查看: 3592|回复: 27
Cadence16.6 HOTFIX VERSION: 015 (15号补丁)
发表于 2013-8-25 13:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DATE: 08-22-2013   HOTFIX VERSION: 015
! N: T8 q" @  @; ^$ @+ H% i===================================================================================================================================# u4 J3 k; p: v+ ^( i8 h
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
/ m% L! X, Q# R( @6 B2 u+ |% M6 t===================================================================================================================================
; k- E% X! d" y# C1156102 PCB_LIBRARIAN  CORE             PDV severe peRFormance degradation on Linux platform makes PDV counter productive after some time
" z: h8 U0 Y; ?% n1165756 concept_HDL    CORE             DE HDL 16.6 adding ASCII character to properties
- E! b: W( T2 p" `- r1169896 ADW            LRM              Library Revision Manager makes updates but the interface never returns to the user
* X2 O$ M* g: P! f1170635 SIP_LAYOUT     WIZARDS          BGA PIN NAME doesn't sync with PIN Number3 Z$ }- }# ]" S+ K: @
1171061 allegro_EDITOR PLACEMENT        Place Replicate Apply cannot place module
# \8 z* p  N/ A; M5 p* q1171415 CONCEPT_HDL    CORE             Mismatch in the interface ports in design bw_hybrid for block a38410_scsp# `  v8 M  H" m0 d" t) J5 j5 b
1171598 APD            WIREBOND         Cannot load xml over 65 profiles defined in file.
; W  S% g0 m( m- Y1 Q2 z4 L1171713 ADW            LRM              Blank lines appear in the LRM - RM-Clicking causes LRM to crash7 A- B$ N* P$ f; l( j; X
1172576 SIP_LAYOUT     IMPORT_DATA      AIF import fails with Error: symbol is missing refdes
# I3 L7 w& j! U8 s! s: w' U1172938 ALLEGRO_EDITOR PLOTTING         Export IPF probrem+ L& E5 X5 F" `
1173190 ALLEGRO_EDITOR ARTWORK          Not able to Add/ Replace film_setup.txt file in Artwork control file.
# p1 W0 ~: k2 S# s! F3 F0 `2 ?, p1173750 ALLEGRO_EDITOR REPORTS          SIP tool crash when clicking report "Net Loop Report"' l: Q$ I+ r9 N- I2 [9 h
1175582 ALLEGRO_EDITOR skill            axlDBCreateFilmRec error undifined function3 t1 l+ H7 a$ M; a0 S/ o
( E0 Q% e3 @) L; @- phttp://pan.baidu.com/share/link? ... 1&uk=3826038294  K& K; b, g4 P" h0 E8 R
8 x* L! c% G' `! c4 z7 I0 {5 B7 {# a, d
推荐
发表于 2013-8-28 08:31 | 只看该作者
对我现在试用的工具基本没影响,暂时不更新了,太频繁了。
推荐
发表于 2013-8-26 09:56 | 只看该作者
太没节操了,还是等到出到20号补丁的时候再重新装
    2019-11-20 15:24
    推荐
    发表于 2013-8-25 21:18 | 只看该作者
    才刚升级不久,又来新的了,这速度也猛了。谢谢分享
    发表于 2013-8-25 13:57 | 只看该作者
    擦 太快了吧
    发表于 2013-8-25 14:05 | 只看该作者
    Thanks a lot.
    发表于 2013-8-25 16:53 | 只看该作者
    好快就出来了!感谢!
    发表于 2013-8-25 19:44 | 只看该作者
    谢谢您的分享啊
    2026-5-4 15:02
  • 签到天数: 807 天
    [LV.10]以坛为家III
    发表于 2013-8-25 20:32 | 只看该作者
    这个给力,非常好。楼主辛苦了。
    发表于 2013-8-25 20:54 | 只看该作者
    有哪位大哥在windows8系统上装16.6的成功了没?
    16.6兼容win8,运行流畅 ,表示毫无压力!  发表于 2013-8-26 09:14
    发表于 2013-8-26 07:36 | 只看该作者
    擦 太快了吧
    发表于 2013-8-26 09:29 | 只看该作者
    这速度,我和我的小伙伴们都惊呆了
    发表于 2013-8-26 09:32 | 只看该作者
    补丁太快了  看看有没有改进
    15#
    发表于 2013-8-26 15:40 | 只看该作者
    等着吧  看16.5的补丁都出到287 D) \! j1 }! l: g" y4 }
    GMT+8, 2026-5-7 19:25 , Processed in 0.187500 second(s), 30 queries , Gzip On.
