跪求allegro16.2生成artwork出现报错解决方法 : ; V2 r, A( ?3 j! D
$ S6 I) w7 w6 E, T6 {9 B& S( Z2 ?0 k* I0 t5 M
Results from parameter file ...
8 X! ?8 U* ~! ~- ^% ^2 Z3 Y DEVICE-TYPE GERBER_RS274X' m h$ M+ F" C$ C7 v6 n1 P
OUTPUT-UNITS INCHES
- k" t9 a; L9 Z" W FILM-SIZE 24000 16000 B4 d* s5 L7 H) [7 [
FORMAT 5.3
3 Z0 e- Q$ P: b5 _4 t4 W* M ABORT-ON-ERROR NO; j4 i: x$ v& `/ Y
SCALE 1
6 d1 [) I3 f9 V$ _) d SUPPRESS-LEAD-ZEROES YES, ^& \. h! T& y
SUPPRESS-TRAIL-ZEROES NO' S' m7 o& H$ @9 V' Z' E. C
SUPPRESS-EQUAL YES$ T1 E' p, |9 h; S
UNDEF-APT-CONT NO
% [3 ?- h4 v( g. P+ m( J4 X; H A9 w8 S" x9 W
WARNING: for raster artwork formats, artwork accuracy must be
6 j5 b" D6 X) L7 r8 r0 p0 ` at least one place greater than the database accuracy, up
# ^$ a5 u6 I( Y% [/ B6 L to the maximum accuracy allowed by the selected output format.: @/ ?$ `2 X; \% n! O
' v7 |$ A; S) S1 W# i
Increase the accuracy by increasing the "Decimal Places" in0 k# H/ J* A! Z1 I' m& C
the FORMAT section of the artwork parameters and then rerun
/ P) f8 p, N) v& L% ~0 c artwork.! v: q3 U+ `7 E. M5 E% u
; ]) A+ B. A3 c! r The current output is rounding down the data. Failure to change9 [' g! \5 |) q4 b5 W) w
the format may result in inaccurate arc coordinates in the output* f$ t5 [, E1 F
files and possible shape/void plotting failures.
, n7 ?5 Q8 c: S8 g5 n/ c: \1 h+ h4 j' }" F5 X
# U4 ` ?9 q" f: m================================================================1 B8 n# `5 r) S" c
PROCESSING FILM < POWER > ?* f' [8 f) j O
TO FILE < E:/highvision/project/RK/RK3168/pcb/POWER.art > ...# F O! L# A# ^- u& { T) p
, |' r5 n/ p! m# v' [! z& g# w; U3 g% i
FILM PARAMETERS :
: m, [- g, [4 D/ ]) w$ r3 ^2 y ---------------------------------------------------------; s( X' f5 _9 v5 R
Undefined line width 6.000
. n5 Q0 `2 n5 |/ I1 a% w& K Mirror code NONE( Z$ {( K0 s( _! |# A
Rotate angle NONE) y1 L ?+ |2 C% D, x, J. f% {
Offset x: 0.000
3 l1 |# ^+ l9 }' e& S4 p: v Offset y: 0.000, i/ N3 e+ A) h* N w9 \
Plot negative NO: B$ F: A/ j$ ~* t
Suppress unconnected internal pads NO
' l$ f' K$ t) N' G
, J/ E' f. K* Q) c* d WARNING: Film contains DRC error(s).
! {% s+ e3 m, l/ c2 v WARNING: Segment with same start and end points at0 Y7 f ?3 J& [2 e6 O: ~( l! E" g
(312.890 -1452.988) will be ignored. Increasing output
: w" \* T* }+ ` y4 t3 o. I, Z" U accuracy may allow segment to be generated.; d" l. ]: k& E' N5 m( z
. ]2 n& _6 U8 z
WARNING: Segment with same start and end points at& Z- s' _% ~, ^1 `5 N2 ]
(1074.500 -1458.000) will be ignored. Increasing output' s- j `0 z x5 E; C" P H0 e
; E' s$ y& Y5 t- T
3 j! d! D4 ]3 F! N+ p* x8 { WARNING: Segment with same start and end points at
( a$ t/ q2 V, E3 H0 h3 v; U: z (-1203.819 -1693.181) will be ignored. Increasing output0 b* r1 B; Q+ r& v) ~, r! a* b
# m/ {& j( t& d* \- X) T$ v
6 E& N$ K0 G# `8 l* j1 l9 w WARNING: Segment with same start and end points at
$ B1 B% f6 H5 ?3 i (-1128.882 -925.181) will be ignored. Increasing output4 H) G; ?8 l' a% B1 X
, ]. Z& E$ M1 ?8 ^' W2 ]. n% D# k* a' a, _
WARNING: Segment with same start and end points at4 F, y8 W2 m6 n$ a; M- D
(-1128.882 -903.642) will be ignored. Increasing output
' b% w, z0 i( D5 A& k+ c accuracy may allow segment to be generated.
1 }( v/ N6 [6 b8 U* ^! J' z
/ f# N' @! _. ~) p, x WARNING: Segment with same start and end points at7 X) f- D# Y3 v; E) ^% D$ x* t
(-812.469 -725.142) will be ignored. Increasing output. V3 [' R6 [0 U/ H) {8 ^% ]
( w, j; j2 w6 R- u/ Q. R- g
0 v: k5 O, V1 ^5 d4 f WARNING: Segment with same start and end points at
+ `* k1 [, K* _" N4 R# @ (-812.461 -725.059) will be ignored. Increasing output3 S' c/ r3 H" u# U* L7 I; P
, Z! f p1 N1 g" K% J( `: S7 D$ H/ ?, x! O& H: q
' O2 S" }( `" D; u/ w (-768.260 -730.799) will be ignored. Increasing output- v1 w2 V# m( k6 }8 c9 W# ~2 `
accuracy may allow segment to be generated.8 f" w1 D/ [4 ~$ m3 V1 ?' ?9 u" x# N
6 G9 ^) a; ]5 l( R+ v6 W
# H1 J; w: P3 _" c( ? (-943.358 -527.441) will be ignored. Increasing output# j, r0 L5 s% t# m
1 I4 X' W1 ]' o% _7 b) F' v5 {$ U
, e/ R- g; E6 w WARNING: Segment with same start and end points at |
