cadence SPB16.6下载(Hotfix013已发布)
6 C2 b T/ p8 E1 ]" R$ L, i. {
]/ K5 g% h: g, P+ ]$ n! ~Cadence SPB16.6已经推出,需要的朋友可以点击下面的链接下载:" l) m8 n# R$ o/ w9 P; D
http://dl.vmall.com/c0ych9k8m3
3 B. K* `9 H4 W! f( \% w, ~+ M: F6 T8 c2 c) t5 e( J
DATE: 07-26-2013 HOTFIX VERSION: 013% ]0 g) m: @5 I$ x8 T# D
# ?! R0 n7 c2 p3 x# pCCRID PRODUCT PRODUCTLEVEL2 TITLE d' Z7 }' ~1 P5 b' T, S! e
3 B* _% I: D8 ^' i" W% {111368 CAPTURE CORRUPT_DESIGN Capture - will not produce allegro netlistwith 10.0, M+ s. t3 @( o' D% G; Y8 n) v6 ?
134439 PD-COMPILE USERDATA caCell terminals should be top-levelterminals
9 T9 f$ `9 B6 }% S: a186074 CIS EXPLORER refresh symbols from lib requires youto close CIS
- b2 R2 X9 Y6 M8 C5 X9 G4 V0 S583221 CAPTURE SCHEMATIC_EDITOROption to have the Schematic Page Name as a Property in the Titleblock, w, l; v% K3 a
591140 concept_HDL OTHER Scale overall output size inPublishPDF from command line
$ S2 w# T$ ^7 ~+ X+ N: o; I' L801901 CONCEPT_HDL CORE Concept Menus use the same key"R" for the Wire and RF-PCB menus# U0 W E1 b4 d% i' l7 `/ |
813614 APD DRC_CONSTRAINTS With Fillets present the "cline toshape" spacing is wrong.4 f5 h' w* n; I, z
881796 ALLEGRO_EDITOR GRAPHICS Enhancement request for Panning with Middle Mouse Button
2 D7 y% {- v9 ]1 e# y' ?8 t( i- a887191 CONCEPT_HDL CORE Cannot add/edit the locked property
9 O$ m$ H$ F! L/ ~' y0 C; [, a$ o911292 CONCEPT_HDL CORE Property command on editing symbolattaches property to ORIGIN immediately) w/ U v5 q& H: q' c4 i
987766 APD SHAPE Void all command gets result as novoids being generated on specific env.
; p& _ c4 E- b! e; O2 \3 G1001395 SIP_LAYOUT ASSY_RULE_CHECK Shape Minimumvoid check reports lots of DRCs which are not necessary to check out.
9 O+ B1 t( o [/ D/ P( s" H$ {1030696 ALLEGRO_EDITOR INTERACTIV Enh - Allow another behavior of PANmovement using middle mouse in Allegro, W) _' G$ o! y: p" g
1043856 ADW TDA Diff between TDOand DE-HDL Hierarchy Viewer is confusing to the user
8 w+ s8 y& c8 X K8 N1046440 ADW PCBCACHE ADW: ImportSheetis not caching libraries under flatlib/model_sym when the source design is notan ADW project2 a& C- Y; O7 Q
1077552 F2B PACKAGERXL Diff Pairs get removed when packing withbackannotation turned on
, D3 r9 c: k1 T1079538 F2B PACKAGERXL Ability to blockall 縮ingle noded nets� to the board while packaging.6 s; j% e8 r: X" W- M/ A# r
1086362 ALLEGRO_EDITOR SHAPE Enhancement request to autovoid a viaif shape cannot cover the center of the via./ d% ^, M# d9 |2 |( C. N8 m
1087958 Pspice MODELEDITOR Is there anylimitation for pin name definition?0 @0 v; u6 R+ L. K5 j! Z
1087967 CIS UPDATE_PART_STAT Update part status window shows incorrect differences
- L, v6 g3 j/ S- J# {1090693 ADW LRM LRMauto_load_instances does not gray out Load instances Button+ N' M! c0 h& ` D5 E# S
1097246 CONCEPT_HDL CORE ConceptHDL -assign hotkeys to alpha-numerical keys
$ O2 o. d/ H$ F: ^% N' X, g5 I1099773 CONCEPT_HDL CORE DE HDL goes intorecursive loop if a custom text locked at site level is deleted from Tools >Option
0 Z: \0 Z- h) T9 d2 q1100945 SCM SCHGEN SCM generatedDE-HDL has $PN placement issue0 ~2 Y1 y# ^* f* E) p
1100951 PSPICE SIMULATOR Increasing theresolution of fourier transform results in out file: J( F" H k8 k R ^ D0 {
1103117 RF_PCB FE_IFF_IMPORT Enh- Allow theAllegro_Discrete_Library_to_ADS_Library_Translator to output in its originalunit
