查看: 5294|回复: 6
Cadence SPB OrCAD 16.60.016 Hotfix
    2025-11-3 15:00
  • 签到天数: 723 天
    [LV.9]以坛为家II
    发表于 2013-10-5 20:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    cadence SPB orcad 16.60.016 Hotfix | 853 mb, H) H, z: V& x# o1 g
    DATE: 09-27-2013   HOTFIX VERSION: 016  W! l: q3 l# @9 A
    & r. ?+ B8 ~  v; S  a
    & `* u  R( h# l2 E4 C
    & N) p+ N7 @$ I/ N% y+ @5 w* a/ wCCRID   PRODUCT        PRODUCTLEVEL2   TITLE( G6 L  r- [% |
    ; c, O2 `; b0 i$ ~5 ?* n6 e===================================================================================================================================0 U0 l1 a; W6 S5 S- o- `0 t3 y$ {
    + R5 H  L0 \; [" [, l7 N548538  CAPTURE        NETLIST_allegro  Enhancement:Include mechanical parts in Allegro netlist
    4 S" L  k! }- a6 W* L- G3 p' c6 q) b2 u1 n7 c6 `
    1076579 CAPTURE        GENERAL          Display value only if value exists& e2 e0 w+ y# B3 {2 X+ h( @, K( p% R
    % C7 u  e/ _* E( M6 ~8 [1083904 FSP            GUI              Need Filter in Change FPGA dialog to select desire FPGA from the long list.1 x6 U8 A4 G) y
    0 I7 L  i, S1 h+ f1089313 ALLEGRO_EDITOR INTERFACES       Allegro Export PDF requires similar setup options as DE-HDL Export PDF for layer visibility1 A. e# Z/ b3 l( q6 `, j  g# R4 W
    5 J2 J$ _0 a" k: v% R  `) r
    1095728 ALLEGRO_EDITOR EDIT_ETCH        Slide to grab adjacent elements when extend selection is enabled5 v, A' M  H/ M3 d0 f/ R7 U
    * Y9 L6 S( z8 U# ~# d1102698 SIG_INTEGRITY  ASSIGN_TOPOLOGY  ECset will map on single ended nets but fails when the two nets are define as a diff pair.
    & t" J' Q+ t1 [; f* }  a7 |+ T2 S  q: x% Q6 p% M4 [" {7 Z0 ^
    1104071 SIG_INTEGRITY  REPORTS          Shape Parasitic value changes for bottom shape for changes in top shape
    ) c/ K# C7 h+ I, U0 a, U& T, B3 i& m- X) _7 w: p+ Z# M
    1117731 FSP            POWER_MAPPING    Ability to sort in Power Regulator forms
    ) x8 C! f$ w" s0 C
    / r5 _+ Z3 f$ ^1 j# X$ _/ @! Y6 x1121539 FSP            CONFIG_SETTINGS  Cannot configure special FPGA pins (temperature diodes), Y, o0 z& k, @: }% j/ ~& G/ z' L
    : Y- l1 h3 l) f( }* l: n1122721 FSP            MODEL_EDITOR     Partial copy-paste overwrites the complete cell in XML Editor
    4 Z$ D) N" {# @. F) S: h6 Z, [+ P8 {1 I* d. F
    1123238 FSP            TERMINATIONS     Report functionality for terminations defined in the complete design.3 ?4 E  U( n3 r7 r8 Q7 n; J7 d+ {% i. ]
    : M- s% L! U8 h4 I4 m
    1123364 FSP            GUI              Clicking on column header should sort the column.
    ! @5 I% e( _$ o  k3 U
    * r; T. Z5 s0 _1 Q% ?! Q1123403 FSP            EXTERNAL_PORTS   Improper checkbox selection for 緿o Not Connect?or 縀xternal Port?column
    1 ?7 l2 \7 i1 Z# N5 }1 A( B% H' b% V$ C4 ~( C2 Q
    1125611 concept_HDL    OTHER            display unconnected pin in schematic pdf.. W' s8 {( B. B$ ]) q
