cadence SPB16.6下载(Hotfix013已发布)
* c) a. p7 ^7 ]0 q/ \( l. ~9 e, S2 Q1 ~/ ~6 Y% q% _: x( N, {
Cadence SPB16.6已经推出,需要的朋友可以点击下面的链接下载:$ V6 w; H; l1 |- C: `
http://dl.vmall.com/c0ych9k8m3( g7 v2 ~. E6 o- P9 T6 t) L
- b2 k8 }. q# v5 ]. i" {7 q
- V5 b0 u! P" N- Z& `) e8 pDATE: 07-26-2013 HOTFIX VERSION: 013
8 O) l, x4 E8 j===================================================================================================================================( O( E* x% N" F1 I
CCRID PRODUCT PRODUCTLEVEL2 TITLE
' X. I6 Q3 f' F- v" s. g0 ]4 ~===================================================================================================================================
9 s0 y" I' C! @4 K: ]111368 CAPTURE CORRUPT_DESIGN Capture - will not produce allegro netlistwith 10.0( Q$ I" l0 A+ n" q& p6 b- \4 C: |
134439 PD-COMPILE USERDATA caCell terminals should be top-levelterminals$ e( ?' q& n2 {8 ~
186074 CIS EXPLORER refresh symbols from lib requires youto close CIS. m6 Q' y2 A& W
583221 CAPTURE SCHEMATIC_EDITOROption to have the Schematic Page Name as a Property in the Titleblock b7 n+ }$ T6 J r
591140 concept_HDL OTHER Scale overall output size inPublishPDF from command line
: h9 M- `1 }+ s+ _0 u801901 CONCEPT_HDL CORE Concept Menus use the same key"R" for the Wire and RF-PCB menus
3 N1 b6 N3 D$ n$ S3 A813614 APD DRC_CONSTRAINTS With Fillets present the "cline toshape" spacing is wrong.' T4 h5 k# \5 |1 A: d5 O' V
881796 ALLEGRO_EDITOR GRAPHICS Enhancement request for Panning with Middle Mouse Button
7 u8 ]; P$ k: B/ z5 O887191 CONCEPT_HDL CORE Cannot add/edit the locked property
9 P V/ Q: N& R911292 CONCEPT_HDL CORE Property command on editing symbolattaches property to ORIGIN immediately
% ?/ y A! w l# y987766 APD SHAPE Void all command gets result as novoids being generated on specific env.
! x+ k- f! Q. C, u- P! s3 I1001395 SIP_LAYOUT ASSY_RULE_CHECK Shape Minimumvoid check reports lots of DRCs which are not necessary to check out.1 P" p0 s) B$ k" f) b9 G
1030696 ALLEGRO_EDITOR INTERACTIV Enh - Allow another behavior of PANmovement using middle mouse in Allegro
1 \0 Q; L& X; u; k. H1043856 ADW TDA Diff between TDOand DE-HDL Hierarchy Viewer is confusing to the user
6 l4 s- Z; }& V' {1046440 ADW PCBCACHE ADW: ImportSheetis not caching libraries under flatlib/model_sym when the source design is notan ADW project( B. X( V0 q/ [7 h6 a+ ~
1077552 F2B PACKAGERXL Diff Pairs get removed when packing withbackannotation turned on
$ j# x, j2 X0 U+ E! I6 q I1079538 F2B PACKAGERXL Ability to blockall 縮ingle noded nets� to the board while packaging.$ h1 D( j- F* C& F
1086362 ALLEGRO_EDITOR SHAPE Enhancement request to autovoid a viaif shape cannot cover the center of the via.6 M- |6 k& l6 |* h9 q3 O