1 T" x1 Z2 K1 Z+ Z' Z6 O1105473 PSPICE PROBE Getting errormessages while running bias point analysis.
2 R2 G/ @% k u: o! R1106116 FLOWS PROJMGR view_pcb settingchange was cleared by switching Flows in projmgr.0 C8 X! a+ v: @* H4 H7 j
1106298 ALLEGRO_EDITOR INTERACTIV Copy Shape uses last menu pick locationas origin and not the Symbol Origin as specified in Options.( [ |9 k6 n* P& K2 G! R/ }2 G
1106626 CONCEPT_HDL CORE Concept HDL crashes when saving pages/ r) v7 C5 g. z, i8 ~* E+ m r
1107086 ALLEGRO_EDITOR INTERACTIV manual void with arc's goes in wrongdirection during arc creation
) K' T0 E& V T9 W' |+ A- g1107172 CONCEPT_HDL OTHER Project ManagerPackager does not report errors on missing symbol
/ h! P, \* V7 v, L' V1108193 CONCEPT_HDL CORE Using theleft/right keys do not move the cursor within the text you're editing: M1 {" y+ \" `; _" j6 g6 r
1108603 PCB_LIBRARIAN VERIFICATION PDV ToolsVerification > View Verification (CheckPlus) leaves<project>.cpm_tmp.cpm
* g/ I6 o5 `: U1109024 CIS OTHER orcad performance issue from Asus.
, {0 f" t" T8 G& _1109109 CAPTURE NETLIST_ALLEGRO B1: Netlistmissing pins when Pack_short property pins connected
- Y/ ?1 h* ^! h0 v" I1 ^3 _ [1109466 ALLEGRO_EDITOR ARTWORK Artwork create some strange gerberlines for fillet.
& o1 E( O6 Z1 i1109647 SIP_LAYOUT DEGASSING Shape degassingcommand enhancement - control over what layers are counted in even/odd layersets.
" H+ }# z6 M' Q, _8 `7 m0 v: v1109926 CONCEPT_HDL CORE viewing a designdisables console window+ \- \$ J6 ?! U0 r
1110194 SIP_LAYOUT WIREBOND If OpenGL settings for display ofdynamic net names is enabled, should be visible while push/shove wirebonds.
! v6 D9 l& Q/ a9 I( l( J' r$ |1112357 SIP_LAYOUT WIREBOND wirebond commandcrashes the application* V, y/ [ L9 A1 J0 J9 s
1112395 CONCEPT_HDL CORE 縗BASE\G� for global signal is not obeyedafter upreving the design to 1650." _& u- g8 g3 M1 D7 _ s- |
1112658 CAPTURE PROPERTY_EDITOR Changing Part 縂raphic� value from property EditorChanges Occ refdes values to instance4 N3 ?$ h& Y4 ?& X9 L
1112662 CAPTURE PROJECT_MANAGER Capture crashesafter moving the library file and then doing Edit> Cut; s" Z9 E/ B5 ?% u; b% ^* X
1113177 PCB_LIBRARIAN CORE Pin Shapes arenot getting imported properly0 ^' o( w4 R. V. k9 Y8 a5 M3 _
1113380 ALLEGRO_EDITOR INTERACTIV Change layer to - option for packagetype .dra is not available in 16.6 release
% K# e4 m1 U6 J- }* f1113656 SIP_LAYOUT WIREBOND Enable Changecharacteristic to work without unfixing its Tack point.! X$ ]6 o9 |1 n
1113838 SIP_LAYOUT DIE_ABSTRACT_IF probe pinsdefined in XDA die abstract file are added with wrong location% B: _& D' R# h% X9 A
1113991 CAPTURE GENERAL Save Project Asis not working if destination is a linux machine
$ @( B6 l( O; o. c4 K: T+ w6 W p1114073 APD DRC_CONSTRAINTS Shape voidingdifferently if there are Fillets present in the design.. W0 i* |7 D, z( E& ]% j
1114241 CAPTURE SCHEMATIC_EDITOR Port not retaining assigned color, when moved on theschematic. a c! H4 h+ K
1114442 PSPICE PROBE Getting Internalerror - Overflow Convert with marching waveform on! S4 s1 D- I, [4 o
1114630 CONCEPT_HDL ARCHIVER Archcore failsbecause the project directory on Linux has a space in the name
1 j* ~3 M, v4 {% t, l% B" |8 F# g3 v1114689 CONCEPT_HDL CORE Unknown projectdirective : text_editor, |" A8 T8 }8 W4 o1 r% O
1114928 F2B PACKAGERXL 縀rror (SPCODD - 5) while Export Physical even afterchange pin from A<0> to A
: X0 L" W$ ~" b+ ?" c4 C1116886 CONCEPT_HDL CORE Crefer hyperlinksdo not work fine when user use double digits partitions for page Border., C- F2 J. h, R
