查看: 6611|回复: 8
新手请教
发表于 2008-8-29 14:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#1 Error [ALG0031] Pin number missing from Pin "1" of Package CAP NP , C2: SCHEMATIC1, PAGE1 (3.20, 2.20). All pins should be numbered.
# p" [. f$ p- y  C+ Y" C#2 Error [ALG0031] Pin number missing from Pin "2" of Package CAP NP , C2: SCHEMATIC1, PAGE1 (3.20, 2.20). All pins should be numbered. 0 @) V4 j! `: r
#3 Error [ALG0031] Pin number missing from Pin "1" of Package SW PUSHBUTTON , S1: SCHEMATIC1, PAGE1 (1.90, 2.10). All pins should be numbered.
+ x% P" p* \$ i* w1 m, Z#4 Error [ALG0031] Pin number missing from Pin "2" of Package SW PUSHBUTTON , S1: SCHEMATIC1, PAGE1 (1.90, 2.10). All pins should be numbered. * A3 H" J; d; r& W+ p) Z1 w
#5 Error [ALG0031] Pin number missing from Pin "1" of Package CAP NP , C3: SCHEMATIC1, PAGE1 (3.20, 2.60). All pins should be numbered.
- Z! C  K; p, W. t4 {  @# Y9 H; e, t5 j& z% u#6 Error [ALG0031] Pin number missing from Pin "2" of Package CAP NP , C3: SCHEMATIC1, PAGE1 (3.20, 2.60). All pins should be numbered.   H  [; v" \! x
#7 Error [ALG0031] Pin number missing from Pin "1" of Package R , R1: SCHEMATIC1, PAGE1 (2.50, 3.50). All pins should be numbered. 3 Y7 [& u* N! f! i! v
#8 Error [ALG0031] Pin number missing fr om Pin "2" of Package R , R1: SCHEMATIC1, PAGE1 (2.50, 3.50). All pins should be numbered.
: ^* e$ N( I2 A+ }#9 Error [ALG0031] Pin number missing from Pin "1" of Package 4 HEADER , JP1: SCHEMATIC1, PAGE1 (3.60, 3.10). All pins should be numbered.
' h, R" ?7 o) C- O4 {#10 Error [ALG0031] Pin number missing from Pin "2" of Package 4 HEADER , JP1: SCHEMATIC1, PAGE1 (3.60, 3.10). All pins should be numbered. 3 }+ Q; \$ Z/ @) J0 C
#11 Error [ALG0031] Pin number missing from Pin "3" of Package 4 HEADER , JP1: SCHEMATIC1, PAGE1 (3.60, 3.10). All pins should be numbered. - s# O+ j: v2 b, ?+ T. r; f% `
#12 Error [ALG0031] Pin number missing from Pin "4" of Package 4 HEADER , JP1: SCHEMATIC1, PAGE1 (3.60, 3.10). All pins should be numbered. # T; X  ]" F5 T+ n. l% B
#13 Error [ALG0031] Pin number missing from Pin "1" of Package 8 HEADER , JP2: SCHEMATIC1, PAGE1 (3.60, 3.60). All pins should be numbered.
0 z% k2 ?$ V& T" G. ]#14 Error [ALG0031] Pin number missing from Pin "2" of Package 8 HEADER , JP2: SCHEMATIC1, PAGE1 (3.60, 3.60). All pins should be numbered. 8 S0 h& f4 o: o. |5 T' t
#15 Error [ALG0031] Pin number missing from Pin "3" of Package 8 HEADER , JP2: SCHEMATIC1, PAGE1 (3.60, 3.60). All pins should be numbered. , F* c' W7 C$ m" z) B$ g
#16 Error [ALG0031] Pin number missing from Pin "4" of Package 8 HEADER , JP2: SCHEMATIC1, PAGE1 (3.60, 3.60). All pins should be numbered. 9 ]1 \8 H; o4 o
#17 Error [ALG0031] Pin number missing from Pin "5" of Package 8 HEADER , JP2: SCHEMATIC1, PAGE1 (3.60, 3.60). All pins should be numbered.
