查看: 2798|回复: 20
Hotfix_SPB16.60.019_wint_1of1
发表于 2013-11-18 09:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 pzt648485640 于 2013-11-19 08:22 编辑 * k/ @# x" d9 Q! E' I. j; N
# G- d0 `* t1 U  qhttp://pan.baidu.com/share/link? ... 9&uk=2033524562
) f" P: Z& P* D
9 d! v! U  |- ~' {% B* L. n5 g1 m/ a3 P: |) x
DATE: 11-15-2013   HOTFIX VERSION: 019, U7 K" o6 F) e8 q' }" o
1 a! E, L' W' H===================================================================================================================================
; j9 F* r1 c9 m; D/ F) t! I0 {% P  L. T2 T
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
) C1 f" |7 h8 D1 I% j
( F5 F- @; w# X4 [  p: c===================================================================================================================================
& B, X- B6 P) |, l1 P7 x
* l; ^7 U$ f2 K6 j+ f  K7 Q9 b7 v1176155 concept_HDL    CORE             Graphics remnants with 16.6 QIR 3/ t, n7 r2 t8 ^9 i" F
0 u' ^+ E3 M3 ]5 O1178272 CONCEPT_HDL    OTHER            Verilog netlist does not include split blocks correctly
7 T+ x/ w5 L3 H# n
. n; A" a, w% A1190782 FSP            FPGA_SUPPORT     Support for Altera > 5SGXEA9N2F45 device.
/ _! W( D0 U" M' n8 @6 o+ p4 X; O( r8 `
1194140 ADW            LRM              SYNC_PROPERTIES is not resolving issues a based sync_properties settings
( m3 a( G2 @2 E) {* _0 [$ J/ [$ d2 {) v" i: g' M5 B/ I
1195744 APD            EDIT_ETCH        Diff_Pair routing fails on certain Uvias in the pair.
7 a  B1 P/ G- N! n5 X5 n! e+ u6 D# u1 f0 W: s
1196704 allegro_EDITOR INTERFACES       ENH: During ipc2581 export checkboxes corresponding to ¿Miscellaneous Image Layers¿ should automatically get selected% ?# u5 c2 P7 j, v0 m" w
- g2 N: ]' ]3 V/ Y$ S1198340 ALLEGRO_EDITOR OTHER            Multiple -product option on the Allegro command line does not access the second -product, t0 t+ L  f5 F( A
# _( z" U- O4 T8 I
1198596 ALLEGRO_EDITOR INTERFACES       When copper thickness is increased for the outer layers, step Viewer does not show correct component position.
/ `5 C' o; K+ k
" c7 L9 m& }6 W# `( V9 N& |1199673 PCB_LIBRARIAN  OTHER            Component Browser fails to load footrpints if they are set with UNC path% P; ^2 N" b+ X9 L6 v
% h6 l6 K# \6 U3 n1 n* o7 {! ?  z1199889 ALLEGRO_EDITOR DATABASE         Allegro crashing with latest hotfix.
5 U5 v# w8 ^) h  Z; L% P' w+ K+ p3 V
2 @" K: K& @0 H1200303 ALLEGRO_EDITOR GRAPHICS         3D Viewer does not update after changing STEP model mapping
6 E9 t' C) u, q$ L+ z1 K: B1 O' V2 F8 x4 L* m, [
1200449 ALLEGRO_EDITOR REPORTS          Allegro crashes when generating Net Loop Report.
9 j9 v* h3 a; }* D( j" z! q* U# _5 `2 B  Z  J/ T
1200915 ALLEGRO_EDITOR DATABASE         Reducing accuracy of this specific design crashes Allegro3 m  r. B% P( Y2 c* a1 r  ^- j
8 |1 O1 I! ]( P- X( N) u5 r4 H1201011 ADW            COMPONENT_BROWSE Component Browser crashes in DB mode
9 p8 m# y  Y# H! h1 ?" M5 H5 F! ?- R4 Y. y
1201376 ALLEGRO_EDITOR INTERFACES       Allegro hangs when trying to map a specific STEP model to a package drawing.
; {) N/ W# l) I2 T0 j* T" ^9 T7 _$ I, N- D" n! i
1201897 SIP_LAYOUT     IMPORT_DATA      BGA Pin Colors not matching the Colors defined in the Symbol Spreadsheet after updating.
