查看: 1912|回复: 11
Hotfix_SPB16.60.026
发表于 2014-3-30 23:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
http://www.orcad.nl/patches/Hotfix_SPB16.60.026_wint_1of1.exe
* h% N& l% Z4 \& X7 x1 l5 o$ e+ c0 n5 \( g7 s3 b* b& e
! O9 ^. m" v9 X) u( B& W
  t; [( J* z# ]4 ]& ADATE: 03-28-2014   HOTFIX VERSION: 026
! m: ?, u3 w+ s& g. J) N( r7 i===================================================================================================================================( p7 @( ?6 \) _" K: r% {& I) Z
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE. K- n& b/ }8 m+ w
===================================================================================================================================8 f7 N- e5 E1 W' r1 @# M8 T( R
1190942 concept_HDL    CORE             Cannot copy locked .xcon files. p$ H3 B# J1 N3 R  d* |; J
1226085 F2B            PACKAGERXL       Winning net NC shorted with loosing net due to PACK_SHORT
5 b7 U3 o4 L  F, [  W' S1244894 SCM            SYSTEM_OBJECT    Get packaging error when adding a pullup/pulldown resistor
( Y  N2 _8 S( H2 \8 }; D1247432 CONSTRAINT_MGR OTHER            PCB Editor crash; j' \) b. }6 j
1248560 F2B            DESIGNVARI       Variant Editor > Help about for S024 says unreleased ?
: d1 w8 z- ?* }) D1248712 SIP_LAYOUT     WIREBOND         Changing the charecteristics of a Bond Finger causes it to shift position- @9 N/ V2 w- ^1 ?, q' c
1248839 allegro_EDITOR OTHER            16.6 S023/024 crashes on Logic Change Parts command.
' [% d; W2 q! A( b( W1249000 SIP_LAYOUT     DIE_EDITOR       unexpected shift of instances/pins by co-design die editor/ X) A6 C' B0 T- {
1249186 ALLEGRO_EDITOR INTERFACES       Bug - Export IPC2581 ignores property UNUSED_pads_IGNORE
+ H4 S5 M, K3 ^. V; b5 _/ \# k1249272 SIP_LAYOUT     IMPORT_DATA      film resistor pins/pads are created on the wrong layer. Always synthesized on top cond layer regardless of config file7 a) H& |8 _& V1 \8 y- l: [
1249792 ALLEGRO_EDITOR INTERACTIV       Cannot place rectangular shape as per included width and height.3 k: ?' Z: Q4 g! m( \5 ^6 [  t' c/ u
1249801 ALLEGRO_EDITOR INTERFACES       Bug - Arcs in IPC2581 export are corrupted6 o' R/ M1 U8 l- u
1251006 ALLEGRO_EDITOR INTERFACES       IDX does not recognize PKG_PIN_ONE property
( U! L# D, v' f$ {6 D1 I3 p1252142 ALLEGRO_EDITOR INTERFACES       Remove inappropriate Conductivity specs from the dielectric layers from the IPC-2581 output1 C0 y( k" `3 A+ B
1253047 ALLEGRO_EDITOR SCRIPTS          Bug: SAV file when creating symbol. q+ T. Z. m% b( [8 A
参与人数 1贡献 +1 收起 理由
stokley + 1 赞一个!
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2014-3-31 09:03 | 只看该作者
    不會吧??不是上週才出25,怎麼本週就出26了..* q8 m* L2 D1 f7 e/ w' ~* `
    不過還是要感謝大大的分享了..
    发表于 2014-3-31 09:46 | 只看该作者
    软件上还是现实25啊  肿么回事
    发表于 2014-3-31 10:00 | 只看该作者
    更新还真不是一般的快
    3 W) }1 u$ S9 M8 r+ B7 i- u8 C谢谢楼主
    发表于 2014-3-31 12:05 | 只看该作者
    更新的非常快啊
    发表于 2014-3-31 20:48 | 只看该作者
    楼主太厉害了3 a6 P0 E% _6 N
    2024-5-31 15:50
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    发表于 2014-3-31 21:38 | 只看该作者
    更新太快,什么时候出新版本
    发表于 2014-4-1 10:46 | 只看该作者
    谢谢分享,更新真快。
    发表于 2014-4-2 14:31 | 只看该作者
    thanks, 更新太快了
    发表于 2014-4-2 19:31 | 只看该作者
    请大虾给一个百度盘地址下载!
    发表于 2014-4-2 21:07 | 只看该作者
    神啊,今天上午打开 orcad 。还是绿色的。现在就出26号了。
    GMT+8, 2025-11-5 15:02 , Processed in 0.156250 second(s), 27 queries , Gzip On.