1 V  |9 u# I" |( `7 T- v#18 Error [ALG0031] Pin number missing from Pin "6" of Package 8 HEADER , JP2: SCHEMATIC1, PAGE1 (3.60, 3.60). All pins should be numbered. 8 |6 x& `/ y; u8 E3 a% _
#19 Error [ALG0031] Pin number missing from Pin "7" of Package 8 HEADER , JP2: SCHEMATIC1, PAGE1 (3.60, 3.60). All pins should be numbered.
# h1 r  A4 s) d6 P0 p$ V- c9 ?#20 Error [ALG0031] Pin number missing from Pin "8" of Package 8 HEADER , JP2: SCHEMATIC1, PAGE1 (3.60, 3.60). All pins should be numbered. 4 x0 K; N" P8 g. I% K" q; W$ Y
#21 Error [ALG0031] Pin number missing from Pin "1" of Package CRYSTAL , Y1: SCHEMATIC1, PAGE1 (3.70, 2.40). All pins should be numbered.
/ [) `* H! s. J#22 Error [ALG0031] Pin number missing from Pin "2" of Package CRYSTAL , Y1: SCHEMATIC1, PAGE1 (3. 70, 2.40). All pins should be numbered.
  L& ^0 p6 x5 d#23 Error [ALG0031] Pin number missing from Pin "1" of Package CAP_0 , C1: SCHEMATIC1, PAGE1 (2.50, 2.10). All pins should be numbered. . g+ D2 q! V8 i9 D! F8 e
#24 Error [ALG0031] Pin number missing from Pin "2" of Package CAP_0 , C1: SCHEMATIC1, PAGE1 (2.50, 2.10). All pins should be numbered. , I; h) r* Z" G( {8 q3 \3 E, c
#25 Aborting Netlisting... Please correct the above errors and retry. % s4 k  V5 n0 j' x9 q; y" D
生成网络表示产生如上错误,该如何更正???
发表于 2008-8-29 14:54 | 只看该作者
引脚没有命名。
 楼主| 发表于 2008-8-29 14:59 | 只看该作者
回复 2# 的帖子
怎么修改啊 能不能详细介绍一下?
发表于 2008-8-29 16:57 | 只看该作者
Number的框框没有任何数字,这是Allgro不允许的,通常会发生这样的问题会在原本的线路图是9.X的版本,然后我们用10.X或更高的版本开启的时候所产生的
 楼主| 发表于 2008-8-29 17:20 | 只看该作者
回复 4# 的帖子
这个改过来了 可是又产生错误了如下
' Q8 t1 l( P- l6 r5 B1 Q( u********************************************************************************0 n  ~6 a$ K  q0 ?2 ]. I
' |$ E0 Q: ?  v* Netlisting the design ; L4 K3 \! F+ ]) l" |% n
*  d1 w; R6 D* m0 I# W6 a; O0 J
********************************************************************************8 G2 U+ [0 R! i& P. \+ R1 F
Design Name:
# Z& e- L" Q: cC:\wenjian1\yanli2.dsn
8 r) }4 t" P! |: d0 [- fNetlist Directory:
2 B) J. i3 T- M/ N+ z8 |C:\wenjian1\allegro- l$ Z6 l; S' Z" P
Configuration File:
+ a2 Q$ n6 u; K/ S; q# @3 }C:\Cadence\SPB_15.2\tools\capture\allegro.cfg
0 A. Y7 ]! m- _+ I
% M0 z% v9 \  V5 {1 F- Q8 l8 KSpawning... "C:\Cadence\SPB_15.2\tools\capture\pstswp.exe" -pst -d "C:\wenjian1\yanli2.dsn" -n "C:\wenjian1\allegro" -c "C:\Cadence\SPB_15.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
6 F* [4 a' ~- O, D#1 Warning [ALG0016] Part Name "CAP_0_CPCYL1/D.300/LS.200/.034_10UF" is renamed to "CAP_0_CPCYL1/D.300/LS.200/.034_".% f, }8 J9 J+ H# g3 H( T* h
#2 Warning [ALG0016] Part Name "CAP NP_0_RAD/.200X.100/LS.100/.031_30P" is renamed to "CAP NP_0_RAD/.200X.100/LS.100/.".
