http://pan.baidu.com/s/1bnCJADx) p/ q) g0 C' T
DATE: 03-28-2014 HOTFIX VERSION: 026
" C; W2 d5 R5 a" W S; b===================================================================================================================================' Q7 M% e$ N* ?) D8 U
CCRID PRODUCT PRODUCTLEVEL2 TITLE' V7 C5 W. C9 t% N% d) Y( @
0 l1 Q$ l2 y/ G: B5 l% m1190942 concept_HDL CORE Cannot copy locked .xcon files" `: y) M3 T F, D6 ~/ E
1226085 F2B PACKAGERXL Winning net NC shorted with loosing netdue to PACK_SHORT
* R1 i5 J1 H9 B7 s5 N3 k# p1244894 SCM SYSTEM_OBJECT Get packaging error when adding apullup/pulldown resistor
. A2 z) L2 {) p H* E) f2 g1247432 CONSTRAINT_MGR OTHER PCB Editor crash; I* q, |: H$ j# R
1248560 F2B DESIGNVARI Variant Editor > Help about for S024says unreleased ?" f5 k9 r8 V% v- f& e9 h
1248712 SIP_LAYOUT WIREBOND Changing the charecteristics of a BondFinger causes it to shift position/ W& v6 u! z& w/ g& m
1248839 allegro_EDITOR OTHER 16.6 S023/024 crashes on LogicChange Parts command.
: n; N0 a* `' g7 }' y1249000 SIP_LAYOUT DIE_EDITOR unexpected shift of instances/pins byco-design die editor3 v2 l! N. M5 b5 s
1249186 ALLEGRO_EDITOR INTERFACES Bug - Export IPC2581 ignores propertyUNUSED_pads_IGNORE
; s I K1 ~% n- G, s E$ E1249272 SIP_LAYOUT IMPORT_DATA film resistor pins/pads are created onthe wrong layer. Always synthesized on top cond layer regardless of config file
# d9 J- @/ j' L" Y4 X1249792 ALLEGRO_EDITOR INTERACTIV Cannot place rectangular shape as perincluded width and height.4 b( b; l, L, W' a7 v2 v
1249801 ALLEGRO_EDITOR INTERFACES Bug - Arcs in IPC2581 export arecorrupted0 {6 A. D3 Y2 ^3 U
1251006 ALLEGRO_EDITOR INTERFACES IDX does not recognize PKG_PIN_ONEproperty
* A0 G7 r p j3 p, v1252142 ALLEGRO_EDITOR INTERFACES Remove inappropriate Conductivity specsfrom the dielectric layers from the IPC-2581 output. z0 t: t7 S) D3 _$ o
1253047 ALLEGRO_EDITOR SCRIPTS Bug: SAV file when creating symbol |
