查看: 1999|回复: 1
生成光绘问题================================================================ ...
发表于 2013-12-5 16:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出光绘的时候,出现下面的warning,请问,有没有问题,谢谢。如何检查断路?
9 c% S& @! x: b+ U; R2 @
2 {' W& n  i! ^4 C8 I0 D   WARNING: Segment with same start and end points at6 h$ c5 s. {9 ~6 }8 A  q
        (1175.500 1103.598) will be ignored. Increasing output: p4 j: C8 a- x# m- V
        accuracy may allow segment to be generated." F4 C& X2 @7 T, v  T6 s; m- P
/ s3 T# S7 q3 X( C: J2 J* q& K$ o
- I! }- d/ C) d- V6 Z3 o        (1279.689 1372.358) will be ignored. Increasing output6 U- r& o1 ?; }# G- b4 R
9 z! l) x/ h4 b7 f; d4 b& g/ }( d% P8 d
* d' g1 C: x/ e4 m& @3 [' j5 w3 z        (1433.228 1039.689) will be ignored. Increasing output
" }+ U0 q5 K0 E; r  C1 p        accuracy may allow segment to be generated.  G- {5 Y8 L7 v9 o1 b1 a' R
7 W" s8 {9 Q1 n9 g
    WARNING: Segment with same start and end points at0 `: \& \( Y- `7 V0 k: S
        (1492.004 1603.701) will be ignored. Increasing output0 b0 E9 o2 r$ s1 P/ d, C
发表于 2013-12-5 16:12 | 只看该作者
你輸出的FORMAT是多少???
GMT+8, 2025-10-26 18:21 , Processed in 0.125000 second(s), 23 queries , Gzip On.