5 _5 U( Z7 [% d  F3 Q) k$ R3 \4 Z#3 Warning [ALG0016] Part Name "CAP NP_1_RAD/.200X.100/LS.100/.031_30P" is renamed to "CAP NP_1_RAD/.200X.100/LS.100/."./ c% F; ^2 d& X! X; i/ E1 n% I! p! V0 i
#4 Warning [ALG0016] Part Name "4 HEADER_0_SIP/TM/L.400/4_4 HEADER" is renamed to "4 HEADER_0_SIP/TM/L.400/4_4 HEA".
% t- S2 _1 X' c! l' v( u4 W/ x3 w#5 Warning [ALG0016] Part Name "8 HEADER_0_SIP/TM/L.800/8_8 HEADER" is renamed to "8 HEADER_0_SIP/TM/L.800/8_8 HEA".
3 Z8 G% ?6 L6 }: b#6 Warning [ALG0016] Part Name "SW PUSHBUTTON_0_RAD/.400X.200/LS.300/.034_RESET" is renamed to "SW PUSHBUTTON_0_RAD/.400X.200/L".
, o0 M) m$ h' J4 I, f' b- i#7 Warning [ALG0016] Part Name "8051_DIP.100/40/W.600/L2.050_8051" is renamed to "8051_DIP.100/40/W.600/L2.050_80".1 e& r) k7 y& p+ o7 ~
#8 Warning [ALG0016] Part Name "74LS373_DIP.100/20/W.300/L1.075_74LS373" is renamed to "74LS373_DIP.100/20/W.300/L1.075".
9 H* E) p6 H& |# q- \$ O#9 Warning [ALG0016] Part Name "27512_DIP.100/28/W.6001 F8 ?5 i. W+ g8 p1 T
/L1.400_27512" is renamed to "27512_DIP.100/28/W.600/L1.400_2".: x& F  \3 x8 {- E* k& @
#10 Warning [ALG0016] Part Name "CRYSTAL_0_RAD/.400X.150/LS.300/.034_12M" is renamed to "CRYSTAL_0_RAD/.400X.150/LS.300/".( }/ S) C" s- S* ^8 d; i( q
Scanning netlist files ...
5 A$ i/ g; z, _% ]Loading... C:\wenjian1\allegro/pstchip.dat! E* q- ]) W* F7 |9 {- r: m
/ [' {& g) q! Q$ ]# k3 w3 mLoading... C:\wenjian1\allegro/pstxprt.dat
8 U6 B4 ~5 f  ?8 h5 F; ?% @- PLoading... C:\wenjian1\allegro/pstxnet.dat2 y1 n6 g3 ?2 k$ P& ]
packaging the design view...
2 B8 c7 b" N# y- D/ g4 r, e1 g" C1 G# A
Exiting... "C:\Cadence\SPB_15.2\tools\capture\pstswp.exe" -pst -d "C:\wenjian1\yanli2.dsn" -n "C:\wenjian1\allegro" -c "C:\Cadence\SPB_15.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
" p- d; B- t) i' t) x2 ^) {* \( l, B
) g8 \0 w5 [5 p8 V0 i5 E) x6 e# u
*** Done ***# `3 j: r0 s4 i% t* H  ?; S
: w; Z" ^: X! k# j- F' P
********************************************************************************- ]; s' q6 N* V& Q( K9 U
*& ^8 S/ b# G& z! y6 |% g; y0 L
* Updating Allegro Board % z2 d# S" X6 V0 U% p$ ], C
5 [# k- l8 a( Q. H  {********************************************************************************
& L  j& J9 e, p$ M$ i+ |% F8 R# sNetlist Directory:6 g. J1 i0 B) A+ U% h% }; Q
C:\wenjian1\allegro2 Q7 i0 G4 y8 D/ H+ F" w+ l
Input Allegro Board:
9 N# U5 k4 y/ w* I1 v) T& AC:\wenjian1\allegro\yanli2.brd
+ N* }) \* X' ]Output Allegro Board:
6 G; ^& {4 `2 vC:\wenjian1\allegro\yanli2.brd
" ]* y3 p3 ^: x; ^' i: O4 z" G7 j5 o& M3 ^3 b  j
Spawning... netrev.exe -5 -y 1 -n -i "C:\wenjian1\allegro" "C:\wenjian1\allegro\yanli2.brd" "C:\wenjian1\allegro\yanli2.brd"
" c5 [( |: e* ZReading File : C:/wenjian1/allegro/pstchip.dat              ' K6 u# @5 X' r$ `7 y1 Y5 m% C