1087958 Pspice MODELEDITOR Is there anylimitation for pin name definition?
: P: R- A _4 {, b/ E0 R4 R. [1087967 CIS UPDATE_PART_STAT Update part status window shows incorrect differences; W* Q* _+ \- Z9 C% y1 A$ x, H
1090693 ADW LRM LRMauto_load_instances does not gray out Load instances Button
0 `* n- ~* e+ p2 j4 }9 T) C1097246 CONCEPT_HDL CORE ConceptHDL -assign hotkeys to alpha-numerical keys
3 q! [( h1 C" h1 F3 v' w- J1099773 CONCEPT_HDL CORE DE HDL goes intorecursive loop if a custom text locked at site level is deleted from Tools >Option$ F3 H" x, m1 k/ a" P0 U! a
1100945 SCM SCHGEN SCM generatedDE-HDL has $PN placement issue% K' x( M: {; _4 K6 v2 a4 G
1100951 PSPICE SIMULATOR Increasing theresolution of fourier transform results in out file& P. O! s: Q. y5 P( `8 u
1103117 RF_PCB FE_IFF_IMPORT Enh- Allow theAllegro_Discrete_Library_to_ADS_Library_Translator to output in its originalunit
3 q, w4 `( w0 a, T" b1105473 PSPICE PROBE Getting errormessages while running bias point analysis.
9 \ g4 t& `; n( r e# A P d1106116 FLOWS PROJMGR view_pcb settingchange was cleared by switching Flows in projmgr.
& l8 A E4 D( k4 m% G1106298 ALLEGRO_EDITOR INTERACTIV Copy Shape uses last menu pick locationas origin and not the Symbol Origin as specified in Options., c* `) p" X8 i7 N* K5 H
1106626 CONCEPT_HDL CORE Concept HDL crashes when saving pages
& ^3 J" [/ v- x, {1107086 ALLEGRO_EDITOR INTERACTIV manual void with arc's goes in wrongdirection during arc creation
3 c; d% T0 X3 p2 H5 u1107172 CONCEPT_HDL OTHER Project ManagerPackager does not report errors on missing symbol
* \, Z; F8 S l/ A6 S: h2 F1108193 CONCEPT_HDL CORE Using theleft/right keys do not move the cursor within the text you're editing* C m) o: S/ A
1108603 PCB_LIBRARIAN VERIFICATION PDV ToolsVerification > View Verification (CheckPlus) leaves<project>.cpm_tmp.cpm
# n- O. K5 y& F* K1109024 CIS OTHER orcad performance issue from Asus.
9 f2 i9 g4 |. P, o& a/ ]5 h1 G/ ~" i1109109 CAPTURE NETLIST_ALLEGRO B1: Netlistmissing pins when Pack_short property pins connected: N: U* F5 l' Z8 ^, l
1109466 ALLEGRO_EDITOR ARTWORK Artwork create some strange gerberlines for fillet.: ]& _$ Y! Z7 L X* x; W
1109647 SIP_LAYOUT DEGASSING Shape degassingcommand enhancement - control over what layers are counted in even/odd layersets.
9 ?0 i0 H7 k L' r! @" s9 O1109926 CONCEPT_HDL CORE viewing a designdisables console window
U6 A( t$ G: v. X1110194 SIP_LAYOUT WIREBOND If OpenGL settings for display ofdynamic net names is enabled, should be visible while push/shove wirebonds.; K* e: h) o% q* ], ^ |
1112357 SIP_LAYOUT WIREBOND wirebond commandcrashes the application
D& b+ m" Q U3 R1 e' ?0 V1112395 CONCEPT_HDL CORE 縗BASE\G� for global signal is not obeyedafter upreving the design to 1650.9 E8 r; F4 e$ b2 S9 W+ d, b0 ~4 @
1112658 CAPTURE PROPERTY_EDITOR Changing Part 縂raphic� value from property EditorChanges Occ refdes values to instance" Q5 n# P4 e, w, U' V8 b' B% ^7 B
1112662 CAPTURE PROJECT_MANAGER Capture crashesafter moving the library file and then doing Edit> Cut
5 t2 I3 O% k/ C1 ]5 D1113177 PCB_LIBRARIAN CORE Pin Shapes arenot getting imported properly* x( k/ Q1 m% X0 p4 A8 X8 X: [; t