1118088 ALLEGRO_EDITOR EDIT_ETCH Should Plan accurate and Optimize beremoved in 16.6?
x# k3 n. m; ]* E3 C( a+ x. m1 P1118734 APD EDIT_ETCH Multiline routingwith Clines on Null Net cannot route in downward direction
. ~! @! f# D3 B% x) o y! W5 Q1118756 ALLEGRO_EDITOR SHAPE Shape clearance parameter oversizevalues getting applied to Keepouts% `2 P, x) K; \2 V( Z
1119606 CONCEPT_HDL MARKERS Filtering two ormore words in Filter dialog box
2 y; X$ x4 y2 a$ L& S l1119707 CONCEPT_HDL CORE Genview does not use site colors when gen schfrom block symbol& h& g; h9 [. ^" M; K! S7 L! y
1119711 F2B DESIGNSYNC DesignDifferences show Net Differences wrongly
( h$ J) G! _) n1120659 CAPTURE PROJECT_MANAGER "Saveproject as" does not support some of Nordic characters.
+ i; ~7 O$ [* x+ C1120660 CONCEPT_HDL CORE Save hierarchysaves pages for deleted blocks. h! A4 ?/ p i! S* d5 A* M' F) N
1120817 SIP_LAYOUT SYMB_EDIT_APPMOD Rotate pads commands not working while in the SymbolEdit App. mode0 }' T5 m Q8 R; ]) ~+ q
1120985 PSPICE MODELEDITOR Unable to importattached IBIS model# t( n, B) Q. H. X: z3 T$ K) v
1121171 CONCEPT_HDL CREFER PNN and correctproperty values not annotated on the Cref flat schematic; c* ]: }, s. G" O! \
1121353 ALLEGRO_EDITOR INTERACTIV Local env setting will change aftersaving and reopening.8 u- x) L) |/ g5 z) e. n& I
1121382 ALLEGRO_EDITOR INTERACTIV Undo command is limited to two for thisdesign% H( ?, v N8 L8 B* x2 E. s
1121540 F2B PACKAGERXL pxl.chg keepsdeleting and adding changes on subsequent packager runs
, c* K! \- r' M( J1121558 ALLEGRO_EDITOR MODULES Unrouted net and unrouted connectionwhen module is placed of completely routed board file.
% p" e, Z- v; Y3 }- F1121585 ALLEGRO_EDITOR OTHER Drill Hole to Shape Same NetSpacing with Dynamic Shapes shows wrong result.% J3 y j8 \' L1 p. L U3 i, W
1121651 CAPTURE SCHEMATIC_EDITOR "PCB editor select" menu option is missing: _; I: }/ v% v) k9 @0 B
1122136 SIP_LAYOUT PLACEMENT Moving acomponent results in the components outline going to bottom side of the design.% ]# D5 T0 n7 m/ E, P. a
1122340 CAPTURE NETLIST_ALLEGRO Cross probe ofnet within a bus makes Capture to hang.7 a" o7 h" N+ U/ W& L- C7 _( q
1122489 CONCEPT_HDL OTHER Save _Hierarchycausing baseline to brd files- p, R$ ?+ }9 B( J
1122781 CONCEPT_HDL CORE cfg_package isgenerated for component cell automatically
; u+ x( s6 p) P. u1 g1122909 CONCEPT_HDL CORE changing versionreplicates data of first TOC on 2nd one: \3 t; M) p4 x