(00:00:00.00)  G; \; u8 g8 X! h. C
Reading File : C:/wenjian1/allegro/pstxprt.dat
! R0 y4 R' _6 I: w! J& ?# A  g(00:00:00.00)
* @% }; l3 [7 h$ jReading File : C:/wenjian1/allegro/pstxnet.dat              0 G" h+ z' K+ ^
(00:00:00.00); w4 q* C# c! l
Starting to process component instances
6 o, ?2 r, N2 m* [' L; }/ o* J; `9 C8 i2 H' o+ b3 ~. M
netrev run on Aug 29 17:10:17 2008
' e0 p: E) T! J9 J0 ?2 i   DESIGN NAME : 'YANLI2'
& u# Q8 q( E3 x. C) Z   PACKAGING ON Apr  6 2004 19:58:38
4 `# N" F8 p2 T7 m0 t% G0 o8 Z
% ]1 P1 I0 Z+ [! X, z9 h& k* K! ^, l
% m5 f7 X  @6 j- q2 R 12 errors detected& G% G  B; C  B4 S! q
No oversight detected5 H# P. I7 o6 G" a# v
No warning detected
! ~% n( `: ^- V& d! B3 e
5 q0 |% n# t4 l: i" }  _cpu time      0:00:12+ c2 C- R: Z+ X4 t
elapsed time  0:00:00( O3 F' {9 N1 s* w# a. X% a
' ?* I+ x1 y; ]3 z) E. M- R- S
# g+ E. E! C: H: E, L
Exiting... netrev.exe -5 -y 1 -n -i "C:\wenjian1\allegro" "C:\wenjian1\allegro\yanli2.brd" "C:\wenjian1\allegro\yanli2.brd"3 p" F' D/ n, b* q! `, U% s
Cadence Design Systems, Inc. netrev 15.2 Fri Aug 29 17:10:17 20088 p- y$ H4 J) K2 K% r! t
(C) Copyright 2002 Cadence Design Systems, Inc.
' v) t7 W$ ^- \
1 [' ~; w8 J2 Y! E/ b' ?. J4 n: H% I------ Directives ------7 J* w* t9 C% F' X+ [) K
$ G1 b* D7 |- i5 `; |. s
RIPUP_ETCH FALSE;2 ~4 o: |2 l+ w4 E- X
RIPUP_SYMBOLS ALWAYS;
/ H$ F1 `/ _& k" H+ @MISSING SYMBOL AS ERROR FALSE;
; S6 ~$ p& o6 X& {  `SCHEMATIC_DIRECTORY 'C:\wenjian1\allegro';
* u* y! {+ c, z3 P! K1 UBOARD_DIRECTORY '';$ a) j0 S4 ^7 u7 n5 I0 B0 l: v: ~
OLD_BOARD_NAME 'yanli2.brd';
8 {5 \! \4 G9 h" B6 P8 \( hNEW_BOARD_NAME 'yanli2.brd';: o: ^. v7 p% A6 h$ ?. _5 ?  r
( e* t. |% [- M* D+ @. XCmdLine: netrev.exe -5 -y 1 -n -i C:\wenjian1\allegro C:\wenjian1\allegro\yanli2.brd C:\wenjian1\allegro\yanli2.brd
: W/ p7 H) F. H# H/ e0 K7 b9 E7 S( {! e4 n* t* `
------ Preparing to read pst files ------' E. B3 R* X+ _$ i6 J
0 p0 {8 b6 @! y; Y' S( h9 E! k( r
Starting to read C:/wenjian1/allegro/pstchip.dat
0 n# O4 \' Y1 a' \0 M" z4 i   Finished reading C:/wenjian1/allegro/pstchip.dat (00:00:00.00)3 S7 C8 T# {& U' i2 D+ J
Starting to read C:/wenjian1/allegro/pstxprt.dat
4 k/ `4 O, o- S( \   Finished reading C:/wenjian1/allegro/pstxprt.dat (00:00:00.00)" F' ?% j4 v0 O- e
Starting to read C:/wenjian1/allegro/pstxnet.dat % A4 H0 ]0 v  H. E
   Finished reading C:/wenjian1/allegro/pstxnet.dat (00:00:00.00)
5 m. t/ ?( d# N- L9 q* Y* q* L$ C0 W
------ Oversights/Warnings/Errors ------- l% h* \7 X. ]( w$ X+ _! [5 Y$ `
5 e8 q$ H( h# t5 {& \
+ t  Q9 N2 V' S7 V; V7 ^& p5 S9 k#1   ERROR(302) Device library error detected.* H9 t. y% `2 }9 n/ z0 q: @
- K( G* U& w+ r2 u0 R
Problems with device 'CRYSTAL_0_RAD/.400X.150/LS.300/'. JEDEC_TYPE property 'RAD/.400X.150/LS.300/.034' is illegal: 'Package name is not legal.'.