1113380 ALLEGRO_EDITOR INTERACTIV Change layer to - option for packagetype .dra is not available in 16.6 release6 h/ H; N3 J7 l
1113656 SIP_LAYOUT WIREBOND Enable Changecharacteristic to work without unfixing its Tack point.; A# {5 [+ O2 R* N
1113838 SIP_LAYOUT DIE_ABSTRACT_IF probe pinsdefined in XDA die abstract file are added with wrong location9 m, r4 I% s7 |" |
1113991 CAPTURE GENERAL Save Project Asis not working if destination is a linux machine
8 z' Z6 D$ T% e6 |6 T1114073 APD DRC_CONSTRAINTS Shape voidingdifferently if there are Fillets present in the design./ c. [+ y& v5 M A
1114241 CAPTURE SCHEMATIC_EDITOR Port not retaining assigned color, when moved on theschematic
. N$ J9 m) L+ \# K1114442 PSPICE PROBE Getting Internalerror - Overflow Convert with marching waveform on5 ?) A6 h( |: P: X% |! S- e! _
1114630 CONCEPT_HDL ARCHIVER Archcore failsbecause the project directory on Linux has a space in the name5 q1 ^( |7 D( U5 ?. i/ E3 d
1114689 CONCEPT_HDL CORE Unknown projectdirective : text_editor
/ e+ w! L t7 t: ^8 B7 A1114928 F2B PACKAGERXL 縀rror (SPCODD - 5) while Export Physical even afterchange pin from A<0> to A
9 O2 T3 i' t$ X5 c6 F/ V1116886 CONCEPT_HDL CORE Crefer hyperlinksdo not work fine when user use double digits partitions for page Border.9 o) i0 `0 w0 x: L( E) N0 V1 v
1118088 ALLEGRO_EDITOR EDIT_ETCH Should Plan accurate and Optimize beremoved in 16.6?
! [+ x1 a, D8 v3 S1118734 APD EDIT_ETCH Multiline routingwith Clines on Null Net cannot route in downward direction
: C, f5 S6 z, V+ E1118756 ALLEGRO_EDITOR SHAPE Shape clearance parameter oversizevalues getting applied to Keepouts
4 k/ t4 [$ Y8 M1119606 CONCEPT_HDL MARKERS Filtering two ormore words in Filter dialog box. A; b/ s+ \/ ] {% G: _
1119707 CONCEPT_HDL CORE Genview does not use site colors when gen schfrom block symbol
+ F. d& q% C4 C# t4 `9 x9 P1119711 F2B DESIGNSYNC DesignDifferences show Net Differences wrongly
! ^* c5 d* M( a# M" ]1120659 CAPTURE PROJECT_MANAGER "Saveproject as" does not support some of Nordic characters.1 Z( h" [, b5 d: X. b% w
1120660 CONCEPT_HDL CORE Save hierarchysaves pages for deleted blocks.& N2 S1 n( [2 V- i2 f5 B% A
1120817 SIP_LAYOUT SYMB_EDIT_APPMOD Rotate pads commands not working while in the SymbolEdit App. mode
( {7 U( |* U0 {& q0 d; O0 W/ [6 x1120985 PSPICE MODELEDITOR Unable to importattached IBIS model
2 P% f' L: S( Y# q. Q1121171 CONCEPT_HDL CREFER PNN and correctproperty values not annotated on the Cref flat schematic" z, r6 u# O+ ~& b$ q" V I
1121353 ALLEGRO_EDITOR INTERACTIV Local env setting will change aftersaving and reopening.
. K9 j6 T$ M9 Q; Z3 G1121382 ALLEGRO_EDITOR INTERACTIV Undo command is limited to two for thisdesign
$ G/ F9 r: c0 i- s9 \6 s1 |* W1121540 F2B PACKAGERXL pxl.chg keepsdeleting and adding changes on subsequent packager runs ?. V$ d3 w3 _1 J8 l
1121558 ALLEGRO_EDITOR MODULES Unrouted net and unrouted connectionwhen module is placed of completely routed board file.! I& f8 a) n* B( ]* v. B* n
1121585 ALLEGRO_EDITOR OTHER Drill Hole to Shape Same NetSpacing with Dynamic Shapes shows wrong result.% P% O' W' c1 `' j3 I1 n1 q. O
