be generated.$ L2 h( ~' Q& g
! y! J, I8 P8 z; W7 x: b
9 w K8 Y* N, G% f; _! m0 l (906.249 1756.999) will be ignored. Increasing output. X. a* W: P! D- w+ c6 F3 D1 I
accuracy may allow segment to be generated./ m8 U4 H/ U3 J4 ~1 t* X5 ^. \
4 N, k3 a0 _1 V0 `9 J a% h WARNING: Segment with same start and end points at
! I- I7 w/ ?- m% F" t2 A" T (643.977 2018.839) will be ignored. Increasing output
1 \7 k8 |/ ~7 r+ F$ Y accuracy may allow segment to be generated.1 S; ^8 k- g' A2 p! c. |3 i
/ F& W$ y: m6 Y6 V) A( k: _$ n WARNING: Segment with same start and end points at/ |: W6 B8 G* g. Q
(906.350 1603.596) will be ignored. Increasing output
+ [! J0 K6 \, Z; K accuracy may allow segment to be generated.7 r2 E1 L4 h6 S* i6 F) l
3 k: V6 y1 W% C" F1 { WARNING: Segment with same start and end points at
/ S1 _/ D, c2 J( I2 P( x (906.348 1621.600) will be ignored. Increasing output
( ~1 c/ c9 x2 J O# o' Y accuracy may allow segment to be generated.. o# f! X7 ?+ w8 |: q" o
6 ~; l }1 @* w( ~7 @' Z; R
/ f. q! G8 X0 n2 O" @ (908.348 1625.598) will be ignored. Increasing output# O* x" r. E" t+ [. n
accuracy may allow segment to be generated.& c3 h9 S& T S: r
# ~0 D6 O$ N- k. m1 ]) k WARNING: Segment with same start and end points at% b* T* K6 `! G" V" R8 ~& c
(1999.226 1858.100) will be ignored. Increasing output
. e2 N' ?6 f( R5 ^- w& S7 f3 E accuracy may allow segment to be generated.
8 s6 ?. V5 O9 T+ n
0 W% M k: d% `9 x WARNING: Segment with same start and end points at
" @4 Y! ?/ b4 A5 N5 J9 r (2087.252 336.877) will be ignored. Increasing output
7 U. |. i$ |0 K6 t6 @3 | accuracy may allow segment to be generated.- v# I% ~% o( @3 b% K
7 L" N- o% d" H WARNING: Segment with same start and end points at0 r( N0 N! a' i. I8 H4 h2 s5 ^
(1131.493 1780.848) will be ignored. Increasing output+ S: E" q, V& R( j1 y
/ X( N% }+ G; X+ l9 \
& s, K! _; v, a& ]4 I$ N( E WARNING: Segment with same start and end points at
1 ]5 \0 c9 v$ N" S (1255.300 1838.972) will be ignored. Increasing output6 g" z8 S6 l$ E3 E: _4 ]
) V2 v7 z+ M$ a+ n8 f: [' Z. l$ k; D) S" V9 V3 b
WARNING: Segment with same start and end points at4 a/ y7 Y. a; G3 j: p
(1255.298 1820.968) will be ignored. Increasing output
2 o1 A) [& O; n9 k: L accuracy may allow segment to be generated.8 C6 l! U$ R. j2 Q% t+ Y
2 q' e8 X l8 O1 m- f; f, { WARNING: Segment with same start and end points at2 ]/ E6 N. f+ \, `! |/ A% M& l
(907.533 2124.928) will be ignored. Increasing output. K$ L" D0 f6 D+ x* V% a
8 Y) P" @* `) y/ b: m9 c
5 X/ }# ?$ }. B. H WARNING: Segment with same start and end points at# o- v+ i# e8 O' r* M8 w7 e
(1513.752 1894.698) will be ignored. Increasing output$ W |9 x! ?) Q- [: N# X2 g9 _$ p
8 Q6 x5 `+ X- U1 ^) P* R* Y2 D; ^! l6 s! n8 z6 l
WARNING: Segment with same start and end points at" O" K( H# S! y8 a2 t
(1829.400 2154.145) will be ignored. Increasing output
8 W. s/ A) V; U- O accuracy may allow segment to be generated.
2 n3 T8 n" A/ d. A) I
( L+ C4 ~- `7 ] WARNING: Segment with same start and end points at, o( ], d/ [1 A! p) ] j5 V
(1206.807 2318.552) will be ignored. Increasing output
) y; Q/ y g5 C, T9 |$ S accuracy may allow segment to be generated.
- ~8 R# N. d2 E# E# e
! \' B2 b- S2 Z( Q1 S# B# m ` WARNING: Segment with same start and end points at% T \5 C3 Z- a
(291.738 2175.767) will be ignored. Increasing output
+ r, Z, z7 b8 C( l- ] T5 B accuracy may allow segment to be generated.
3 O f: d! @! j& s |