" B7 J7 M4 S0 l' S# k
" W) W. i' m( {Device 'CRYSTAL_0_RAD/.400X.150/LS.300/' has library errors. Unable to transfer to Allegro.; e/ N( p- N. |: z
6 f9 N( a5 V) W) a  ?% _2 A
#2   ERROR(302) Device library error detected.' L( s3 E- ?; Y# ], M7 n) J
" U# D6 n' T, w7 Z( C
Problems with device '27512_DIP.100/28/W.600/L1.400_2'. JEDEC_TYPE property 'DIP.100/28/W.600/L1.400' is illegal: 'Package name is not legal.'.
9 u$ M- D1 K4 S& X/ t0 j
+ I7 c0 Y% I" C" I2 v5 A4 p( H2 m& jDevice '27512_DIP.100/28/W.600/L1.400_2' has library errors. Unable to transfer to Allegro.: ]( Q2 e0 a& v( g
, S9 D2 l# x( J3 y  A
#3   ERROR(302) Device library error detected.8 S3 y% y7 Z3 e  H. {
& J5 ?9 @2 B7 D) k& dProblems with device '74LS373_DIP.100/20/W.300/L1.075'. JEDEC_TYPE property 'DIP.100/20/W.300/L1.075' is illegal: 'Package name is not legal.'.: O% X9 j8 I3 b2 w3 H! v
! v' R; |+ X9 _
Device '74LS373_DIP.100/20/W.300/L1.075' has library errors. Unable to transfer to Allegro.9 E8 D  b- s+ p7 k1 b1 q
6 \. p8 z" V$ {7 @1 m- t$ c* @/ |#4   ERROR(302) Device library error detected.
! c4 f( s9 L* ?  I% R$ W: f5 {; ]' |8 A; g, U
Problems with device '8051_DIP.100/40/W.600/L2.050_80'. JEDEC_TYPE property 'DIP.100/40/W.600/L2.050' is illegal: 'Package name is not legal.'.- p( j1 S- r" C# @* f  t( o
! D2 x: A3 i8 F' \Device '8051_DIP.100/40/W.600/L2.050_80' has library errors. Unable to transfer to Allegro.
# `& G2 S# p% y0 U% d" F/ W4 E
1 Q/ ~" y1 t( P$ P4 v+ K3 l4 C* j. D#5   ERROR(302) Device library error detected.
9 U9 n1 w& Y5 x
/ T' }4 H7 \! A9 J; ZProblems with device 'SW PUSHBUTTON_0_RAD/.400X.200/L'. JEDEC_TYPE property 'RAD/.400x.200/LS.300/.034' is illegal: 'Package name is not legal.'.0 u/ S: |. a) j9 M. p4 E$ t7 H1 V
3 u5 }, M% K6 p9 S' T7 MDevice 'SW PUSHBUTTON_0_RAD/.400X.200/L' has library errors. Unable to transfer to Allegro.( t  F8 X" r. C! \. ?) R' s, H. Z
' |  u7 F( q: V; H$ B  H
#6   ERROR(302) Device library error detected.