1121651 CAPTURE SCHEMATIC_EDITOR "PCB editor select" menu option is missing; R! x' \" P4 i' ^5 l
1122136 SIP_LAYOUT PLACEMENT Moving acomponent results in the components outline going to bottom side of the design.
# j# }" `! i1 ~' W1122340 CAPTURE NETLIST_ALLEGRO Cross probe ofnet within a bus makes Capture to hang.2 w0 B( J' m, g2 R- Y3 B% P! d
1122489 CONCEPT_HDL OTHER Save _Hierarchycausing baseline to brd files
+ F) _# Y+ G7 G9 E1122781 CONCEPT_HDL CORE cfg_package isgenerated for component cell automatically
0 [% t* i6 W$ r1122909 CONCEPT_HDL CORE changing versionreplicates data of first TOC on 2nd one, Y+ D: B, O; j
1123150 CONCEPT_HDL CORE property on yaxis in symbol view was moved by visibility change to None.
: F/ n y6 p; }- I8 Q6 ~1123176 ALLEGRO_EDITOR UI_FORMS Negative values for pop-up location isnot retained with multiple monitors (more than 2)6 V. L0 H$ p7 t0 e8 A
1123815 ALLEGRO_EDITOR GRAPHICS Embedded netname changes to a differentnetname5 ^7 {+ v% W/ M
1124369 ALLEGRO_EDITOR INTERACTIV Sliding a shape using iy coordinate doesnot work indepedent of grid./ q7 L9 Z* ]( B; V- \. {
1124544 CONCEPT_HDL CORE About SearchHistory of find with SPB16.5
. F9 ~( _0 {4 T! R& ^1124570 APD IMPORT_DATA When importingStream adding the option to change the point
% e# q( X0 d+ h4 o2 w! K( P" [+ ]1125201 CONCEPT_HDL CORE Connectivityedits in NEW block not saved( lost) if block is created using block add
- x3 S3 P1 G9 P& _1125314 ALLEGRO_EDITOR INTERACTIV Enved crash during setting of library paths inuser preference
" S2 T, a3 B, ~' f& o8 b7 D1125366 CONCEPT_HDL CORE DE-HDL crachESDuring Import Physical if CM is open on Linux$ Y' Y9 v% @5 U$ j3 C* f( D
1125628 CONCEPT_HDL CORE Crash on doingsave hierarchy q8 d O( C2 h5 M% I7 n
1130555 APD WIREBOND Wirebond Import should connect to pinsof the die specified on the UI.6 k0 ]& L0 e6 @4 [0 d
1131030 PSPICE ENVIRONMENT Unregistered iconof Simulation setting in taskbar4 a7 U* H4 K' t0 h# ^4 l3 o6 f+ T6 r
1131083 ALLEGRO_EDITOR INTERACTIV Bug: 16.6 crash in changing the mode inFind filter window, V. l1 n9 z7 Y0 p5 N: x
1131226 ALLEGRO_EDITOR PLACEMENT When Angle is set in design parameterswhile placement component is rotated but outline is not.
7 P' @; V! @8 f* K7 A1131567 CONCEPT_HDL OTHER Lower case valuesfor VHDL_MODE make genview use pin location to determen direction.
4 _8 i# C( k/ c: ~1131699 PSPICE PROBE Probe windowcrash on trying to view simulation message+ j4 |7 u0 q, W" F) O1 m/ w
1132457 CONCEPT_HDL CORE The schematicnever fully invokes and has connectivity errors.
Q+ n; C- i1 r% {& y, k1132575 CONCEPT_HDL CORE 2 pin_name weredisplayed and overlapped by spin command.
/ p" ]/ |$ c% I1 b1132698 ALLEGRO_EDITOR EDIT_ETCH Slide Via with Segment option with newSlide command7 {$ X# D; l. c3 @% e, }9 V
1132964 ALLEGRO_EDITOR SHAPE Same net "B&B via toshape" errors created when adding shape4 O" P# j* {' V* |' c
1133677 CONCEPT_HDL CORE Cant delete norreset LOCATION prop in context of top
" Y, X h1 |" c- I1133791 CONCEPT_HDL CORE Cant do textjustification on a single selected NOTE in Windows mode./ s3 |" }1 J( @
1134761 CONCEPT_HDL CORE Why does MousePointer/Tooltip display LOCATION instead of $LOCATION property( ?) c' s+ m4 q- i
1135118 ALLEGRO_EDITOR INTERACTIV Mirror and other editing commands aremissing for testpoint label text in general edit mode.
