DATE: 05-23-2014 HOTFIX VERSION: 0297 I" x" J+ z( e) t5 O1 V: G3 W. k
3 V/ \$ r9 m) T; S: }/ [* ^' G
8 h/ O" T. ?# ^& Q2 W0 d- z$ \7 h0 q& S+ [) g5 z5 j! ?' U
CCRID PRODUCT PRODUCTLEVEL2 TITLE
' s8 R9 m" O' \6 B8 s# [: l, [: L8 T8 |- S
===================================================================================================================================: }* }* ^/ U5 o9 m
* v6 j+ v% n& G1209461 FSP DE-HDL_SCHEMATIC Hierarchical BlockSize not automatically adjusting to text needs
* e. I/ K. \6 u# F4 h6 q; u
' I0 [# C8 t- _3 @& i' R8 Z1217832 SIG_EXPLORER SIMULATION S-param generated by SigXP doesn't matchwith HSPICE/ADS.
7 E5 {/ g0 I0 r9 D5 r* p0 x4 J( }/ n0 P/ F, b% W* S: G ~8 B. x
1263575 concept_HDL CORE Copy-Pate makes ComponentsOff-Grid& ]8 G X) }0 n+ i: o, X' G7 d
' U, m3 n0 P" z+ T1267602 SPIF OTHER Route Automatic hangs- Z4 \" V6 I! C/ K9 g# G A
3 G8 d! d- C6 T3 R( m. i5 u" R
1268022 FSP PROCESS FSP is not respecting the use banks forattached design.
. z# n0 c4 F. w5 e. a) H+ S- f
5 t. b" B/ S4 x, |1268587 allegro_EDITOR INTERFACES Enh. Preserve relation between hole andpadstack in IPC-2581) b8 G2 a/ r2 X& l
% {6 T8 C/ E$ _1268918 SIP_LAYOUT DIE_ABSTRACT_IF SiP - DIE export from co-design object to XDAresults in missing data" I. j: m/ V" _2 S3 g. R, L) b6 J
# a2 F g( ^# B y, ~* j
1269232 CONCEPT_HDL INFRA While Pspice uprev the designcrashes
2 _0 v; N7 t( @: n6 q$ |) A! E# C! u9 ]- U0 \1 X. e' R
1269825 SIG_INTEGRITY SIGNOISE PCB SI hangs when running crosstalksimulations( h& J/ f% k* `0 z; v2 K# ]+ Q
2 t: P; g! |9 t5 K" J6 ^; y1270963 ALLEGRO_EDITOR GRAPHICS Add Circle lint font hidden/Phantom hasresolution problem/ e4 h$ q9 Q' V6 K' M
' H4 A" [" w1 c( E g% F% y
1270990 ALLEGRO_EDITOR GRAPHICS Allegro response is slow when addedcircle
- v- m1 h& u$ J2 O9 _; _) m4 O' d3 G; v; q7 C
1271655 ALLEGRO_EDITOR MANUFACT Dimension option causes a genericcrash, reproducible in any design$ r4 C. g! ~& O. S% X: Z/ N% p6 ?
2 x% g. Z" R2 s% U0 @1 Q j X
1272495 ALLEGRO_EDITOR MANUFACT Filtered Part numbers in IPC-2581still pass actual part number for references onutide of BOMItem9 h( g2 f; H7 g6 e
2 f: ~0 E$ W; J/ P$ h8 {3 c! c* V
1272839 ALLEGRO_EDITOR MANUFACT Kindly explain the drill legendbehavior when padstack rotation is 45 degrees and mirrored ?
1 @- U! N( L: T" R- @& l: r3 P. f2 {1274518 ALLEGRO_EDITOR ARTWORK Artwork does not create voidcorrectly. |