! U* u1 v1 n. A
/ P0 A8 W" h( X* e- PProblems with device 'R_0_AX/.400X.100/.034_10K'. JEDEC_TYPE property 'AX/.400X.100/.034' is illegal: 'Package name is not legal.'.% @& e$ E$ m0 n. E9 D+ }
* o$ G3 h. z/ d0 ^- f0 F! s1 K
Device 'R_0_AX/.400X.100/.034_10K' has library errors. Unable to transfer to Allegro.  o" n: R0 j) \
6 p. _0 X, u4 |* C6 h3 G7 S. n! u
#7   ERROR(302) Device library error detected.4 _1 H; s- b' t. p, r, |6 D# L
, E2 }: o( u0 q0 t$ [0 ~6 H+ a0 VProblems with device '8 HEADER_0_SIP/TM/L.800/8_8 HEA'. JEDEC_TYPE property 'SIP/TM/L.800/8' is illegal: 'Package name is not legal.'.& B! o' r5 k6 f/ I5 J! J4 S0 ^
( |, Q) m3 U- \/ g
Device '8 HEADER_0_SIP/TM/L.800/8_8 HEA' has library errors. Unable to transfer to Allegro.
9 [7 d4 q# t0 r, \7 {: V: S& B( g7 N! o, R* K9 G$ z$ V
#8   ERROR(302) Device library error detected.' l1 ?( m& J6 v- D
$ j, y* T7 ?: ]0 X3 I/ e3 fProblems with device '4 HEADER_0_SIP/TM/L.400/4_4 HEA'. JEDEC_TYPE property 'SIP/TM/L.400/4' is illegal: 'Package name is not legal.'.$ Z. Z* v1 J9 V4 I; {
6 _4 i7 h8 r* M' Z8 E7 p& Z
Device '4 HEADER_0_SIP/TM/L.400/4_4 HEA' has library errors. Unable to transfer to Allegro.% d( l+ ~. {% V" x
8 G" P+ k7 A0 H#9   ERROR(302) Device library error detected.  @3 w$ f# |7 v
2 t+ n0 u, g$ Q  K8 O9 r+ MProblems with device 'CAP NP_1_RAD/.200X.100/LS.100/.'. JEDEC_TYPE property 'RAD/.200X.100/LS.100/.031' is illegal: 'Package name is not legal.'.4 u$ D0 J. l1 n4 Q
* ?" u  f$ k8 d# B$ y
Device 'CAP NP_1_RAD/.200X.100/LS.100/.' has library errors. Unable to transfer to Allegro.
$ l6 w4 A' s& l- X0 z. N+ N6 I  C6 y7 }5 e0 t1 a; g0 j
#10  ERROR(302) Device library error detected.
: C- P/ e6 c9 p- w6 v1 ~7 K
$ K  ~, v7 |! j6 O3 yProblems with device 'CAP NP_0_RAD/.200X.100/LS.100/.'. JEDEC_TYPE property 'RAD/.200X.100/LS.100/.031' is illegal: 'Package name is not legal.'.4 E2 f. W2 v; B  c7 M0 h
6 @4 m+ H0 P7 U% c6 \' K
Device 'CAP NP_0_RAD/.200X.100/LS.100/.' has library errors. Unable to transfer to Allegro.
  Q7 I$ F1 W  g+ ?& S, @
" N; h, i  T0 m% w' t1 D#11  ERROR(302) Device library error detected.& e2 E& T$ g8 o+ H* `! c5 J
# N+ m3 g6 W3 N$ f
Problems with device 'CAP_0_CPCYL1/D.300/LS.200/.034_'. JEDEC_TYPE property 'CPCYL1/D.300/LS.200/.034' is illegal: 'Package name is not legal.'.
# W7 q; O2 P+ |. n1 N
- d- X$ p, m. N0 a0 BDevice 'CAP_0_CPCYL1/D.300/LS.200/.034_' has library errors. Unable to transfer to Allegro.
/ q/ M, K; L0 u  i# p- K" X. N6 n5 s, R& ?
