查看: 10608|回复: 87
Cadence SPB16.6下载(Hotfix020已发布)
发表于 2013-12-17 21:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* A& u9 Q& O3 C" m- R% i8 C0 z, @" L6 @/ |) k8 R- K* c: b
免责申明: 此链接来自于上海库源电气 如有需要请购买正版cadence软件 支持正版。。。。' ]) j2 \. z2 h' x) Q7 H
* Z2 p, y' B* N  a
' T6 G, ?% D& `
, q4 l; J3 a& b2 l+ J+ a
6 I! s. `7 i+ i3 y4 e/ l; d' u
游客,如果您要查看本帖隐藏内容请回复
; c4 U. a* E' r5 T4 m9 U+ I
打补丁方法:7 v- e8 {; G% u9 U+ S
     请论坛搜索,,,,! B& c. f. j+ l0 g3 P
DATE: 12-4-2013   HOTFIX VERSION: 020- A/ P$ P7 c# H7 b% W
; C2 w) i% y, i( j/ F, G/ c+ O===================================================================================================================================$ b9 J) k8 \0 M& p! _( [
4 c$ {) M! N9 c% h* m, TCCRID  PRODUCT        PRODUCTLEVEL2   TITLE' y1 L: ~' x9 P% Z! A
( H' M/ ?5 o: @3 N7 x
) K8 n- S8 h  h# z4 S: w! m! U/ ]5 r
1116426 F2B           PACKAGERXL       Packaging in 16.6increased by 3 folds compared to 16.3) @5 `4 y: V& K8 z4 B
3 z. r$ p- S) \! ]& J5 v
1190095 concept_HDL   CORE             In Windows modeselect the part and click on version placed selected version +1.
9 o7 ~$ R3 j4 ?% n
$ \& \+ v4 P: D1 p: u0 {5 ^+ C1199410 CONSTRAINT_MGR CONCEPT_HDL      Constraint Differences Report windowhangs in 16.6-s016
( _7 _1 a" e6 X4 Y
# {6 H5 r) v# K+ n1199425 CONSTRAINT_MGR CONCEPT_HDL      Import Physical fails (the cmfeeback.exehas stopped working) in 16.6-s016
: O0 L, j1 p% H1 X: H. ?2 l2 A5 _4 H1 g4 C. F( b
1199700 Pspice        NETLISTER        Netlist fails onaddition of netgroup
% |# n) z6 B& J* w$ [; Z& a2 n/ A) S4 U) y
1200936 CONCEPT_HDL   PDF              publishpdf failsif UNC paths are provided from the command line
! U! u2 W3 r4 Y" N+ H: d2 V- Q0 n( s0 Z6 c! J
1202391 CONSTRAINT_MGR OTHER            Getting 'An Invalid argument wasencountered' when generating Net Class-Class report in CM
% Z/ a6 N( O: ?! w3 ]5 ]. B! ?4 [4 d5 r4 @
1202587 CONCEPT_HDL   CREFER           Crefer schematicreports cannot be deleted on Linux.$ v7 |9 n( @+ L2 {# |9 Q
7 P; `! e3 s# O' ^1203143 GRE           CORE             GRE crashes on runningPlan > Spatial
" g; a# s  L! X! K4 B9 a
8 S, m  O% F4 }2 w5 ?% }, p1206019 allegro_EDITOR INTERACTIV       Allegro needs to be restrated to readsteppath with 16.6 S017
9 t) y7 c, ^: U) `% S9 ]  f
+ [( c0 D1 Z) k# n4 t5 t" e1207050 ALLEGRO_EDITOR INTERACTIV       Refresh padstack fails on Warning" x, F: F+ h" X: A. }& @% d" z
6 n. p' F( C% B( b" W: |
1207178 CONCEPT_HDL   CORE             Aqua color onwire does not matches icon color2 ~0 K. _2 e6 u5 p
  l7 L6 R. k& G% @4 ^, N  z7 e, D
1208152 F2B           DESIGNASSC       ERROR: DictionaryFile: cmdict.l could not be found9 }7 [% W: L+ Q/ U9 c$ a
5 E! J: s) b. R: H1208276 APD           STREAM_IF        Stream in failsto import what Allegro exported! D0 Y( a% z7 s. _6 V, Y8 H0 C
. y$ h- a( W) r/ G. u. H8 R1 ?( U