    ' g( s" y, C' h+ Z1 t' v
    1129871 ALLEGRO_EDITOR INTERACTIV       Wire Profile Editor can't read mcmmat.dat in working directory.
    5 a2 R2 m9 X6 }- a5 T8 J# {! A; L0 e1 N
    1133688 ALLEGRO_EDITOR GRAPHICS         Enhancement request to enable 3D Viewer to show STEP model from .dra file.
    ! a* }( a. P  ?/ G; w! D1 O$ c/ @6 {- n/ u
    1141747 ALLEGRO_EDITOR GRAPHICS         3D view dooesnot displays height if step_unsupported_prototype variable set
    6 K+ D5 c4 P: }- f$ E  k6 @# ^
    1142215 SIG_INTEGRITY  SIMULATION       PULSE_PARAM set on DiffPair wasn't used for designlink simulation.
    # U; v5 o9 h8 B4 G, j% ]0 L& g
    5 q+ |+ J/ C$ w: k' C1 ~( x1142798 ALLEGRO_EDITOR INTERFACES       Step file output is incorrect in step viewer when composed of arcs and line.
    , N7 _8 s, Y6 o2 j5 m' F, Q* |% @0 \
    1142894 FSP            GUI              Ability to RMB on a header and select `Hide Column?
    4 Y( D2 k+ E9 a5 _; \# w1142940 FSP            EXTERNAL_PORTS   Issue with checking/unchecking "Do not connect" and "External port" cells
    7 [, S/ q+ q, k6 r+ D0 ^, c- E7 u' m% u5 N$ D4 P! l6 r7 H
    1142949 CONCEPT_HDL    skill            Usage of "Preferences > License Settings?in FSP3 T3 _! E7 ]2 O6 B; L: Y
    ; ~$ k- p8 ]! k- _7 f& C2 R1143091 SIP_LAYOUT     SYMB_EDIT_APPMOD symed:  When AddPins is used to add pins to a co-design die, those pins are not output as bumps in the die abstract+ M" u2 y& f/ w& t; U
    $ a* A7 J& q( W/ _6 U) f1144371 CONCEPT_HDL    COMP_BROWSER     Component Browser search results are inaccurate
    & S; o2 y# p% V7 N5 ~0 c; X0 M: X, t* j6 V% t/ Z" \
    1145033 ALLEGRO_EDITOR PLACEMENT        When aligning components with options in Placement mode displays no busy indicator
    ) h. f$ D6 h9 n$ E: p) J/ _: `4 \' \( N
    1145286 CONCEPT_HDL    CORE             Directive required for switching off the console
    " }. I6 G" y% L% \3 X  C$ E
    & Z# P/ g% v! E. b6 K* a) H) Q1145800 ALLEGRO_EDITOR GRAPHICS         Spurious odd lines are shown in shapes and text that are not part of the design with opengl.& W% I2 F" n! v) ?7 n. o' V$ i2 l
    % |. [) |- o8 R* V! U" L  G
    1147899 ALLEGRO_EDITOR SHAPE            Autovoid two overlapping shapes that share the same net) m4 T4 w6 q6 a" F9 w/ l. O
    2 w/ U8 y+ @$ L/ j/ o6 _$ W$ _
    1149996 ALLEGRO_EDITOR EDIT_ETCH        Routing does not follow the ratsnest 'pin to pin'.- T( ]/ N) n$ O7 `% w2 d* n
    - V1 ^' V1 e1 T6 U1150847 ALLEGRO_EDITOR INTERFACE_DESIGN Rename of DiffPair was not retained.