------ Summary Statistics ------5 T5 v0 m' R4 M: Z2 w
/ U' e8 s( v. v: A! }
' ~6 e, b4 X. M8 f" E0 |
#12  ERROR(102) Run stopped because errors were detectedへ
0 }3 J3 A5 d3 S! ]2 ]! F
' z* x  ~0 v$ `! a& O: I7 D7 s" q3 c
netrev run on Aug 29 17:10:17 2008" O+ h. n) q' Q* n2 B4 ~) u
   DESIGN NAME : 'YANLI2'" l1 P: `+ k% o) y
   PACKAGING ON Apr  6 2004 19:58:382 z: u; E3 N+ X- n6 g4 Y; W( Y
9 @. H, M' M, O' K/ x7 s& r   COMPILE 'logic'
3 y: q" |. `  E9 B4 P   CHECK_PIN_NAMES OFF
5 X: d% M/ b8 _8 Y  D   CROSS_REFERENCE OFF$ [5 h' F9 l! w6 T
   FEEDBACK OFF
0 z1 ?! m, y& }! r/ E) n, D8 I! C1 ?! d   INCREMENTAL OFF  n7 M8 Q' x/ X
   INTERFACE_TYPE PHYSICAL
7 B1 C8 U/ f0 U* e) a4 g0 b, R   MAX_ERRORS 500' t) B1 ^6 K8 I3 p+ r
   MERGE_MINIMUM 51 {4 g& v+ `( Y: k2 S
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'" b+ \4 _* r8 N" Q
   NET_NAME_LENGTH 24. W: `: P* u: L& b8 N
   OVERSIGHTS ON. M7 T$ w6 X9 [0 `+ P
   REPLACE_CHECK OFF+ m/ a) `( X, r5 J% R7 F
   SINGLE_NODE_NETS ON
) g) Y2 T( W/ T   SPLIT_MINIMUM 08 l/ r" R; p7 i7 u
   SUPPRESS   20
& }# D. F/ t" c% K" W   WARNINGS ON9 c8 X) H, q& q& S8 f) Z
' N, G/ b8 }, y/ a( F/ W
12 errors detected. c) ^! \3 t3 u5 _
9 w. R! H/ e8 F- D7 k No warning detected
9 q( B% H! n3 p9 x3 X, y' U) Y7 i. H+ ^* J: l* p/ B$ a
cpu time      0:00:120 u# Y0 P7 w* T* |# |
; g% v7 B  s/ \! ^4 m
# ]( M" n2 N  c0 w  f  k
. W/ i' n  H+ [* f! c: s9 [3 Q3 {, z1 U4 a( n/ M: c4 t
*** Done ***8 I# l( u# e& E: h/ I: m# [. u! H
% T% r* T% [' l
********************************************************************************( h7 k& g" Y/ A. y- S% k( O+ {4 x" v& Y
; p: h2 `5 k5 j" k" H1 n* Spawing Allegro " a/ U3 @% R  I2 ~+ B5 u
  I8 B3 e6 E0 c! Z6 d********************************************************************************6 c! {' V  E$ J8 ~
Spawing "C:\Cadence\SPB_15.2\tools\pcb\bin\allegro.exe" -mpssession Administrator "C:\wenjian1\allegro\yanli2.brd" ' \7 [3 \! r+ a4 h) V- R
8 R! P" y/ o: q! l, z0 u
- B: w8 ]; L, o+ t6 s" |3 r*** Done ***
1 H" S9 U9 R( S$ T: I" E+ C# g: W. l怎么回事
 楼主| 发表于 2008-8-29 17:25 | 只看该作者
文件如下 请高手再指点!!!
谢谢  orz
wenjian1.rar
17.91 KB, 下载次数: 10, 下载积分: 威望 -5
发表于 2008-8-29 22:45 | 只看该作者
帖子不要发一大串,看的不爽,没心情帮你改错,同类型错误发一个就行了,把所有的错误都发出来,自己不分析一下就来问,那是对自己的不负责
发表于 2008-8-30 00:24 | 只看该作者
'Package name is not legal.'.说得很清楚嘛,封装命名有问题,出现了非法字符。Allegro中的封装名不能出现“.”似乎“/”也是非法字符。唉,其他的就不说了。
 楼主| 发表于 2008-8-30 10:38 | 只看该作者
刚开始学啊 有很多不是很明白
不好意思啊 我用的封装是layout 中的  是不是allegro 中的封装不能用layout中的???谢谢诶
GMT+8, 2025-11-4 21:40 , Processed in 0.156250 second(s), 27 queries , Gzip On.
