查看: 4156|回复: 23
Cadence SPB OrCAD 16.50.047 Hotfix 升级补丁
    2025-11-3 15:00
  • 签到天数: 723 天
    [LV.9]以坛为家II
    发表于 2013-9-11 09:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    本帖最后由 紫菁 于 2017-9-14 14:13 编辑   O! }. ?0 Q& q
    # x; m0 \* ^, V( L- v* z+ H8 j( \
    cadence SPB orcad 16.5 最新的升级补丁,版本号16.50.47,修正内容如下:
    . @( B% k' N$ d8 g+ }3 y7 [6 |! N% I% J/ C. T
    DATE: 09-6-2013 HOTFIX VERSION: 047
    : g( D5 i9 @: R* |, JCCRID PRODUCT PRODUCTLEVEL2 TITLE' m3 C# j( c6 d
    : [$ Q; L0 V1 z0 U  h8 E4 O2 E1095533 concept_HDL CORE changing visibility for $PNN results in crash in windows mode
    * B/ k, |5 T8 y# U/ z1153813 CONCEPT_HDL CORE Spaces should not be allowed in the signal name entry form
    % x- i' A1 i/ g9 e) k1156102 PCB_LIBRARIAN CORE PDV severe peRFormance degradation on Linux platform makes PDV counter productive after some time" s( y6 Z* J  p: B. |) w
    1161781 CONSTRAINT_MGR CONCEPT_HDL SigXp crash when selecting ECset in design
    + i  Z0 ^( c2 s- I1 V  K1163709 CONCEPT_HDL CONSTRAINT_MGR Loosing Diffpairs when reimport block or restore from definitioin* E9 h3 c% \" |; |3 |
    1167887 F2B OTHER Improve message on symbol to schematic generation, K: L; \6 j( j$ M
    1168496 allegro_EDITOR SCHEM_FTB Export Physical Crashes when netreving the board
    , }% N# }0 B* p6 z1 W1168830 ALLEGRO_EDITOR DRC_CONSTR missing DRC-marker for package to package check
    ) ?2 \* S9 e* A1169593 CONCEPT_HDL PDF Published PDF file\'s hyperlinks do not work fine when user click 1D10 or 2A10.
    & _7 K% L9 i  G2 y! r0 ?( L) u1169984 F2B PACKAGERXL Error Mapping cset when packaging but not in CM Audit0 F$ K# i4 S# {
    1171136 CONCEPT_HDL CORE Page Number should also be displayed in Import Design Window.) F, T+ S9 s8 I8 T/ I
    1172597 ALLEGRO_EDITOR DATABASE Board cannot be unlocked using Password used while locking
    5 N1 I) O/ Z# a/ }, i# z1172938 ALLEGRO_EDITOR PLOTTING Export IPF probrem
    : c% E. n6 X+ t/ Q) f8 j: R1173183 ALLEGRO_EDITOR DRC_CONSTR Undesired Same net DRC for overlapping Pin and Via" _9 A6 V2 [! m+ U; G8 B: W
    1173829 ALLEGRO_EDITOR MANUFACT Backdrill completes even though a stub exceeds the MAX_PTH_STUB value; z. d. w& r9 x8 L+ x+ l
    1178972 CONSTRAINT_MGR ANALYSIS The Cross-Section\'s parameters was not applied immediately after importing a DCF on the Constraint Manager.
    ! h$ `( R, o. `6 ~" L; v4 p# k% r. w7 L' ~( B
    ! a" z/ P) m6 W. n
    游客,如果您要查看本帖隐藏内容请回复
      ?( C2 R/ s2 d. ~' f3 o
    ' i) v2 [) |' d9 C
    2021-11-13 15:29
    推荐
    发表于 2016-12-13 13:17 | 只看该作者
    对不起,这个文件已经过期或共享已失效,文件不能下载。如有疑问请咨询客服。
    推荐
    发表于 2016-1-5 10:55 | 只看该作者
    请问升级补丁具体应该怎么操作?为什么我的升级后软件不能使用了呢?
    推荐
    发表于 2013-9-11 12:42 | 只看该作者
    更新有点快,楼主出手也很快,谢谢
    奋斗
    2019-12-11 15:50
    发表于 2013-9-11 10:36 | 只看该作者
    46才装上,这么快就47了。
    2021-7-21 15:48
  • 签到天数: 51 天
    [LV.5]常住居民I
    发表于 2013-9-24 11:21 | 只看该作者
    这个要顶!谢谢楼主分享!
    2021-1-26 15:48
    发表于 2013-9-25 08:00 | 只看该作者
    这个要顶!谢谢楼主分享!
    郁闷
    2021-6-24 15:21
  • 签到天数: 24 天
    [LV.4]偶尔看看III
    发表于 2013-10-12 11:10 | 只看该作者
    谢谢楼主分享
    发表于 2017-11-8 15:21 | 只看该作者
    求补丁连接
    ) k# s1 P  ~2 Q' j3 ?  _1 l4 t* r
    13#
    发表于 2017-11-15 10:52 | 只看该作者
    遇到困难了,下载试试能解决否  e4 r# V/ L# w' w! W
    GMT+8, 2025-11-4 08:47 , Processed in 0.156250 second(s), 26 queries , Gzip On.