    $ `$ m4 ^% ]$ F! m, j
    , B: B& d1 N1 m& x1152577 ALLEGRO_EDITOR DATABASE         slide removes cline seg, C$ x: D+ I6 I
    & ^. ?. ]! ?; @1 H7 E( G
    1152751 CONCEPT_HDL    CORE             Option to double-click and copy the Netname+ V( u7 g: F  \
    ; k3 D/ o0 Z9 d) V. t
    1153220 ALLEGRO_EDITOR INTERFACES       ENH: option to supress header/footer during PDF Export
    " r1 |) B* G* Q+ w( x9 h; q" }- t3 b) L* o3 y
    1153625 ALLEGRO_EDITOR INTERFACES       If Symbol has place bound bottom, the step model shows incorrect placement.0 a( i) H# R5 _+ G8 b
    + h' v, V4 }9 [" k% r2 p- z* N) o
    1153813 CONCEPT_HDL    CORE             Spaces should not be allowed in the signal name entry form
    - R# g) z, V/ W& n! f4 T
    0 {4 _& g5 S1 L( H: P! c1153857 CONCEPT_HDL    CORE             Changing different power symbol should maintain the schematic level properties.4 m4 J. t. c" o+ z& Y
    ) g( V6 |5 ], Y  g. g! U/ u& C  K1155161 CONCEPT_HDL    CORE             Add Signal name: Suggestion box overlaps with the typed signal name that is typed
    ! Z1 z6 S- Z& s2 ]9 B1 g$ W8 C" `+ \# U9 ?5 F! t' L
    1155922 CONCEPT_HDL    OTHER            How can I use the batch mode for PDF Publisher and print a variant overlay?8 d6 W! J9 E8 ?# w) p
    " i5 E9 _5 d2 g6 {$ D2 T1156858 ALLEGRO_EDITOR pads_IN          PADS Translator: Missing drill on square PTH padstack9 w/ P, J9 E* G7 l8 Y/ n
    $ l5 e; W4 s4 X. Q. E
    1157362 APD            3D_VIEWER        Need a way to color multiple nets in 3D viewer from APD/SiP.
    1 i  ~# L, k+ c. m) o7 O' ]2 O) V9 Q1 ~6 d. X
    1158130 CONSTRAINT_MGR ANALYSIS         Constraint Manager do not display the Cumulative Result in Reflection Simulation8 W0 o/ C- s; p! ]6 m8 j- i
    : d7 N1 t* ]3 Z( i4 M; O( d0 D1158210 ALLEGRO_EDITOR SHAPE            SIP Layout happens crash while users move the shape with route keep-out
    $ s7 Q8 R3 \; C5 i6 D% u0 N
    $ z( z7 R5 C1 u1158452 SIG_INTEGRITY  GEOMETRY_EXTRACT CPW differential traces are not extracted as coupled when they are routed at an angle
    ! w6 {7 _  d" u( i: \. m) w
    ! p# `; b! u. l2 {1158827 ALLEGRO_EDITOR EDIT_ETCH        Slide a via in pad automatically add cline back to via to pin.+ R4 F5 a# ^8 H. Y
    # Y: p# A' m: U% `! T2 M* {
    1158871 PCB_LIBRARIAN  IMPORT_CSV       PIN TEXT is not automatically added when importing the .csv file
    3 O/ m' D8 V& G! _
    " b; f5 I3 I0 \  x; q& b: L1159738 ALLEGRO_EDITOR INTERACTIV       Selecting the Cancel button in the Text Edit command does not cancel the text.. ~. q( J+ l, O
    $ a+ _2 b, K/ t
    1159878 SIG_EXPLORER   OTHER            Ecset mapping dont follow topology template3 D6 T" ^( A" B" y
    & d5 t9 S2 f$ \! e0 N1159971 ALLEGRO_EDITOR MANUFACT         Allegro PDF Publisher requires ability to control film record sequence when generating the combined PDF file
    : g- q: @% X1 F5 h7 X
    ! ?6 Y# X( E* b6 m6 Q1160017 SIP_LAYOUT     DIE_ABSTRACT_IF  Add text to clarify shrink operation
    + }+ |) L# p) R" q! ~
    * {  k) ~1 I) n# n# r2 U/ S1160507 APD            EDIT_ETCH        Script not playing back what was recorded when sliding lines
    ; }# E$ m* r: \/ Z/ W, D" c8 s. g# ?) g2 f
    1161261 ADW            TDO-SHAREPOINT   Schema for TDO-SP fails on Japanese OS
    9 D/ E7 E: i0 |+ i7 o" F/ Z
    ) B# w" J9 F) v. ^: t( }- @  j1161538 CONCEPT_HDL    CORE             Espice model value edited in DE HDL  & then netlisting done, but it doesnt changes the earlier assigned model in Allegro" ~" c1 r  J- ~% s( \
    7 A6 k1 r2 {- C3 E8 @
    1161636 ALLEGRO_EDITOR DRAFTING         need new function for PDFout : hatching shape
