TA的每日心情 | 郁闷 2019-12-19 15:30 |
签到天数: 1 天 [LV.1]初来乍到
' ]) T5 h' b/ a) b' z还没有,出差了一周,事情搁在那,现在又重新捡起来检查,按官方的电路也试过,但是没有好转。9 `0 k% c; S# J B @8 ~1 Z& ]
问题出现时系统打印如下:" ~- S% O& Q5 T5 O. F, X$ a/ Y
atmel_nand atmel_nand: No DMA support for NAND access.
5 K# R2 Y. W1 H- a. k" S" s9 mNAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
+ {- M' [' I/ a! I; w% o+ Q! LScanning device for bad blocks
5 V, Z" ]) X% c7 ?; VBad eraseblock 2709 at 0x0000152a00008 ?; w( G! W1 f7 M7 Y! J9 t* g; {( L4 `
Bad eraseblock 7103 at 0x0000377e0000
/ v* {1 ?8 M. X+ n3 V& _Creating 3 MTD partitions on "atmel_nand":. t9 U, S4 v4 s8 \# d B; @1 y
0x000000000000-0x000004000000 : "system0"9 Z* K, |( j0 ` X, q3 P' A: e3 e% ]
0x000004000000-0x000008000000 : "system1"
5 [( U2 h6 C: D; C7 z5 q7 V# ?, I* {2 _0x000008000000-0x000040000000 : "data"% h# t$ g" K3 C+ { G+ J
atmel_spi atmel_spi.1: Atmel SPI Controller at 0xfffcc000 (irq 13)
: s h, l+ e! q& v% @8 Lmacb macb: invalid hw address, using random
3 m" t9 L1 u5 w5 C. ]" k9 Z, e4 rMACB_mii_bus: probed/ j( {0 p; E) r; {
eth0: Atmel MACB at 0xfffc4000 irq 21 (a6:ac:7f:b8:05:7a)' [ [3 _, w: X! W5 s, @
eth0: attached PHY driver [Davicom DM9161A] (mii_bus:phy_addr=ffffffff:1f, irq=-1)
( Z7 a n5 N' L* h) vPPP generic driver version 2.4.2, I, L1 |* H! K4 F$ ~/ B" G
PPP BSD Compression module registered
9 l+ n0 B2 c1 Q1 i' FPPP Deflate Compression module registered! y I3 s6 W X* l" D6 N
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver% N; t2 b" m* ^, l6 `
at91_ohci at91_ohci: AT91 OHCI
+ @9 p% L4 L5 \# C. Eat91_ohci at91_ohci: new USB bus registered, assigned bus number 1$ e3 x) }: z T) z0 b n+ N
at91_ohci at91_ohci: irq 20, io mem 0x00500000
. q l. S4 z! Z/ B; bhub 1-0:1.0: USB hub found
1 m& t* {2 f( Y7 jhub 1-0:1.0: 2 ports detected/ `; b( f$ X8 P
如果是正常仪器启动,加色那段信息为:8 u5 ]1 P# p) W9 H% z
eth0: Atmel MACB at 0xfffc4000 irq 21 (a6:ac:7f:b8:05:7a) ' {/ D& V* h1 P% {- L7 t1 I5 T
eth0: attached PHY driver [Davicom DM9161A] (mii_bus:phy_addr=ffffffff:00, irq=-1)
( Y2 z- K- @2 o5 c但是不知道这个代表这什么意思。! m- C) s0 \' n3 B& z0 `( V