1123150 CONCEPT_HDL CORE property on yaxis in symbol view was moved by visibility change to None.
! t; h; z- v- R0 O6 R1123176 ALLEGRO_EDITOR UI_FORMS Negative values for pop-up location isnot retained with multiple monitors (more than 2)- Y3 E, e) c) _" t1 c2 Z# N& e
1123815 ALLEGRO_EDITOR GRAPHICS Embedded netname changes to a differentnetname4 |1 x4 m* b7 G3 \, t3 ]
1124369 ALLEGRO_EDITOR INTERACTIV Sliding a shape using iy coordinate doesnot work indepedent of grid. Y6 y# u9 C4 q1 u. e. ]1 i( w
1124544 CONCEPT_HDL CORE About SearchHistory of find with SPB16.5
9 d7 R5 h0 D, y1 }2 K' ?1124570 APD IMPORT_DATA When importingStream adding the option to change the point
/ D% F6 S$ c# G9 C0 g1125201 CONCEPT_HDL CORE Connectivityedits in NEW block not saved( lost) if block is created using block add& g* i% ?5 V7 G" r
1125314 ALLEGRO_EDITOR INTERACTIV Enved crash during setting of library paths inuser preference
3 m" u. M$ o S9 Z; ? s1125366 CONCEPT_HDL CORE DE-HDL crachESDuring Import Physical if CM is open on Linux
5 Y7 p+ Z v t4 K' `& D" e1125628 CONCEPT_HDL CORE Crash on doingsave hierarchy; q& l' H% g! S) J
1130555 APD WIREBOND Wirebond Import should connect to pinsof the die specified on the UI.4 ^& I! h: J6 U F
1131030 PSPICE ENVIRONMENT Unregistered iconof Simulation setting in taskbar
7 G0 V0 u0 H* K' Q l$ V1131083 ALLEGRO_EDITOR INTERACTIV Bug: 16.6 crash in changing the mode inFind filter window2 Q: r; K4 M+ o( y4 O/ h- y
1131226 ALLEGRO_EDITOR PLACEMENT When Angle is set in design parameterswhile placement component is rotated but outline is not.
; U2 ~/ q* l3 t- P9 Q) J& w) u2 ~1131567 CONCEPT_HDL OTHER Lower case valuesfor VHDL_MODE make genview use pin location to determen direction.
. I! C7 ~4 G1 H. N" t1 k6 i8 ?1131699 PSPICE PROBE Probe windowcrash on trying to view simulation message0 I/ G. s# f* S
1132457 CONCEPT_HDL CORE The schematicnever fully invokes and has connectivity errors.
$ }. ]- \2 N" W" b+ D$ A: T3 q0 E/ r1132575 CONCEPT_HDL CORE 2 pin_name weredisplayed and overlapped by spin command.* K" e8 a/ L: q5 ?3 a g
1132698 ALLEGRO_EDITOR EDIT_ETCH Slide Via with Segment option with newSlide command8 |3 i2 [* w2 J5 k$ K* ]1 \
1132964 ALLEGRO_EDITOR SHAPE Same net "B&B via toshape" errors created when adding shape+ S; m9 |5 q# k
1133677 CONCEPT_HDL CORE Cant delete norreset LOCATION prop in context of top
8 D- e, y$ h2 E6 `" @1133791 CONCEPT_HDL CORE Cant do textjustification on a single selected NOTE in Windows mode.0 R, T! e8 C {) c( |/ W' x
1134761 CONCEPT_HDL CORE Why does MousePointer/Tooltip display LOCATION instead of $LOCATION property
4 j+ i) w% o, j% T1 T" f1135118 ALLEGRO_EDITOR INTERACTIV Mirror and other editing commands aremissing for testpoint label text in general edit mode.2 t1 g, ?9 L. g% d( L
1136420 CAPTURE GENERAL Registrationissue when CDSROOT has a space in its path' M: G2 M8 v3 [, b9 M
1136808 PSPICE STABILITY Pspice crashmarker server has quite unexpectedly
( x% k0 P. f. B! F1136840 CAPTURE SCHEMATICS Enh: Alignment oftext placed on schematic page `4 M* {5 M* {- T
1138586 ADW MIGRATION design migrationdoes not create complete ptf file for hierarchical designs
* u a0 t# i# ?4 T1139376 CONCEPT_HDL CORE setting wirecolor to default creates new wire with higher thickness) k' K# f, B) a d6 |6 J) Q
