我代码是这样写的:clk为50M时钟,clk_out为一个管脚。3 X' Z# [" w( u2 R4 v
module test(clk, clk_out);
! w% s8 b- m2 S1 `3 c' \4 Q; pinput clk;
$ o7 j3 I+ @) a! zoutput clk_out;
' |& @4 v$ c, [# c! c6 E/*******************************/
8 U! C" b: _+ _) }' `reg clk_out;# U$ G6 L$ m4 Z8 v( c) u' i
reg set;7 z' ~# x% _, g5 k9 k Y
reg [31:0]cnt;6 }% C! N/ C' p3 P" p# Y- _& P3 u' d
parameter duty = 32'D100;( G v4 H! Y+ _" P! d
7 z+ W5 J" p5 oalways @(posedge clk)/ {/ j; l/ J* Y( Z
begin
- Y3 ?" I# m. e3 ~ if (cnt == duty)& O e$ T+ Z! `; ^( r
begin
s! }; s2 q; ~, B7 W cnt <= 0;
V8 `' J3 |/ @% F set <= 1;
# v/ W" {( q6 O& Y# [ G* g end$ b% i7 f8 U+ W" A; G
else
c' A6 M# F) X begin
/ M; Y9 b# _! h. N V D% X: {& \; C cnt <= cnt + 1;: J! p% S) k& |- d
set <= 0;
, c3 N: N; A6 K end
7 M* p. m" K, S9 M& Eend
) D+ R$ X1 L" k. e q7 P, _1 N/*******************************/
) Q0 Y) \" o: n8 w u+ f# t( \4 Y3 Walways @(posedge set)! y8 a' s* @ n- H3 O
begin. E% [0 {+ \6 `1 o; r) z; m
clk_out <= ~clk_out;
; O5 x& @9 Z! Oend
0 a. }1 R3 T4 q4 ]/*******************************/- v j# D1 \7 D: g* u
endmodule
& |& ~9 c* s- A( q
- s: H. b& H5 {2 C& z% ?5 P输出方波的频率很低,大概是1M,再大的话波形就会变了。这是正常的吗?还是测试方法有问题?
7 S m# K! E; k3 X+ F: j- y板子配置:DE2(核心是:EP2C35F672C6),其他就没什么了。 |