    % s7 X1 P' B  X
    $ k( {3 ^1 G2 T0 l0 N& m! ~1161777 ALLEGRO_EDITOR OTHER            default line width for PDF output
    1 v  @8 ~9 h  B0 W4 @2 g
    : r  L4 Z2 i  {2 j1162383 CONCEPT_HDL    CHECKPLUS        Checkplus not using $CDS_SITE/custom_help and $CDS_SITE/custom_rules_include directories.- F, L3 e2 |) m4 M  v' {
    5 [8 \% y: q  R7 \. Z$ {$ _  o: k* K
    1162562 CAPTURE        STABILITY        Capture crash on second attempt of Pspice netlist creation in 16.6% H9 A) z$ U' Z/ q: h( m8 \6 `
      d8 @4 O8 {' Y) W9 Y1162629 FSP            PROCESS          "Load Process Option" under Run does not work properly
    $ x) e" O. M$ J0 @/ z3 z0 ^$ {+ L/ W8 _7 P
    1162686 CONCEPT_HDL    CORE             Changing NET_SPACING_TYPE to display both shows up with $NET_SPACING_TYPE
    ' L! d$ o* o$ Q' |
    " j" `& P7 Q$ f7 o4 i1 Y1163149 ALLEGRO_EDITOR DATABASE         Autosilk creates Illegal arc to corrupt database
    - F0 e: u9 R) Y
    2 j* |; I1 _( _9 h% X1163439 ALLEGRO_EDITOR COLOR            Duplicate Views Listed in Visibility Tab.4 x/ K. b* g4 ^( C+ ]; G
    ; |- T; ~8 i3 G7 k1163521 CONCEPT_HDL    COMP_BROWSER     System Architect crahes on replace
    , \  t& Q6 w. |3 ?: ?4 ^, z2 L- X( i' H
    1163709 CONCEPT_HDL    CONSTRAINT_MGR   Loosing Diffpairs when reimport block or restore from definitioin
    ' b% L# C8 g$ Q# C3 z, V; W
    1 U2 R1 N6 B0 T  I7 U0 a0 D1163902 APD            EXPORT_DATA      Q- In APD > File - Export - Board Level Component, check otion of delay reports is not working, is it ?
    7 |: g5 p  X1 f4 o) Z( t) Z8 {
    4 O5 q6 ^' j, _& ?: b" i1164337 CONCEPT_HDL    CORE             Cannot delete attribute filter value in PDF > General > Attribute Filter list
    & Q! y4 A0 U# q$ i  M9 `3 C& S( X9 p
    ( m% v8 O1 I7 f& a3 ^1164365 ALLEGRO_EDITOR INTERACTIV       Symbol not selected for Move because Symbol Pin number selected in options tab not available on symbol( \' v3 y" s) m: P5 u
    / f& m2 c, f7 ?8 q- H1164769 APD            VIA_STRUCTURE    The replace via structure command does not accept a single canvas pick.' r7 c# _& C, w8 c+ |7 W+ m  Q# G
    " j% s  [6 T9 [$ F* g! q  n* p
    1165026 ASI_SI         GUI              EMS3D exist in Via Model Setup of SI base.. V3 r0 S" B- T1 j2 h. b1 \
    : d: b7 M1 M. ?* j" p1165561 CAPTURE        DRC              File > Check and Save clears waived DRCs
    5 L$ I) y+ I! F& I# _. a
    + Q" E9 ^% p) ?1165631 CAPTURE        STABILITY        Capture crash in the hierarchy tab of Project Manager window& R0 r6 E6 E3 @0 ]- G
    # ?, i" G" a( f7 q6 D
    1165836 SIG_INTEGRITY  GEOMETRY_EXTRACT Some nets has no result at Bus Simulation and Comprehensive simulation.(update)# L+ z/ S. T6 \# f
    5 \% z0 g& L0 O6 s! i
    1165911 FSP            PROCESS          Editing group name in protocol causes incorrect Process option checked
    ' V# \' N5 S9 W3 b( e& u9 N: O1 \) P6 V( t% i' p: `
    1166026 ALLEGRO_EDITOR DATABASE         Running DB Doctor removes net name from vias
    6 a  r5 B4 x) u5 i& L1 f" c  U6 m' d+ f' w9 W& H
    1166034 SIP_LAYOUT     OTHER            SiP - Cline Change Width command enhanced to have selection by polygon not just rectangle
    6 Y4 R' H; M2 G3 a& l/ Y- ?. \, u4 B6 ~9 n0 y- g6 L
    1166074 GRE            CORE             GRE crashes during planning phases
    & z6 j. l& N  p: u" N0 O: ]3 f
    8 K, A9 \2 }) b% F0 u1166319 ALLEGRO_EDITOR PLACEMENT        Swap not succeed
    & m% T9 P7 D  a4 `" D/ E8 a# [( d0 u1 f8 B# B5 b
    1166484 SIP_LAYOUT     WIREBOND         Bondfinger "Align With Wire" problem during move
    & j' i/ O! S) z* I1 u  y; n: m8 e9 R# s/ L2 ?
