查看: 2052|回复: 3
求axlTriggerSet用法
发表于 2014-7-16 13:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用 axlUIMenuFind()axlUIMenuInsert() 命令写了自动添加菜单的 il 文档
虽在加载ilinit文件时运行成功,但之后又被加载allegro.men,菜单给还原了。无法实现自动添加菜单
我想知道axlTriggerSet用法,越祥越好。
下面是我找到的资料
添加菜单的几种方式:
MENU CUSTOMIZATION METHODS
Provide your own customization menu via CDS_SITE. Replace the cadence provided menu (.men file) with your own.
Advantages: Relatively easy and no skill programming required.
Disadvantages: For new releases need to merge your menu changes with new Cadence menus. May need to modify multiple menus
Overload your menu customizations on Cadence menus via Skill axlUIMenuRegister.
Advantages: Relatively easy with minimal Skill programming. Depending on your site's additions may be immune to many Cadence menu changes.
Disadvantages: Cannot delete Cadence menu items or restrict your changes to a one Cadence menu.
Register a axl menu Trigger notification via axlTriggerSet.
Advantages: Almost as much flexibility as overriding the default menu file including targeting specific menus.
Disadvantages: Need to examine your Skill code with new Cadence releases. Requires much more Skill programming knowledge.
Description
This allows you to register menu items to be loaded when Allegro loads a new menu. It is a combination of axlUIMenuFind and axlUIMenuInsert.
If more elaborate menu configuration is required consider calling axlTriggerSet directly.
我想知道axlTriggerSet用法,越祥越好。最好能帮我解决在allegro启动时,就自动添加菜单的方法,
发表于 2014-7-16 16:03 | 只看该作者
 楼主| 发表于 2014-7-17 13:54 | 只看该作者
   (axlTriggerSet ‘menu ‘loadMyMenu)
调试通过,就是不知怎么调用,没有看到菜单
Function loadMyMenu already registered for 'menu trigger
 楼主| 发表于 2014-7-17 14:33 | 只看该作者
调试通过了,谢谢betamelody,您是我的老师
GMT+8, 2025-8-12 11:18 , Processed in 0.109375 second(s), 23 queries , Gzip On.