1140819 APD GRAPHICS Bbvia does notretain temp highlight color on all layers when selected.
) ?+ V# F; J( T3 h1141300 CONCEPT_HDL CORE DE HDL hier_writesave hierarchy log reports summarizes Successfully saved block x while blockwas skipped
; V: J( y1 J6 x) q# b1141723 ADW PURGE purge commandcrashes with an MFC application failure message
# N" [- t- c& }6 O) ~7 N' M1143448 CAPTURE GENERAL About copy &paste to Powerpoint from CIS3 ~: O, o5 i2 v/ a! k9 K
1143670 SIP_LAYOUT OTHER Cross Probingbetween SiP and DEHDL not working in 16.6 release
; G. y! J; c+ Z, W( a1143902 ALLEGRO_EDITOR DATABASE when the shape is rotated 45 degreesthe void is moved.; k& } n' n, E! a) G' O. K$ Z% r
1144990 PCB_LIBRARIAN CORE PDV expand &collapse vector pins resizes symbol outline to maximum height8 ~& r1 H4 @5 R; Y5 F: a
1145112 CONCEPT_HDL CORE Warning message:Connectivity MIGHT have changed; K9 Y5 y! Q3 S4 p5 ^" o( ?3 @
1145253 CONCEPT_HDL CORE Component Browseradds properties in upper case
7 j6 Q" v: |7 J0 Z2 r, _1146386 ALLEGRO_EDITOR INTERACTIV Place Replicate Create add Static shapewith Fillet shape
7 S! {! r5 C" w) C3 A# ~, c1 n8 F1146728 F2B PACKAGERXL DCF with upperand lower case values on parts causes pxl to fail
# e& [) o, |( E' H! s+ V1146783 ALLEGRO_EDITOR INTERFACES Highlighted component is missing fromexported IPF file.7 N" E! v, o# E2 v' p
1147326 CONCEPT_HDL CORE HDL crashes whentrying to reimport a block( M5 w2 E# S. j% r' s+ H& G1 R( y
1148337 CAPTURE ANNOTATE Checking "refdes control" isnot giving the proper annotation result. b6 s/ o! d- `8 r$ a) U# D9 N( G
1148633 SIP_LAYOUT INTERACTIVE Add "%"to the optical shrink option in the co-design die and compose symbol placementforms
/ L6 H; M7 m9 B6 e" V6 K1149778 CAPTURE SCHEMATICS Rotation of pspice marker before placementis not appropriate
+ M3 k; F1 I) z1149987 PCB_LIBRARIAN PTF_EDITOR Save As pushingthe part name suffix into vendor_part_number value# ^$ o c% q9 O* k: E& |2 V# Q
1151748 ALLEGRO_EDITOR OTHER If the pad and cline are the samewidth don't report a missing Dynamic Fillet./ n, x* l0 N: B
1152206 CONCEPT_HDL CORE ROOM Propertyvalue changes when saving another Page
3 ~+ a ~6 K* T1152755 CONCEPT_HDL COPY_PROJECT Copy projecthangs if library or design name has an underscore3 E5 y+ h, p; q) s
1152769 PSPICE ENCRYPTION Unable to simulate Encrypted Models in16.62 [% R+ O' T# @
1153308 ALLEGRO_EDITOR DRC_CONSTR Creating Artwork Getting Warning"DRC is out of Date" even when DRC is up to date
" _! C% H6 L1 y: {" N; s, b% \1153893 F2B DESIGNVARI 16.6 VariantEditor not supporting - in name
) ?: O! @! [- ]2 o( {1154185 SIG_INTEGRITY SIGNOISE Signoise didn'tdo the Rise edge time adjustment.