* s+ P2 _8 P9 ]5 e4 `" Z5 o% K* V7 P, D% o; M9 o$ f
1202709 ALLEGRO_EDITOR INTERFACES       STEP File generated from Allegro is not overwritten when the variable "set ads_textrevs# \2 C8 A+ E! ?6 h2 z# s
3 A  [6 F6 J; Q4 x, [/ ~
1202820 ALLEGRO_EDITOR INTERFACES       Different xml generation for same step model on S106 and S017
) g" o' ^9 y7 G9 O+ ?* i! v) s) k" d0 B0 E' D2 Y
1202842 ALLEGRO_EDITOR INTERFACES       Step model invisible for one pin dra in allegro 16.6 symbol editor
6 h9 o$ ~; }2 ]$ k' v" x% `' i' ~- L7 u$ K8 v
1202983 ALLEGRO_EDITOR SHAPE            Shape voiding creates DRC with Route Keepout
! U+ M4 a, W$ Z& y0 W: p" J& L) l- F( C5 l- n" `* s
1203125 ALLEGRO_EDITOR OTHER            Exporting STEP file with External copper enabled does not show all copper when viewed with Solid Edge or Inventor
% N: y; _' X2 U  _3 O; T9 f) ~6 t# o
1203236 ALLEGRO_EDITOR INTERFACES       IPC2581 output with crosshatched shape is not correct9 w9 I# _# P  Z2 D% ^* x$ M
. R0 M: O" M) u3 k! E- J
1203995 CONCEPT_HDL    CHECKPLUS        CheckPlus rule, local_signal_no_offpage_body, getting an incorrect failure.
, F/ U  R9 ~  G( j# D% x) k9 D7 H9 N, F  i4 ?1 O8 I/ q. \. C! q# E
1204629 ALLEGRO_EDITOR skill            axlUIDataBrowse crashes the editor or returns error
6 l& U3 r2 x6 h+ [6 c1 J& V( a4 _& }% S$ Z5 @; f+ }( M( o( o
1204640 SIP_LAYOUT     DIE_EDITOR       Concurrent co-design update fails& K4 F) R% J9 m2 V9 G  [0 \1 i
; t9 B( s0 ]: O; h2 ^* I* d1204881 SIP_LAYOUT     BGA_GENERATOR    Pin numbers are messed up after deleting a pin at a staggered bga% p6 h: u, @$ ?$ g5 y8 ]- ~$ p
$ o0 e  w' t0 o. v4 y: y; ?7 L1204885 CONCEPT_HDL    CONSTRAINT_MGR   Cant assign discrete models after the wrong model was removed.
/ x: A. g! {3 L" S2 V/ ^" ~# o' _" N9 Q3 S( R0 e; {4 l
1205374 ALLEGRO_EDITOR OTHER            pdf out command creates incorrect drill Symbol Characters placement in pdf file when setting film mirrored.: K! g) }# F. m: b
! q- w+ t8 ?! d$ l! [9 ?8 `
1205729 SIP_LAYOUT     DIE_EDITOR       update of codesign db fails on exit from die editor- L6 Y  J# q" w8 Z, f
% B$ s$ F3 E! B; M4 c1205801 ALLEGRO_EDITOR OTHER            Tool crash when do export IPF.
3 A, i% \2 {& Z3 Z& G2 A' |0 Q- E6 ?
1205881 CONSTRAINT_MGR OTHER            In CMGR , Objects > Create crashes Allegro
+ o% }8 i+ v' F- {9 I7 j4 [1 {& I, `4 I7 a& P, q- [- E
9 Q9 o4 Y$ Z* Z3 ]& D1 X
参与人数 2贡献 +7 收起 理由
yangquan3 + 2
interrupt + 5 很给力!
推荐
 楼主| 发表于 2013-12-6 11:05 | 只看该作者
as135781012 发表于 2013-12-6 08:57
  M& M) d+ a9 p% m/ N大家能破解吗?我 015可以破解成功,019不行。。。。。。。。。。。。。
: l* ~+ W) k; B6 s  X8 C; A6 ^, v; F可以的,我自己测试过
推荐
发表于 2013-11-21 14:29 | 只看该作者
mengshang 发表于 2013-11-20 12:385 y( m& H7 |9 y% G3 Q' P
怎么下载下来只有1M
+ P+ h& Y" g" J$ U  @( v6 ]5 b/ q1 O- B下载失败了吧,重新下载测试一下。2 K( r  i4 H" g: x$ t/ y( b
多谢lz。
推荐
发表于 2013-11-20 12:59 | 只看该作者
发表于 2013-11-18 10:55 | 只看该作者
这个得顶起吧
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2013-11-18 12:51 | 只看该作者
    趕快來下載囉!!!
    ) L9 ]% v5 Z, C3 v; m3 D' T- s謝謝大大無私的分享!!!
    2024-5-31 15:50
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    发表于 2013-11-18 22:32 | 只看该作者
    先收下了。谢谢!
    发表于 2013-11-19 13:09 | 只看该作者
    谢谢LZ的分享!!!
    发表于 2013-11-19 14:46 | 只看该作者
    能给详细点吗?我有点不太明白
    发表于 2013-11-20 08:56 | 只看该作者
    破解没有问题吗?
    4 _" s) u  S& G1 `6 x- N& D; c3 q
    / j2 k2 w; g% \  T2 U有没有测试呀?
    发表于 2013-11-20 09:54 | 只看该作者
    软件更新的速度真快
    发表于 2013-11-20 10:02 | 只看该作者
    谢谢分享,更新的真快
    14#
    发表于 2013-11-20 12:02 | 只看该作者
    感谢分享啊
    15#
    发表于 2013-11-20 12:38 | 只看该作者
    怎么下载下来只有1M
    GMT+8, 2025-11-5 12:15 , Processed in 0.187500 second(s), 29 queries , Gzip On.
