allegro 中报如下错怎么解决?
EDA365欢迎您登录!您需要 登录 才可以下载或查看,没有帐号?注册  ( c/ |/ Y6 [) J) KWARNINGS:7 ~" V6 A# F; D6 K5 {
 Dml model tdr_out is duplicated 2 times in libraries$ a# I. o+ ?  S# n! ?
 D:\cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml." S: o$ E" S0 ]% B2 `& o7 Y/ {
 Dml model se_test_fixture is duplicated 2 times in libraries# h4 {0 N' e! g  W, d( O
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.; M4 x7 Z5 M' @
 Dml model scope_in is duplicated 2 times in libraries
 L8 B; N( N% `  c5 O         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.
 * r3 ^, ^0 C1 F- D" uDml model resistorPack_850 is duplicated 2 times in libraries" F- ?# \9 _; J$ [6 x" e8 P% j
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.8 n1 G& x) _! U0 J; z5 v/ M
 Dml model resistor50 is duplicated 2 times in libraries& y+ c0 r; Z8 k6 y* D. @* j
 9 }" _. O  h, A5 n7 s3 r; ~Dml model p14u1_sparam_pkg is duplicated 2 times in libraries
 R& b. V9 t; e& p: `. W         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.
 $ G. x2 H5 m8 Y4 UDml model p14u1_modsel is duplicated 2 times in libraries
 - B3 \! v3 F& C. o( @2 y' J         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.& q# |9 U1 u: r
 Dml model p14u1_diffPair is duplicated 2 times in libraries
 % o3 N) r- z+ Z& j( Y- M6 i         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.2 O$ E+ D: r4 p2 v& \
 Dml model p14u1 is duplicated 2 times in libraries9 n& w) r7 m6 k
 5 d  G4 u: [) b$ K( H) pDml model lvdsload is duplicated 2 times in libraries, X" G* @, n# s( w2 L; t, @
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.) C, }7 F* b4 `# ?6 N0 n+ Z6 I: a. Z
 Dml model inductor15nH is duplicated 2 times in libraries7 f4 j# g7 `! Z6 a( h; M  i
 : X/ ~/ c# b& v+ M. GDml model capacitor20pF is duplicated 2 times in libraries$ t: Z( j$ M2 @1 x/ X2 I9 B8 W
 0 L. Z; f" Y/ ?3 F6 j! yDml model cable_espice is duplicated 2 times in libraries
 + |/ o. h" f  z         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.
 % d5 W" F) \/ @Dml model blm2_pos is duplicated 2 times in libraries
 ' v4 o7 D- {' \; S& T         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.% L6 |& B1 ?3 m  o2 a- R
 Dml model TestPt_ESpice is duplicated 2 times in libraries* ^& a) Q, M4 R$ L8 a+ l9 m
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml./ D1 }! s1 J0 X" d+ g0 W, A2 d2 V
 Dml model ScopeProbe2 is duplicated 2 times in libraries
 ' X4 H2 L$ u- A. e         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.8 W5 r. u2 C) w. D1 U2 S2 M
 Dml model ScopeProbe1 is duplicated 2 times in libraries
 & O& u5 C( G1 m# J/ T8 e- y         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.7 q- b/ h. y6 w  c$ C" _# K
 Dml model R50_withpkg is duplicated 2 times in libraries5 g! b, F1 I* S  {0 `, U7 y$ J
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml., h0 i. r  b3 T- I
 Dml model PCIxload is duplicated 2 times in libraries3 j8 D3 X* q5 d4 m3 ?. ?1 ]3 y
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_PCIx_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_PCIx_samples.dml.3 [' `+ R9 u+ u- e3 a3 P& a) `& C
 Dml model FourWireCable is duplicated 2 times in libraries
 + ~+ V4 E5 C* N9 I; B% P" P         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.* P. m. s$ O/ W; u. s( J/ @8 q
 Dml model EightPin_3p3v is duplicated 2 times in libraries
 4 D0 J5 n: @4 `( `& d+ t, C& h$ I         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.; I" \1 A, I: G1 y( ?4 i4 E, n- F
 Dml model EightPin_2p5v is duplicated 2 times in libraries' X6 S3 [: K, Y0 p% }  u
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.+ B& p. C; ?3 t
 Dml model EightPin_1p8v is duplicated 2 times in libraries
 9 Z! g3 [" D$ p/ j& ^: e0 c         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_samples.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_samples.dml.( P3 V' [( N" m( |
 Dml model DummyProbe is duplicated 2 times in libraries3 \9 w+ o0 r9 R, A  f* t+ z1 I
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_iocells.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_iocells.dml.
 ) l! ?5 n9 `; ?Dml model CDS_lvds_out is duplicated 2 times in libraries# m7 O5 a6 L: G6 w  D
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_iocells.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_iocells.dml.. G0 @. U# F8 D, T8 |
 Dml model CDS_lvds_in is duplicated 2 times in libraries
 % D! o" b% e" Z) i& r) l         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_iocells.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_iocells.dml.9 _, \% Z+ V: ~& P. R" }) c0 r
 Dml model CDS_lvds_device is duplicated 2 times in libraries, _; f. q* {2 B
 4 [' U2 g$ X% K! u& @5 k9 ]Dml model CDS_Pkg16DIP is duplicated 2 times in libraries
 ) e- E5 y" A7 r         D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_packages.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_packages.dml.0 b7 \7 k# a( M; }6 {. I
 Dml model CDS_Pkg14DIP_Sparse is duplicated 2 times in libraries* m1 K' Q2 R/ \: A+ w/ k
 D:\Cadence\SPB_16.6\share\local\pcb\signal\cds_packages.dml D:\Cadence\SPB_16.6\share\pcb\signal\cds_packages.dml.) e) l% y9 v% K0 f* Y* i6 M. u6 z
 + ^2 G- ^7 v8 t6 K+ K3 q+ P- t. [5 T1 S' D
