TA的每日心情 | 开心 2021-2-2 15:32 |
签到天数: 3 天 [LV.2]偶尔看看I
本帖最后由 夏雨初晴 于 2014-1-5 23:11 编辑 9 `5 v! e" \& j+ R! Q$ ^
/ S5 W+ U. S$ Y) r1 `, p
主要更新修复:
* a4 N6 o; _0 S+ d |3 P# n% ]DATE: 12-20-2013 HOTFIX VERSION: 021& M/ L. W- d; u0 K5 ]- @) l
3 r3 ^7 U8 P1 C7 s$ |/ oCCRID PRODUCT PRODUCTLEVEL2 TITLE# B) F& P" I2 R7 ]: L/ D" h$ Q: V
6 @- c# [5 F/ s9 L1214932 allegro_EDITOR OTHER Allegro will crash when peRForming show dimension on linear dimensions.+ Y9 J) D7 l1 N1 `0 C
1215045 ALLEGRO_EDITOR skill Successive file open / ipc calls crashes Allegro 16.6
r: ]8 g' X4 w1215115 ALLEGRO_EDITOR NC drawing name doesn’t display in the ncdrill.log file# r) T; Z7 J$ x0 _# t" q
1216028 SIP_LAYOUT PLACEMENT Design will not update embedded component symbols.
- H) z: Q& j- c: s! U1 i: B* K; V8 Y, q1218451 ALLEGRO_EDITOR DRC_CONSTR Route Keepout to Pin DRC created even after adding Void in RKO shape
, J: E3 h. O, W% R. }# C: q1218636 ALLEGRO_EDITOR SCHEM_FTB netin process will rotate embedded symbols+ D( I4 t2 `# I# L$ h3 L! q. B
1218706 CONSTRAINT_MGR concept_HDL NCC associations get deleted from FE CM9 r/ E: \% q6 K
2 Y* E8 ^2 V5 P9 S百度分享下载地址:http://pan.baidu.com/s/1qWlSbJA |