    1166530 ALLEGRO_EDITOR INTERACTIV       Bug: Mirror in Placement Edit resets the options tab for Edit > Move
    ' L# u2 j$ i; C" i
    ) N7 L- I2 d7 D/ \7 R  a0 M1166819 CONCEPT_HDL    CORE             Cadence DEHDL Text Size Issue
    $ p2 I4 U5 t; l: b' d( F5 G2 X* J3 b
    2 }* ]& w2 X9 K( B* L# h1167847 CAPTURE        PROPERTY_EDITOR  Implementation name length greater than 31 character causes capture crash0 H7 y1 f$ |+ I3 ~' A, k, C
    * I2 K2 f& A; m: n- Y$ w) }' ^
    1167887 F2B            OTHER            Improve message on symbol to schematic generation
    4 r: F' z  U( L' [6 h4 Y
    + j3 J5 d- Z/ J' S& j$ C% f$ Z! k1168369 F2B            DESIGNVARI       Variant don縯 appear in increasing order while Annotate.
    & ]+ `9 \1 K: a2 F* `% R5 w4 q2 `
    ' L0 K/ @! o" q5 y# s" D% F" O1168629 APD            OTHER            Do we have Skill command which is equivilant to Change Characteristics operation of a Wire Bond in APD; Z, ^  A, M/ [6 |% j, Z
    % h0 g+ k) W5 d
    1168678 ALLEGRO_EDITOR NC               Drill Figure will be changed wrong layer when some subclass was deleted in SPB165S045.
    * K$ H- w) o2 |3 {5 b
    0 m# H* h) p5 r( J4 I& h1168798 ALLEGRO_EDITOR INTERACTIV       Enh - Allow user the ability to set the visibiity layer of refdes while moving the symbol rather than fixing it to silk/ o5 D5 f6 K3 q7 V/ D/ O
    , o) @5 P6 G9 W" z: s1168830 ALLEGRO_EDITOR DRC_CONSTR       missing DRC-marker for package to package check- B" D4 F- v0 @% n
    . @8 M  d! a, n. b; X9 ~6 w% x% l! n1168864 ALLEGRO_EDITOR CREATE_SYM       Saving the dra after Shape Expand/Contract throws warning 'Sector Table is not empty3 M% p# K4 |0 s1 g: r
    4 V2 ?  O* d$ n5 ]4 s2 M1169213 PSPICE         SIMULATOR        Parametric sweep is giving incorrect reuslts% Y/ F: F! d3 M  R' H3 B  W
    . n1 ?, k' Y3 N8 c7 j
    1169436 FSP            FPGA_SUPPORT     Add support for Cyclone V CSX and CST parts( D& r' A" y7 w0 j1 [
    9 t' C6 v* T$ s
    1170108 ALLEGRO_EDITOR INTERACTIV       Enhancement to preserve Rat T location for Topology assigned schedule. K  f1 c7 C+ B
    $ R; a, |; S( f3 X1 a( G) o  `
    1170313 SIP_LAYOUT     LOGIC            scm adding additional pin names and unassigned property to codesign die chips file& I* s4 u# P+ s  S- J: x. u* p; Q
    9 f/ u2 c0 m5 w3 y0 j: |1171136 CONCEPT_HDL    CORE             Page Number should also be displayed in Import Design Window.5 g+ }/ J8 |7 o* P7 t* Z
    ; f, F. D- H- S7 B& ~1171747 ALLEGRO_EDITOR PLACEMENT        Allegro crashes when doing a gate swap between components/ ~4 P# `- u: X! P
    0 C6 b0 l0 [; O
    1172183 ALLEGRO_EDITOR INTERACTIV       Alignment modules fails on equal spacing$ b! V, T, n. Z# r% L" F8 Z/ s
    0 w8 I. s% b" _1 k8 V1173183 ALLEGRO_EDITOR DRC_CONSTR       Undesired Same net DRC for overlapping Pin and Via
    + E$ f& ?2 M( u# }
    1 q/ Q3 f1 W" b# J2 Q# f$ @1174067 ALLEGRO_EDITOR DRC_CONSTR       Soldermask to shape drc does not show if the layer is a PLANE.! E$ Y" z/ \  b( T7 E3 Y