1208345 ALLEGRO_EDITOR skill            Why axlChangeLayer not working forshapes on this attached skill file?9 R9 t0 p% X+ G# p% g* ~
8 N  V9 y2 h5 r2 c1208351 ALLEGRO_EDITOR SKILL            axlFilmCreate do not define theIPC2581 domain correctly.2 q1 r/ c' O. h( \3 H, r# V& I
+ z3 w0 X$ Q- O6 @
1208467 PCB_LIBRARIAN VERIFICATION     con2con manglescell data after checking cell having syntax errors on part_table
; ~8 z+ _6 F# V1 P( C9 n8 ]" t9 ?  L, B2 m# b
1208579 SIG_INTEGRITY GEOMETRY_EXTRACT Incorrect traces are extracted when void area is lessthan anl_min_void_area setting) @" z9 `: t7 F- W8 L9 w
6 [( d' U, n, H$ p- ?; C- p1209347 ALLEGRO_EDITOR PARTITION        Import partition that has diametraldimensions will crash Allegro
9 ~4 ~0 h2 v1 f! o& b
9 Q  q1 s- B; I8 e( m1209897 ALLEGRO_EDITOR PADS_IN          Pads_in will not translate design.$ ]: d, _, x  m) n% ^$ I+ B
$ }8 N: u. f2 m  u* Q. P3 M  v1209902 PCB_LIBRARIAN CORE             PDV crashesreading part# O8 t  [6 P1 p, \7 n9 ~
( H9 v4 m0 L2 x/ i1210183 PSPICE        SIMULATOR        SimSrvr crashwith ORPROBE-3211 RPC Server unavailable Message; I: ^. X& B( {0 [2 {8 [
9 A9 b* r$ T! ?2 a1210408 ALLEGRO_EDITOR EDIT_ETCH        AiBT hangs when doing interactivebreakout on bundles using latest hotfix.
3 ?! p+ V1 U. t( f; r  O
  x; w; ], l, D  w1210443 ALLEGRO_EDITOR INTERFACES       Allegro Design Publisher does not createfully searchable PDF for some of the text that are present or certain layers
% H1 r8 ~: M! i$ `8 o- C( R
! ?% G8 r8 M" L1210876 CONCEPT_HDL   ARCHIVER         Archiverwrongfully deletes directories.
# d8 I3 ~/ i  f- U, o( o& f# r7 D+ o
1211839 CONSTRAINT_MGR DATABASE         Topology can't be extracted correctly.% A8 _$ L) e' ~. k2 }
) u3 S. |) s: x; C! ?+ Q" e  d+ q1212709 ALLEGRO_EDITOR DATABASE         No connect can`t be detected inSPB165S048
2 n5 O* e, z$ s0 s& y! T% z9 H8 T: I. M$ c6 [* X6 e! L
1213752 CONSTRAINT_MGR OTHER            "Show Constraint DifferenceReport" option at File > Import > Logic does not retain the lastsetting
推荐
发表于 2021-1-30 21:03 | 只看该作者
thanks a lot for sharing the information
2 ]9 I8 U- O  o' z7 u
    2024-8-21 15:35
  • 签到天数: 109 天
    [LV.6]常住居民II
    推荐
    发表于 2013-12-29 22:09 | 只看该作者
    nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn
    推荐
    发表于 2013-12-26 08:20 | 只看该作者
    如果您要查看本帖隐藏内容请回复
    发表于 2013-12-18 15:51 | 只看该作者
    看看有帮助否?
    发表于 2013-12-18 20:40 | 只看该作者
    你好,想下载一下,谢谢啦
    发表于 2013-12-18 21:52 | 只看该作者
      谢谢分享!
    发表于 2013-12-20 11:02 | 只看该作者
    解决什么问题
    13#
    发表于 2013-12-20 11:31 | 只看该作者
    # E& r8 g2 f3 w) h; {& \  谢谢分享!
    14#
    发表于 2013-12-20 11:42 | 只看该作者
    很好的东西,谢谢
    15#
    发表于 2013-12-20 12:54 | 只看该作者
    你好,想下载一下,谢谢啦
    16#
    发表于 2013-12-20 21:42 | 只看该作者
    找了很久 希望可以用, 感謝
    18#
    发表于 2013-12-21 09:41 | 只看该作者
    看一下,谢谢
    GMT+8, 2025-11-5 14:12 , Processed in 0.156250 second(s), 26 queries , Gzip On.