4 v" E! ~$ z( |1136420 CAPTURE GENERAL Registrationissue when CDSROOT has a space in its path8 J1 z' ]9 ^& a O+ M5 j
1136808 PSPICE STABILITY Pspice crashmarker server has quite unexpectedly; }' _4 P! n: V) e
1136840 CAPTURE SCHEMATICS Enh: Alignment oftext placed on schematic page7 Z- l8 [# e2 O' W k5 U* G( g- X
1138586 ADW MIGRATION design migrationdoes not create complete ptf file for hierarchical designs
- G, J, Q4 O+ b1139376 CONCEPT_HDL CORE setting wirecolor to default creates new wire with higher thickness
. X, T) {6 [$ d% r1140819 APD GRAPHICS Bbvia does notretain temp highlight color on all layers when selected.
( n) U4 j1 _$ f; t9 [; T1141300 CONCEPT_HDL CORE DE HDL hier_writesave hierarchy log reports summarizes Successfully saved block x while blockwas skipped
- B5 {6 C9 E: T1 v! L/ J1141723 ADW PURGE purge commandcrashes with an MFC application failure message
% |; @* T; {/ W" k% E5 C( b1143448 CAPTURE GENERAL About copy &paste to Powerpoint from CIS6 z% E: i( I- H* {+ J6 b
1143670 SIP_LAYOUT OTHER Cross Probingbetween SiP and DEHDL not working in 16.6 release
/ ]6 ?$ t7 r4 W5 p1143902 ALLEGRO_EDITOR DATABASE when the shape is rotated 45 degreesthe void is moved.2 @2 s- K% Y+ x$ T% p
1144990 PCB_LIBRARIAN CORE PDV expand &collapse vector pins resizes symbol outline to maximum height2 d3 C- N7 e3 N. h) O( l
1145112 CONCEPT_HDL CORE Warning message:Connectivity MIGHT have changed
3 _: `2 y* P, Z& Y1145253 CONCEPT_HDL CORE Component Browseradds properties in upper case
9 C" O& l7 j% n5 Z- l" g1146386 ALLEGRO_EDITOR INTERACTIV Place Replicate Create add Static shapewith Fillet shape1 Y2 F4 h1 y4 R% {6 K* ?6 z
1146728 F2B PACKAGERXL DCF with upperand lower case values on parts causes pxl to fail8 `: G5 c4 i+ ~
1146783 ALLEGRO_EDITOR INTERFACES Highlighted component is missing fromexported IPF file.7 u5 b* C7 X1 j# c& E; N
1147326 CONCEPT_HDL CORE HDL crashes whentrying to reimport a block
6 Q( ]. e: H1 U, P2 J1148337 CAPTURE ANNOTATE Checking "refdes control" isnot giving the proper annotation result, W7 X: M( \& D) @$ v; s
1148633 SIP_LAYOUT INTERACTIVE Add "%"to the optical shrink option in the co-design die and compose symbol placementforms
& ?. t* b; C/ Y( b. P# J- O1149778 CAPTURE SCHEMATICS Rotation of pspice marker before placementis not appropriate
' }6 o! o( L% J3 T1149987 PCB_LIBRARIAN PTF_EDITOR Save As pushingthe part name suffix into vendor_part_number value3 T4 Q/ b$ E* S4 Z$ S. [$ @# g
1151748 ALLEGRO_EDITOR OTHER If the pad and cline are the samewidth don't report a missing Dynamic Fillet.7 ?7 Q8 C, U( j. z
1152206 CONCEPT_HDL CORE ROOM Propertyvalue changes when saving another Page
F0 J( x6 t8 e) U1152755 CONCEPT_HDL COPY_PROJECT Copy projecthangs if library or design name has an underscore3 @2 K8 P2 N3 n' K: R9 c+ b& t* S
1152769 PSPICE ENCRYPTION Unable to simulate Encrypted Models in16.6+ O9 U5 X7 p6 D& G0 x) Q
1153308 ALLEGRO_EDITOR DRC_CONSTR Creating Artwork Getting Warning"DRC is out of Date" even when DRC is up to date# |: c' H, i( } W+ i# `& B
1153893 F2B DESIGNVARI 16.6 VariantEditor not supporting - in name
) n8 a8 e& y8 H0 `2 Z1154185 SIG_INTEGRITY SIGNOISE Signoise didn'tdo the Rise edge time adjustment.
