查看: 2127|回复: 13
Cadence16.5 Hotfix_SPB16.50.048_wint_1of1
发表于 2013-10-29 17:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
+ Z. V- I) r: q; B: f- i
cadence16.5 Hotfix_SPB16.50.048_wint_1of1 & ~; H9 D3 v3 A4 M" l( b) f" B
! y. X, ?9 q5 W* q
& ~$ ~2 @7 g# e* c* O; O, Nhttp://115.238.233.103/file/MDAw ... k&mode=download& b5 l- Q9 ^' k2 j: {* G' ~
Hotfix中只需要安装最新的版本即可。
. ?* B: m, P- E8 x$ C% k" MDATE: 10-4-2013   HOTFIX VERSION: 048
' T% q* B1 m, W. I. x# g: L===================================================================================================================================$ B  m% q' J. L
CCRID  PRODUCT        PRODUCTLEVEL2   TITLE
' h+ f# |4 G% Y' }0 ]0 _! _===================================================================================================================================
/ |: h: {5 P, x* m3 i  P1143902 allegro_EDITOR DATABASE         when the shape is rotated 45 degreesthe void is moved.4 u# N# l( @+ L; q% Q* g# C/ L; m
1145286 concept_HDL   CORE             Directiverequired for switching off the console
9 F! h( e' ]  u, w' i3 v1 }0 C, I1175307 CONSTRAINT_MGR ANALYSIS         CMGR fails to report RPD DRC foraccuracy 4 - mm
% S( ~  R" F! p+ ?0 Q- }! [1177714 CONCEPT_HDL   RF_LAYOUT_DRIVEN RF component's LOCATION property can not be set toinvisible9 }* z# W2 @2 a7 {* G. r
1178180 CONCEPT_HDL   CONSTRAINT_MGR   The"hier_write -forceset" deletes all existing constraints in CM
$ O: t  C6 @% b) u1184178 CONCEPT_HDL   CONSTRAINT_MGR   Ecset xnetmembers lost from electrical class when restore from definition of  subblocks
3 u# l) \' P: }1 h$ A2 V! w7 g1184682 CONCEPT_HDL   CONSTRAINT_MGR   Net Constraintnot transferring to layout from schematic
4 |9 Q# d5 N# o# {1186152 ADW           LRM              Part Status forDeleted Part in LRM is distinguished with other part status7 p# B' y& \' e& x0 e: i0 A
1187196 CONCEPT_HDL   CORE             TOC notpopulating (page 1)
$ f& r6 N- K) R* h- }% t' r3 }1187667 F2B           PACKAGERXL       Existing hardLOCATION property in drawing was left unchanged1 e1 ~- [' [6 L; w' T( `
1190144 ALLEGRO_EDITOR OTHER            Fillet shape is not genrated aroundcline
; A+ M/ k. g3 Z1 y7 q9 S7 ^& _1190618 ALLEGRO_EDITOR GRAPHICS         Enhancement for Visible grid, T* V' z& P4 R
1190927 CONCEPT_HDL   CORE             Check sheet doesnot report shorted signal/power nets if power symbol is connected to a pin* f/ C; X, U/ Y; u: Y
1191008 CONCEPT_HDL   CORE             Remove BinaryFile feature doesn't work
发表于 2013-10-29 17:17 | 只看该作者
The URL requested is invalid, please goto www.dbank.com to download the file. , V! m) c& l) W- C6 z7 S
( k4 ~3 X, x) _8 l
请求地址异常,有可能以下原因导致: 4 L  X) S2 b1 `' m; K5 H+ g; p) \
1. 复制地址不完整; , c# l. [, e0 \) J/ c
2. 下载链接已过期;
! C7 W) b8 Z0 g- W3. 从其他网站进入下载;
+ S8 \7 R8 U- m% c6 S  d7 Y8 z9 }3 T& i
注意,file.dbank.com的下载地址做了防盗链措施,请进入www.dbank.com提供的下载页面下载文件。
 楼主| 发表于 2013-10-29 17:22 | 只看该作者
nbhand 发表于 2013-10-29 17:177 k  e5 N! i; U8 }; B' m
% d* ^4 Y/ D6 U0 Q4 F
( B8 N* A% I& D请求地址异常,有可 ...
0 p  N! [( k9 O( T没法下载吗?
 楼主| 发表于 2013-10-29 17:24 | 只看该作者
http://dl.vmall.com/c0bnbzru42
# w) T4 }0 p7 t: y: v8 t2 b3 J, |+ Z( t6 ?) R  E/ Y
发表于 2013-10-29 20:24 | 只看该作者
谢谢分享啊
    2021-1-26 15:48
    发表于 2013-10-30 08:50 | 只看该作者
    谢谢分享啊
    发表于 2013-10-30 10:58 | 只看该作者
    楼主好人 楼主威武
    慵懒
    2025-11-3 15:37
    发表于 2013-11-1 08:20 | 只看该作者
    谢谢分享啊
    2025-11-3 15:00
  • 签到天数: 723 天
    [LV.9]以坛为家II
    发表于 2013-11-2 17:57 | 只看该作者
    这个无论如何得支持一下。
    2024-5-31 15:00
  • 签到天数: 1000 天
    [LV.10]以坛为家III
    13#
    发表于 2013-11-5 13:46 | 只看该作者
    感谢无私的分享
    2021-7-21 15:48
  • 签到天数: 51 天
    [LV.5]常住居民I
    14#
    发表于 2013-11-11 10:04 | 只看该作者
    谢谢楼主的分享!
    GMT+8, 2025-11-5 14:33 , Processed in 0.156250 second(s), 23 queries , Gzip On.
