查看: 2415|回复: 8
Hotfix_SPB16.60.023_wint_1of1
发表于 2014-2-18 18:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
http://pan.baidu.com/s/1eQl7md83 B: R3 v3 Q6 I  Z
DATE: 02-14-2014   HOTFIX VERSION: 023
1 Z- n, v7 y$ {===================================================================================================================================
7 h. H/ R7 g- T6 i, w2 H3 ]CCRID   PRODUCT        PRODUCTLEVEL2   TITLE7 p8 q. N* o3 k$ [
===================================================================================================================================# x1 s9 A* a, k4 Q4 r( a( ?
1120183 F2B            DESIGNVARI       Variant Editor Filter returns incorrect results.
9 @) }' V" ~- r6 N. Q1202715 SPIF           OTHER            Objects loose module group attribute after Specctra% b& h5 s  E' O9 B9 p' q) d9 I! k
1203443 ADW            LRM              LRM takes a long time to launch for the first time
: |8 P  @! H  X% Z& a1207204 concept_HDL    CORE             schematic tool crashed during save all. y' e3 R8 M+ \& H( E& N. \5 [
1222101 CONCEPT_HDL    CORE             Pins are shorted on a block by the Block's title delimiter  i' g3 V+ ]* x5 Q
1223709 FSP            FPGA_SUPPORT     Need FSP model of Altera 5AGZME3E3H29C4 FPGA
: R/ M* w! `5 k0 P' ^1224025 allegro_EDITOR INTERFACES       The 3D viewer when working on a brd file shows package placed on BOTTOM side of my board while it is present on TOP side
- s" E, C( @+ _% u" A2 W' t1225591 F2B            PACKAGERXL       Aliased net signals starting with equals sign are not resolved correctly in cmgr- L: k7 Y% C4 J, j: Y1 V
1226480 ALLEGRO_EDITOR EDIT_ETCH        Routing time is took to double increase when using the Add Connect because DRC is Allowed.0 }/ Q( h( t7 [! ]1 p
1229234 FLOWS          PROJMGR          Can't open the part table file from Project Setup
( V" ^6 F- X1 C1 p" w/ p1229555 ALLEGRO_EDITOR ARTWORK          IPC-2581 not recognizing pin offsets correctly.
8 X  R0 ]/ O, r+ B7 L1229610 FSP            FPGA_SUPPORT     New FPGA device request - Altera Cyclone V ST: 5CSTFD6D5F31I7" ]( w2 V7 Y$ b7 K6 q- x0 t- f0 v; N
1229664 ALLEGRO_EDITOR SHAPE            Shape not voiding different net pins causing shorts with no DRC's9 s& {+ R) p! h5 c7 y
1232601 ALLEGRO_EDITOR MANUFACT         Cannot add test point to via on trace.
, R" |6 d7 p3 ?6 s% ~" ]5 o1232772 ALLEGRO_EDITOR DATABASE         When applying a place replicate module Allegro crashes% m0 y2 d0 ?3 @$ r! K2 b! a9 z
1233216 SIP_LAYOUT     DIE_ABSTRACT_IF  Allow more than 2 decimal places for the shrink facor in the add codesign form$ ^# h2 t3 F- @4 z
1233690 PDN_ANALYSIS   PCB_STATICIRDROP PDN IRDrop: Mesh mode in Report is incorrect.9 X, E3 @8 K6 h7 Q* r- U
1233977 ALLEGRO_EDITOR INTERFACES       single shape copied and rotated fails to create when importing IDX! [1 o1 c' b1 F+ h1 V7 p2 X
1234357 SIP_LAYOUT     SCHEMATIC_FTB    DSMAIN-335: Dia file(s) error has occurred.7 E/ J% a' G- U
1234450 ALLEGRO_EDITOR INTERFACES       clines, pads, etch shapes to be at the same level with the board when viewed in STEP viewer.
0 W/ p2 \: E/ h7 R' K8 d  t1235587 Pspice         MODELEDITOR      PSpice Model Import Wizard does not display symbol graphics for DE-HDL Symbol/ U) c$ o8 _& q$ t8 a/ N; i  X
1236571 ALLEGRO_EDITOR GRAPHICS         Allegro display lock up and panning issues+ ^% X. e, B8 a- D: k0 R
1237415 ALLEGRO_EDITOR INTERFACES       Multidrill pad is exported with single Drill in the STEP File
6 i5 H5 j0 }  ^( O' v1237807 ALLEGRO_EDITOR SCHEM_FTB        The line feed code of netview.dat
发表于 2014-2-18 18:55 | 只看该作者
Thanks a lot.
发表于 2014-2-19 05:37 | 只看该作者
点赞,谢谢分享啊
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2014-2-19 10:03 | 只看该作者
    昨天才重灌16.60.022說,結果進了StartPage頁,就看到有.023出了,
    - c9 j7 [" E( ?6 ~  C0 \真是暈倒!!!!
    " \( `( I  m) [) ~4 C2 ^2 H太感謝steven.ning大大提供這網速快的百度網盤的資料下載了...
    2025-9-28 15:57
  • 签到天数: 316 天
    [LV.8]以坛为家I
    发表于 2014-2-21 10:01 | 只看该作者
    % l( d/ y0 F2 X# v1 ~8 Z感谢楼主分享
    发表于 2014-2-21 14:52 | 只看该作者
    更新太快了。。。
    2021-1-26 15:48
    发表于 2014-2-21 15:52 | 只看该作者
    可以提供另一種下載方式嗎?
     楼主| 发表于 2014-2-21 16:21 | 只看该作者
    + c3 r! D1 b6 V% W: n$ j5 W. ghttp://dl.vmall.com/c0fu1auqa8
    2021-7-21 15:48
  • 签到天数: 51 天
    [LV.5]常住居民I
    发表于 2014-3-3 09:29 | 只看该作者
    楼主给力,两种网盘都上传了!
    GMT+8, 2025-11-5 15:02 , Processed in 0.156250 second(s), 23 queries , Gzip On.