6 |9 c- P0 P. K. {5 a# p, f1154860 ALLEGRO_EDITOR MANUFACT Double digit drill character overlapswith figures triangle, hexagon and octagon in NC drill legend+ F5 z3 p3 l4 u& m, i3 B; R
1155167 ALLEGRO_EDITOR EDIT_ETCH Via structure placed in Create Fanouthas incorrect rotation.' s* D4 B* [' g6 U
1155728 CONCEPT_HDL CORE Unable to uprevpackaged 16.3 design in 16.5 due to memory1 j/ `! b* C5 M5 v- d" K
1155855 SCM SCHGEN A newlyuser-defined net property is not transferred from SCM to DEHDL in PreservedMode
* I7 y/ H) ~# l8 X# k! O% I4 d8 t8 I1156274 ALLEGRO_EDITOR INTERFACES Exported Step file from Allegro is wrong- K+ d: \9 \5 Z5 [
1156316 CONSTRAINT_MGR OTHER Break in functionality whilecreation of pin-pairs under Xnet in Constraint Manager
3 b8 m' j0 E& ]$ E1156351 CONCEPT_HDL CONSTRAINT_MGR Loose members inPhysical Net Class between DEHDL and Allegro$ w( Y6 i S. a# x( f
1156547 ALLEGRO_EDITOR DRC_CONSTR Etch Turn under SMD pin rule checkthrough pin Etch makes confused.
$ w1 ]8 s& z% D3 l+ `1156779 CONSTRAINT_MGR OTHER Electrical Cset References in CM notworking correctly
. a4 W- i; p! U7 a7 Y1157167 ALLEGRO_EDITOR skill axlPolyFromDB with ?line2poly isbroken) L/ V) ^; C0 W6 A8 O
1158042 ALLEGRO_EDITOR DFA DFA_DLG writes the dra file namein uppercase.
4 c8 p' {# N7 o4 X% d1158718 CONCEPT_HDL CHECKPLUS Customer couldnot get $PN property values on logical rule of CheckPlus16.6.
. G! _% U- s. O/ }1158970 ALLEGRO_EDITOR SCHEM_FTB Changing LOCATION to $LOCATION in DEHDLdoes not update the .brd file
9 q) E+ T! A- T& D1158989 ALLEGRO_EDITOR INTERFACES pdf_out -l creates a PDF
, Z$ X$ `$ G5 A/ Z1159285 APD DXF_IF DXF_OUT fails;some figures are not exported* l! E) r% j d3 w* q' Q/ p
1159432 ALLEGRO_EDITOR SHOW_ELEM http:// in the Show Element in 166 donot have HTML link to open the Website
+ R9 g. y+ h, X6 s# p1159483 PCB_LIBRARIAN SETUP part developercrashing with; d5 Y( M) F$ M, t$ M
1159516 ALLEGRO_EDITOR EDIT_ETCH Unable to slide cline segment with newslide.
$ F# H; I. l: _7 e% W1159959 ALLEGRO_EDITOR GRAPHICS 3D viewer displays clines arcsincorrectly' W( Y, d9 j* E' _
1160004 SCM UI The RMB->Pastedoes not insert signal names.
+ {+ l" X& P9 z1160410 ALLEGRO_EDITOR DATABASE Lock databse with View Lock option ismisleading
, R" p; K0 \8 {5 g" g$ v: i' g1160529 SCM SCHGEN Schematicgeneration stopped because the tool was unable to create an appropriateinternal symbol structure, N% h: n% L, m# W+ Q
1160537 SPIF OTHER Cannot start PCBRouter+ \3 |8 }! o/ n/ f. X
1161363 ALLEGRO_EDITOR SYMBOL Getting error SPMHGE-73 when tryingto mirror symbol
/ P( ?' F' n2 c9 M# q( j! b5 ~- x7 [1161781 CONSTRAINT_MGR CONCEPT_HDL SigXp crash when selecting ECset indesign
; T+ _5 `, Z/ E1161896 ALLEGRO_EDITOR DRAFTING Tolerance value added for Dimensionsis not working correctly (HF11-12)/ K/ _0 s" H- t+ b7 Q3 B2 D
1162193 SIP_LAYOUT DIE_ABSTRACT_IF shapes in diafile not linked to the die after edit co-design die
0 \0 q7 ^- p; c! T: c# {1162754 APD VIA_STRUCTURE Replace Via Structurecommand selecting dummy nets. |
