请教一个关于Hyperlynx进行批量仿真与串扰仿真的问题。批量仿真:选用DSP与两片DDR相连接的所有网络,进行仿真。部分仿真报告:
; j' |5 c& Y5 F6 I4 f/ V a: C W% _* O; K( ` c" o
Maximum allowed crosstalk ........... 150 mv peak
! ^: b) g3 \' s; |& J+ g( Y NET = DDR_A5# c* I! H# J6 D6 Y
ELECTRICALLY ASSOCIATED NETS --------------------------------------
1 r5 W( b- Q: a1 u+ M net = T_DDR_A5_2+ I+ z6 L; L8 J% H) B0 D7 [
AGGRESSOR NETS (Estimated peak crosstalk)6 i! R: K7 F, @0 Q
DDR_A3 ......................... 395 mv
3 Q8 b! V, y8 t+ P0 S7 p1 D DDR_A7 ......................... 311 mv
/ E7 S7 a' `& U& V DDR_A6 ......................... 232 mv0 ], \5 O' q# Y8 {
T_DDR_A6_2 ..................... 182 mv+ D1 U- F( c3 p0 s+ t! ~% H! \: b
DDR_A1 ......................... 150 mv" R" R& h, N( C+ E9 u8 S5 a
Sum of the two strongest aggressors ............. 706 mv% S$ I, R) |+ @, d) @
** Warning ** Estimate exceeds maximum allowed crosstalk!
! L! ]8 `; O- |! @4 V根据报告进行DDR_A5的串扰仿真:采用electrical thresholds,串扰极限值设为150mv,选择所有与DDR_A5相关网络(即上述串扰超过阈值的网络)进行仿真,采用133MHZ,占空比为49%的激励源,将DDR_A5网络的输出驱动端保持低点位,示波器仿真图如下:8 L% f6 E9 r p9 I. [
# o& m, J9 M5 I, R8 ?/ D
& ?# L# t+ J* Z+ X9 _& D5 p如图所示,DDR_A5上输出端、两个接收端为0V附近三线,其中红色线代表某一接收端信号,峰值为155.7mv;浅蓝色为另一接收端信号,峰值为97.6mv;输出端信号为深蓝色线,峰值为65.11mv。问题:请问两个仿真模式下,为何DDR_A5上串扰情况不一致呢?8 s: y8 U* r2 \4 }2 p6 _1 @
" t/ K* u6 m$ n/ Q1 N& ]0 U% U% ~
7 p) B; ?) E! |! U" G$ |& v. G% q0 G9 ?
+ m# j2 Z8 X/ o- j
