生成光绘后,如下信息,请问,这些warning有没有影响,谢谢。
* _+ l: E! h* p0 b* }0 L, u% I( {! }( U8 ]9 g) V5 ~
================================================================6 }% [! R" h# D' M
PROCESSING FILM < TOP >8 H! j) _/ X- [# H* `
TO FILE < D:/SCWORK/SYSB/PCB/TOP.art > ...
V, d9 P7 C) y# K, [" Z) S7 y; G================================================================6 c" \6 U/ ~, _, J
5 n) d4 T7 Z7 ^, T/ D! L6 d
FILM PARAMETERS :4 } c- X3 p$ i8 d
---------------------------------------------------------* o9 M& }3 F' Y, y
Undefined line width 6.000
: V6 y+ d4 P, A. }6 {5 l Mirror code NONE" Z: f% E5 o$ A" O" }
Rotate angle NONE/ ^9 r6 Y2 f1 O( V. y% J# N+ B3 c h; l
Offset x: 0.000* x A# d- e& Z6 j
Offset y: 0.000
9 B7 x8 @, [6 e1 @' { Plot negative NO, }/ o) |, X8 t$ b2 l1 V9 [0 g
Suppress unconnected internal pads NO
4 z; g5 R. O1 Q0 `! I& F. L- h; _( N# \/ t- n8 B& `) N
WARNING: 0 width line found at (20.000 0.000)
% g/ ~+ k5 G" ?, e ... using undefined line width of 6.000
& R, X' K5 ?% i$ x2 r% s5 S+ e% s& a% i* _9 M2 [! A
WARNING: Segment with same start and end points at
! n: H; F2 Y+ {- E# \* m0 k (2709.189 1745.260) will be ignored. Increasing output0 b* I8 \5 c: I" z' V
accuracy may allow segment to be generated.2 \% Y! u- p7 Z* |6 e, h
3 K- m9 u: `) H1 A! W WARNING: Segment with same start and end points at
. O' z+ y& E1 b6 E2 h/ o- s0 O/ D$ K (1175.500 1103.598) will be ignored. Increasing output! C, \ A7 v' t
accuracy may allow segment to be generated. |