( T W% F( ]) o2 a1154860 ALLEGRO_EDITOR MANUFACT Double digit drill character overlapswith figures triangle, hexagon and octagon in NC drill legend0 k. H3 [! K2 p7 I
1155167 ALLEGRO_EDITOR EDIT_ETCH Via structure placed in Create Fanouthas incorrect rotation.
0 }/ Y6 Z$ y& l& N, d" O/ F1155728 CONCEPT_HDL CORE Unable to uprevpackaged 16.3 design in 16.5 due to memory' q( H: y+ k( A/ z5 ]
1155855 SCM SCHGEN A newlyuser-defined net property is not transferred from SCM to DEHDL in PreservedMode8 S# m/ [' M. {) T. D- Y
1156274 ALLEGRO_EDITOR INTERFACES Exported Step file from Allegro is wrong: A+ c% P, B5 f7 j, e8 z6 u+ \
1156316 CONSTRAINT_MGR OTHER Break in functionality whilecreation of pin-pairs under Xnet in Constraint Manager
3 g4 u6 Y" S1 Q+ [+ ^1156351 CONCEPT_HDL CONSTRAINT_MGR Loose members inPhysical Net Class between DEHDL and Allegro( ^4 Y) V9 }: J4 s6 X' W5 S! t+ r
1156547 ALLEGRO_EDITOR DRC_CONSTR Etch Turn under SMD pin rule checkthrough pin Etch makes confused.
6 t& t R/ E" C8 L: \, ~1156779 CONSTRAINT_MGR OTHER Electrical Cset References in CM notworking correctly
8 P, q6 a- J F+ n0 X+ {1 h" B$ t" r1157167 ALLEGRO_EDITOR skill axlPolyFromDB with ?line2poly isbroken& G: R( r5 g* u3 H( @
1158042 ALLEGRO_EDITOR DFA DFA_DLG writes the dra file namein uppercase.
* j& ~ o1 j" w8 {/ r( \% ^1158718 CONCEPT_HDL CHECKPLUS Customer couldnot get $PN property values on logical rule of CheckPlus16.6.- g# l6 X* D' \% u6 ^
1158970 ALLEGRO_EDITOR SCHEM_FTB Changing LOCATION to $LOCATION in DEHDLdoes not update the .brd file
' M J4 D d" f) I1158989 ALLEGRO_EDITOR INTERFACES pdf_out -l creates a PDF
1 D0 U ^! L% A% D# m0 n1159285 APD DXF_IF DXF_OUT fails;some figures are not exported
' n8 d {: Q1 q) C0 b1159432 ALLEGRO_EDITOR SHOW_ELEM http:// in the Show Element in 166 donot have HTML link to open the Website. N$ z8 M3 H& N4 f6 w
1159483 PCB_LIBRARIAN SETUP part developercrashing with
l/ u$ E! d0 ^* d0 h1159516 ALLEGRO_EDITOR EDIT_ETCH Unable to slide cline segment with newslide.! y; x) r& M6 j( F2 V1 h- n. h% ?: F
1159959 ALLEGRO_EDITOR GRAPHICS 3D viewer displays clines arcsincorrectly y/ [8 s, g4 B* O; @ Q q
1160004 SCM UI The RMB->Pastedoes not insert signal names.' h4 V$ K, S2 S# {: @( Q
1160410 ALLEGRO_EDITOR DATABASE Lock databse with View Lock option ismisleading
$ M2 g2 d# @% L' Z X: `6 B1160529 SCM SCHGEN Schematicgeneration stopped because the tool was unable to create an appropriateinternal symbol structure3 a9 D* x% K0 V, D
1160537 SPIF OTHER Cannot start PCBRouter
2 |) W \% i2 s1161363 ALLEGRO_EDITOR SYMBOL Getting error SPMHGE-73 when tryingto mirror symbol
' ]: e- K( \" ^1161781 CONSTRAINT_MGR CONCEPT_HDL SigXp crash when selecting ECset indesign
3 m1 ^3 _* I3 A6 R- u2 Q* ~; M1161896 ALLEGRO_EDITOR DRAFTING Tolerance value added for Dimensionsis not working correctly (HF11-12)% _0 u% S7 e" l3 Y- l% O
1162193 SIP_LAYOUT DIE_ABSTRACT_IF shapes in diafile not linked to the die after edit co-design die
/ |4 ?2 X- N3 G2 Z( R6 k( t1162754 APD VIA_STRUCTURE Replace Via Structurecommand selecting dummy nets. |
