查看: 2391|回复: 13
Cadence Hotfix_SPB16.60.014_wint_1of1(14号补丁)
发表于 2013-8-14 18:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
0 U  b  @& l; x
http://pan.baidu.com/share/link? ... 5&uk=3826038294
( d5 L5 @/ B1 E9 z5 w
" t* F- e$ w8 D& |6 D; I0 b2 qDATE: 08-9-2013    HOTFIX VERSION: 014===================================================================================================================================CCRID   PRODUCT        PRODUCTLEVEL2   TITLE===================================================================================================================================1155569 APD            MODULES          P1_U1 and P1_U3 Die pins are missing after Place Module.1158528 concept_HDL    OTHER            Dual Monitor issue: Retain Hard Packaging option is missing and attribute test distorted1160968 allegro_EDITOR skill            Text Subclass change difference in Edit > Change and axlChangeLayer Skill command1161986 SIG_INTEGRITY  SIMULATION       Flatline waveform seen when via model is set to detailed closed form or analytical solution1162323 SIP_LAYOUT     DIE_EDITOR       Die Editor is incorrectly leaving an unassigned function pin in the die during refresh from die abstract1162752 ALLEGRO_EDITOR SKILL            axlDBChangeText doesnt recognize ?layer as a valid argument as documented1165002 GRE            CORE             GRE Crashes during Plan Spatial giving "Memory Allocation Failure" Error.1165469 CONCEPT_HDL    CORE             Import Design loses design library name1165708 ALLEGRO_EDITOR TESTPREP         Test point router failing when attempting to insert new TP via's1165801 CONCEPT_HDL    PDF              Pin texts of spun symbol overlap in publish PDF.1166020 SIP_LAYOUT     WIREBOND         Bondpads created with shapes do not follow the orthogonal pattern when adding wirebonds.1166371 ALLEGRO_EDITOR DATABASE         File locked for writing in 16.5 cannot be unlocked in 16.61166482 ALLEGRO_EDITOR INTERFACES       Step orientation for y-rotated component is not exported correctly.1167519 ALLEGRO_EDITOR DATABASE         Uprev dbdoctor does not log warnings about renaming properties.1167588 SIP_LAYOUT     DIE_ABSTRACT_IF  do not create a new pad stack for each I/O pad1168496 ALLEGRO_EDITOR SCHEM_FTB        Export Physical Crashes when netreving the board1169510 SIP_LAYOUT     WIZARDS          Netlist in Wizard is crashing with this text file where the Net Name for one of the assignments is blank, meaning dummy1169593 CONCEPT_HDL    PDF              Published PDF file's hyperlinks do not work fine when user click 1D10 or 2A10.1169984 F2B            PACKAGERXL       Error Mapping cset when packaging but not in CM Audit1171008 SIP_LAYOUT     OTHER            SiP Layout - Beta feature Void Adjacent Layer Shapes - changes or modifies "priority" of other/all shapes1171411 ALLEGRO_EDITOR OTHER            Enh - Break in Step 3D view in latest hotfix v16.6s013
发表于 2013-8-14 18:55 | 只看该作者
楼主真是好人啊,强悍!
发表于 2013-8-14 19:38 | 只看该作者
谢谢您的分享
    奋斗
    2023-2-7 15:02
  • 签到天数: 206 天
    [LV.7]常住居民III
    发表于 2013-8-14 21:02 | 只看该作者
    更新的也太快了
    2021-10-7 15:18
    发表于 2013-8-14 21:11 | 只看该作者
    谢谢lz分享!
    发表于 2013-8-14 22:14 | 只看该作者
    我12点发的被删了,不知道为什么。还好,还能下载!谢谢!
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2013-8-15 09:16 | 只看该作者
    這一次更新來的好快,
    * E  L# c: ?2 T2 [9 L0 G) r7 t感謝大大的分享了..
    发表于 2013-8-15 09:22 | 只看该作者
    谢谢分享!
    发表于 2013-8-15 09:24 | 只看该作者
    Scott.Dong 发表于 2013-8-14 22:14
    9 [, c3 [9 d6 ]' a- r; T1 P! j2 u我12点发的被删了,不知道为什么。还好,还能下载!谢谢!
    - p3 `$ \/ R# |$ l好像只有特定的人才能发下载,我原来也发过下载链接,同样是无理由被删。
    发表于 2013-8-15 10:00 | 只看该作者
    太感谢了啊
    发表于 2013-8-15 10:19 | 只看该作者
    多谢
    发表于 2013-8-15 10:47 | 只看该作者
    谢谢分享
    13#
    发表于 2013-8-15 14:50 | 只看该作者
    谢谢楼主!
    14#
    发表于 2013-8-15 15:48 | 只看该作者
    candence 16.6?
    GMT+8, 2026-5-7 20:22 , Processed in 0.171875 second(s), 23 queries , Gzip On.