    ) F' C  Z9 a5 t* L# X8 v2 E
    1174338 ALLEGRO_EDITOR PLACEMENT        preview has rotated pads
    " n* k. v; e, V0 m
    : x6 |! L4 W! l  {- ^5 D# x) |1175307 CONSTRAINT_MGR ANALYSIS         CMGR fails to report RPD DRC for accuracy 4 - mm* [/ ~) I1 A5 c1 ~! I: G5 @
      i1 Z" @$ p% p( p1175537 ALLEGRO_EDITOR REPORTS          net loop report crashes Allegro. Design specific( p' e" [) W4 W. r: w
    * r- O/ _; \0 Q% e8 U1176126 ALLEGRO_EDITOR INTERFACES       3D viewer doesnot change models units dynamically  ~3 y2 S2 B: A6 W+ s/ `
    : w, N- u& q% m$ p7 u$ [6 S1176281 CONCEPT_HDL    CORE             Option to Auto-hide excluded modules7 V9 s, l! ^, o- l/ _! e& g4 i/ i0 |
    / v- J$ C5 o7 a4 }: X8 o1176413 ALLEGRO_EDITOR MANUFACT         Q - testprep parameter settings is not retained, what could be the cause..
    % p% O3 S2 S! T  ^. @6 D- D8 A* D, ]2 ?5 w/ t
    1176791 ALLEGRO_EDITOR GRAPHICS         Spurious odd lines are shown in shapes and text that are not part of the design with opengl
    7 u4 {7 w8 e- x
    ) P1 E1 U$ R0 p2 U* N; u9 c6 N, B3 y1178052 ALLEGRO_EDITOR SHAPE            SIP crashes during shape degassing.
    7 x) k! y; t/ j8 r% d
    0 M! n4 }8 C( z1 z2 t1178158 ALLEGRO_EDITOR INTERFACES       Export step file creates step file of same height$ {! i6 M; Y* h& E; i1 c0 b7 s6 u
    8 N# }, H/ u& L- |1178201 ALLEGRO_EDITOR GRAPHICS         Large oval pads rendered as oblong hexagons in the 3D viewer/ ?# \4 L0 P3 [3 W
    2 s0 |. M  ~( U5 w2 f1178671 ALLEGRO_EDITOR GRAPHICS         3D Viewer in package symbol editor not displaying correct place bound shapes.
    2 s% L1 L) T+ `" {" t) G
      a* r2 @' c7 ^/ g( U8 S- Q# e1178725 ALLEGRO_EDITOR OTHER            With fillets present, rat lines do not point to the closest endpoint.
    , y1 s) C# W+ L3 h& L7 ^9 y
    6 b/ q0 o. u! X2 M) Y" R1178972 CONSTRAINT_MGR ANALYSIS         The Cross-Section's parameters was not applied immediately after importing a DCF on the Constraint Manager.: r/ v/ o9 I" M5 `! j
    " ^+ |" b2 `8 |$ j# |8 d
    1179093 ALLEGRO_EDITOR SHAPE            Dynamic Shape for GROUND net on TOP Layer is corrupted and is not voiding correctly in certain areas.
    7 k, o) P) J  V8 e4 Z4 H' m, P+ R. ~+ q1 h
    1179109 ALLEGRO_EDITOR OTHER            DXF importing makes figure shift in 16.5&16.6 version it is ok in 16.3 version: M1 v0 y) w, p$ H' Z  n+ a9 v
    % [4 W! }# ~" Y
    1179571 ALLEGRO_EDITOR ARTWORK          Artwork crash and artwork log report Aparture missing
    . ~2 z3 p1 a; L( t3 |, M- Z6 ]
    ) Q3 ~6 e' R. z# V1179636 SPECCTRA       ROUTE            Route Automatic will not start if NET_SHORT are attached to a mec-pin; F( F0 `  T& C- Z- s+ ?" z
    2 M+ P7 Z! i* _8 Q7 `  k  u! ~1 W6 r
    1179659 SIP_LAYOUT     DIE_EDITOR       die edit on co-design die losing c4 bumps
    & b$ I- e& X% h' ]2 ^/ P* A8 `
    ; d1 Z" x; \0 P1180306 ALLEGRO_EDITOR ARTWORK          When trying to create Artwork the tool crashes with no error messages just a little X box
