****************************************: r5 H9 D5 X' ~, R
 *  Starting to assign physical parts.  *: h( z1 C& U$ w6 Z! E: I* P
5 }6 T, Z! @. E9 y #1  ERROR(1053): Cannot find a ppt part that matches the instance properties.
( ~! f  d4 l* U9 |1 U        Ppt Name: CAPACITOR_SMD" a3 N% v. `2 H: H) [& U
        Schematic instance: @CICORE_LIB.CICORE(SCH_1) AGE1_I516@LOCAL_LIB.CAP~
) u9 c2 E7 y8 j8 `. z) `; B, XACITOR(CHIPS)" z1 w1 }8 }- r0 J. b# O
        Property Name: VALUE     (OPT=?)! F( @1 A4 x1 H. E
        Property Value: 10UF4 b7 Y% D' \7 X* ]. A3 Y" c* L: Q
        Property Name: JEDEC_TYPE     (OPT): g% ]& u, u$ J4 k
        Property Value: RESC1206E
6 n. ^) a6 x- c3 @! n' B0 N& ] #2  ERROR(1053): Cannot find a ppt part that matches the instance properties.
/ _7 t& J; W1 W/ a  j        Ppt Name: CAPACITOR_SMD
7 w' L4 n( F  j; u        Schematic instance: @CICORE_LIB.CICORE(SCH_1) AGE1_I517@LOCAL_LIB.CAP~
  y2 F/ r; f: E, H% U1 Y+ \ACITOR(CHIPS)
- s% k4 G, n" m5 V  s0 f7 H" x" ^        Property Name: VALUE     (OPT=?)
( u3 Y6 g4 M% i1 O0 C! K        Property Value: 10UF9 U' {- _! _, ]* I* p
        Property Name: JEDEC_TYPE     (OPT)6 H. w7 D$ n1 j8 ?4 X: J
+ x7 R0 z0 A- N #3  ERROR(1053): Cannot find a ppt part that matches the instance properties.* z$ h1 X6 w- \* }3 ]; }
        Ppt Name: CAPACITOR_SMD- B1 M: R- e' A2 q8 W' q
        Schematic instance: @CICORE_LIB.CICORE(SCH_1) AGE1_I540@LOCAL_LIB.CAP~. d. z/ Y  M  t1 Z
ACITOR(CHIPS)8 T& R* G3 `' Q! L& U
0 E! }2 c( h0 u$ B* o( u7 w        Property Value: 10UF
: L) B& f8 f! d7 q6 Y2 a. }7 W1 J1 D6 `        Property Name: JEDEC_TYPE     (OPT)
' G0 t2 \$ o9 d) ^/ K+ ]- F+ V" b        Property Value: RESC1206E% S( Q) Q/ q8 t+ `9 D
 #4  ERROR(1053): Cannot find a ppt part that matches the instance properties.
$ c4 {/ D" y+ B        Ppt Name: CAPACITOR_SMD  B& e, [6 P+ A# I
        Schematic instance: @CICORE_LIB.CICORE(SCH_1):PAGE1_I544@LOCAL_LIB.CAP~  [; ?! t: h9 C5 Q; `# g
ACITOR(CHIPS)
2 k& X) j- E$ ~: C6 k/ O        Property Name: VALUE     (OPT=?)
; K# J1 L, L" X5 [        Property Value: 10UF
- p/ M9 x& t5 y2 `% y6 }        Property Name: JEDEC_TYPE     (OPT)) _: l! [9 R8 e# R7 B
        Property Value: RESC1206E  b5 A$ J) {- f+ e
 #5  ERROR(1053): Cannot find a ppt part that matches the instance properties.
% K* {! T$ C* A: b4 T4 s0 G5 U2 y4 |        Ppt Name: CAPACITOR_SMD3 ?! Y2 o2 ~" k, S& V# ~
        Schematic instance: @CICORE_LIB.CICORE(SCH_1):PAGE1_I545@LOCAL_LIB.CAP~
& h6 {* P, l+ x) d$ T% b" hACITOR(CHIPS)
0 F( {2 y6 ~. }: l* U6 r* U        Property Name: VALUE     (OPT=?)
9 h& s/ H( p# n6 `8 N        Property Value: 10UF
$ k/ I+ g  ]/ R: ?        Property Name: JEDEC_TYPE     (OPT)
2 o* H0 W7 O+ S! \' u7 [4 V        Property Value: RESC1206E
% C! ?: Y/ i$ {1 f #6  ERROR(1053): Cannot find a ppt part that matches the instance properties.2 W  B7 U: ]' I# @& }- l  ?
        Ppt Name: CAPACITOR_SMD5 K# o2 Y5 L% p: i0 S
        Schematic instance: @CICORE_LIB.CICORE(SCH_1):PAGE1_I553@LOCAL_LIB.CAP~1 ^1 T* E+ }/ N+ Z+ s
ACITOR(CHIPS)
- \; u; T: {$ z# R: y' y6 h        Property Name: VALUE     (OPT=?)- o/ [. p' P% `2 B; q! G8 v) M( B
        Property Value: 47UF# t8 N/ M* W* v; `1 g
        Property Name: JEDEC_TYPE     (OPT)" ]/ u0 G$ a6 F! ~" o  ~
        Property Value: 1206
5 d' \5 g- ]6 z5 a; {4 I ***********************************************2 _' A% @- O& A8 g7 h
 *  End assigning physical parts.  (00:00:00)  *' p8 R2 T+ W! n; b5 l6 t/ ~
 ***********************************************+ O( U( A/ D, D( c
' \( r% ]6 m% m- w6 ]0 ]2 d* |文件从 HDL 到pcb的package 总是执行不过去,上面的这些我需要调整哪一些?该怎么做? |
