- E: k' h: T; v4 ^( T1 v
. t# o& }. S' q1 h6 g& c$ S- s- B: c! `! A0 q9 a
http://pan.baidu.com/s/1kToiYV1; X$ R' l, c8 A9 X7 o3 `: T' J
' M+ R; v: O1 B9 v( a) J$ U. p8 @) X' b
DATE: 06-12-2014 HOTFIX VERSION: 0305 V: S+ N, i; g" F
1 U& q5 h& @5 Y. ]CCRID PRODUCT PRODUCTLEVEL2 TITLE
" r( Q3 Y) x% A ^/ _2 @$ M===================================================================================================================================- l" p8 W4 W9 n* v. _
982961 allegro_EDITOR PLACEMENT Show the Rats when one selects physical symbols to place them
4 }3 q) d4 r8 j, M1138680 FSP POWER_MAPPING Ability to assign decoupling capacitors inspreadsheet like application
5 {* M$ n8 t7 F3 E$ B5 s% n: G1243410 SIG_EXPLORER EXTRACTTOP Circuit topology extract failed in caseof CLASS
. E3 a5 i8 R0 t% }( V$ H& g$ o1262977 ALLEGRO_EDITOR TECHFILE When importing a certain tech file intoan empty .brd Allegro crashes.
9 w4 ]$ x1 G( E9 a9 v- A1267558 ALLEGRO_EDITOR INTERFACES Arc part of symbol pin missing in 3Dview of step model& u; o: f& p& S# b$ c a7 V9 \
1268252 ALLEGRO_EDITOR GRAPHICS step place bound issue(3D View)9 P( B @9 u( j* j# u# x
1270450 ALLEGRO_EDITOR INTERACTIV footprint add line on line crash
4 I) Q7 A/ g8 A2 }$ q1270962 concept_HDL PDF PDF Publisher command line doesnot print pdf file if double back slashis present( I& J- J/ x( Y* _8 R1 g2 r
1270964 ALLEGRO_EDITOR mentor Mentor translation crashes with noerrors in log file
7 p. R9 Y, j3 b& E/ S! S* Q1 y1270999 MODEL_INTEGRIT TRANSLATION ibis2signoise Issue# O5 L, N, @( A4 j: [ S
1271543 ALLEGRO_EDITOR PAD_EDITOR Library import reporting missingpadstacks
/ D* b+ @% \5 d4 V' S; T, \ X1272099 ALLEGRO_EDITOR GRAPHICS Plotting does not fill shapes% |4 L T* U6 l8 C1 N, @
1272406 ALLEGRO_EDITOR DRC_TIMING_CHK skill command 'axlDBTextBlockFindName'returns 1 when nil is expected7 r3 q% L5 k+ n5 P3 B' `4 { {+ J) C
1272748 ALLEGRO_EDITOR GRAPHICS 3D viewer crashes on this specifictestcase
% O$ B/ ]( j3 o) d* g h# u1272793 ALLEGRO_EDITOR GRAPHICS 3D view doesnot displays hole withoffset correctly- F* m9 K ]2 L$ P6 r: [- C
1272863 ALLEGRO_EDITOR INTERFACES Ability to find the origin of STEP Filein order to place it exactly where it needs to be on footprint during mapping.
( R( R+ D, r% D P& F9 l1273264 ADW COMPONENT_BROWSE hyperlinks notrecognized in the component browser
3 c! \3 I5 w' w2 _1 ~( U1273304 CONCEPT_HDL PDF Publish PDF from commandline does not work ifthere are spaces in the Path
, H" B# `) F2 V: R3 j4 Q1274661 CONCEPT_HDL CORE I can't copy a property from onecomponent to another- {& P3 z( V- F+ p# t4 o; K5 Y4 R
1275237 ALLEGRO_EDITOR DATABASE Allegro Crash on running DBDOCTOR fora board; z6 w' W$ P( Q% E, r
1275345 CONCEPT_HDL CREFER The Xref information page numbervalues are incorrect c% }. j" k$ Z# j8 V$ I: ?; E) X* o
1275748 APD IMPORT_DATA WireBond starts away from the Die Pinafter importing Die using Die Text In Wizard
/ d" l, S. h7 x: N9 q* Q1276270 CONCEPT_HDL CORE DEHDL crash by Zoom In > Ctrl+A> Move, ]6 R, |% }) |* b
1277735 SIP_LAYOUT IMPORT_DATA sip layout spd2 translator issues withoffset die and mirroring
3 x0 u$ ^$ L* [/ j i, u) @1279258 CONSTRAINT_MGR OTHER Import logic stops with error
' X2 D `: Z; L2 f1279694 ALLEGRO_EDITOR SKILL axlCNSSpacingMin('via nil) crashesAllegro PCB Editor |