    : O( ^# F' T2 N3 Q- A0 g( E" L1 E9 p) }
    1180573 ALLEGRO_EDITOR ARTWORK          If one layer has warning, all artwork films are "created with warning".
    " Z5 o9 t. h! y' |! h' f
    6 J. q7 j" B  M% J& [1180960 SIP_LAYOUT     PLACEMENT        swap function is not swapping logical paths in sip layout!- X& F9 Z& v! T8 _9 w
    + c( R! R9 Z6 x4 v6 \- i, D( `  e
    1182534 ALLEGRO_EDITOR SKILL            axlLayerPrioritySet() not working with v166 s013 and up5 V6 _0 T. Y- a3 F* m  c  ?& w
    1 F' C& Z  n9 {! r. U1182560 ALLEGRO_EDITOR PLOTTING         Creating plot 2nd time casues Allegro to crash
    , v4 ]! U8 a" @/ h/ ]& K" ^* p' h! U. ?# P: I  V; k3 I
    1182616 ALLEGRO_EDITOR PLACEMENT        Application crashes when attempting to place a high pin count BGA
    3 y( {3 k9 p5 H( i" }+ p2 o% c& _( s* Y3 F/ t1 i: h
    1183752 CONCEPT_HDL    CORE             Unable to modify location properties within a read-only hierarchical block! b" p' w/ ~  m
    6 ?( H$ I% J2 D. T1183774 SIP_LAYOUT     DIE_EDITOR       Die Refresh hangs5 Z" q4 ]7 \! [6 M. m
    / l+ Y4 o) ^2 |% m1 C- s2 Z) W5 J
    1184178 CONCEPT_HDL    CONSTRAINT_MGR   Ecset xnet members lost from electrical class when restore from definition of  subblocks) h2 O# o  |* S( H" A$ c2 a( c. H
    0 Y  @$ s  q5 W* K/ V8 Q1184787 ALLEGRO_EDITOR EDIT_ETCH        Allegro SPB166 s 015 crashes during normal add connect function.
    8 u. S- T" |: }* K/ ?- c5 ^* H# }- [/ R2 M8 `
    / a' h. k# U4 {
    Cadence SPB OrCAD 16.60.016 Hotfix! y3 _; ~) `1 e3 U( P/ I
    / l8 Z) _/ _/ t
    Download uploaded6 l) o5 ^) t( _7 b
    http://uploaded.net/file/lo9hy18c/ceenS1660016fi.rar/ |/ c8 L" h% w; }; {
    9 h+ S- i' j" z8 JDownload filefactory! O* g" y; ]# J7 s7 o: K
    http://www.filefactory.com/file/6t9yiqdubs8t/n/ceenS1660016fi.rar
    1 w; k1 K- n- o" \8 i0 F* Y2 M8 K+ d. [3 G8 s3 P: M& I3 n$ `
    Download 城通网盘$ ^1 y& m3 o7 t% o4 b3 q2 v* H& R% C
    http://www.400gb.com/file/31016333
    / l1 g2 p: A5 q: T) o9 h  w% q0 {# G
    5 O8 ~6 M9 ]; @% }; o% X: DDownload 百度云
    1 f% Q: b$ e& ]% j! {http://pan.baidu.com/s/1n9yPG" m% ]0 y1 s4 c0 @
    推荐
    发表于 2013-10-9 10:13 | 只看该作者
    谢谢,请问下有没有打补丁 的方法??
    发表于 2013-10-6 21:22 | 只看该作者
    长假回来就给力了 谢谢了!!!
    发表于 2013-10-9 14:25 | 只看该作者
    前几个补丁跳过了,这次看bug fix,修正了很多,也增强了很多功能,特别是step方面,测试一下,多谢分享!
    发表于 2013-10-11 10:06 | 只看该作者
    谢谢楼主分享!!!
    GMT+8, 2025-11-5 12:23 , Processed in 0.140625 second(s), 24 queries , Gzip On.
