cadence SPB 16.5下载地址(Hotfix更新至044)
$ l9 b* d! C' _2 R4 Y+ k* v) m2 g2 z+ f
Cadence最新版软件SPB 16.5及其Hotfix下载链接如下:( b4 |/ L8 Y* d- c. C+ A4 a) b0 q
http://dl.vmall.com/c0sfvdb4yy
* l* @) P* k5 [) u. [1 K6 `
. H8 r6 k( h! O- \, h7 gHotfix中只需要安装最新的版本即可。
0 T' [5 `& K f- A4 z, _7 ]& J
0 ]9 z) v, w- z' K' bDATE: 06-7-2013 HOTFIX VERSION: 044: _1 b3 K& W |+ H9 R
===================================================================================================================================" K9 ?( q% s4 |' ^1 B& d9 \
CCRID PRODUCT PRODUCTLEVEL2 TITLE; [7 b' f" f/ Q/ p
===================================================================================================================================2 C$ j: P$ B! C/ m9 l8 h% \: P
1055338 SIP_LAYOUT DRC_CONSTRAINTS Soldermask to Via drcs on bondfingers- M2 g- W0 i9 H0 D
1084716 allegro_EDITOR OTHER Getting an MPS error when updating CM from SigXplorer: n: D v- T3 c0 ~# p
1104145 ALLEGRO_EDITOR SCHEM_FTB User defined properties do not appear in PCB; V, G, U3 m0 a Z6 K/ r( C
1106116 FLOWS PROJMGR view_pcb setting change was cleared by switching Flows in projmgr.
z# h5 l2 F% W% P. e1106900 concept_HDL COMP_BROWSER Component Browser peRFormance utility should honor CPM directives for include and exclude PPT
3 c% x7 r. d$ f* `1110323 APD DXF_IF DXF out is offsetting square discrete pads." K- o$ h0 b' R) T6 ~" o
1119007 CONCEPT_HDL CORE PDF Publish of schematic creates extremely large PDF files
# o/ ~/ C0 q2 [" P! p+ `1121020 FSP MODEL_EDITOR Cut-Paste from Excel causes empty cell in Rule Editor
7 @: F6 T5 M; p9 j1121353 ALLEGRO_EDITOR INTERACTIV Local env setting will change after saving and reopening.! {; U7 C* x' | a, `
1122781 CONCEPT_HDL CORE cfg_package is generated for component cell automatically
& F3 v/ [2 c: o/ ]4 \, P5 r" @: f1122909 CONCEPT_HDL CORE changing version replicates data of first TOC on 2nd one2 y _' r) h; l
1123581 ALLEGRO_EDITOR MANUFACT Dimension Line gets changed on board- E: {" q* p( C% r+ |
1124544 CONCEPT_HDL CORE About Search History of find with SPB16.5
/ V6 E" U3 D8 y3 q X8 _7 `1125366 CONCEPT_HDL CORE DE-HDL craches during Import Physical if CM is open on Linux& }! }1 D! K1 ?8 C
1125628 CONCEPT_HDL CORE Crash on doing save hierarchy J0 \& Y: r0 \! G. q' c
1126182 ALLEGRO_EDITOR DRC_CONSTR Shape fillet DRC in same net thru via to thru via was removed after update DRC.
2 e( u0 A' d2 w# h4 }; b. \1130945 SCM SCHGEN SCM Export Schematic does not copy all cells in the library5 r' h5 b P! P9 m1 o
1131567 CONCEPT_HDL OTHER Lower case values for VHDL_MODE make genview use pin location to determen direction. V8 F) P: o/ B7 j e
1131650 ALLEGRO_EDITOR PLOTTING PDF Publisher doesnot display few component defination properties in Property parameters5 [. |3 E+ M* Y8 j1 X; E0 l) x
1131868 CONCEPT_HDL CONSTRAINT_MGR Many net-class constraints "fell off" the design after uprev and Import Design of GEP4! _3 `1 ]; D" F8 O$ T
1132457 CONCEPT_HDL CORE The schematic never fully invokes and has connectivity errors.
. J. Q+ M( b9 `4 i' e1132575 CONCEPT_HDL CORE 2 pin_name were displayed and overlapped by spin command.
, R0 X+ j! G( n+ b1132638 ALLEGRO_EDITOR DFA 'dfa_update' crashes when running the utility on the attached foder.3 ?: O9 C8 `5 P$ S" ]$ h
1133677 CONCEPT_HDL CORE Cant delete nor reset LOCATION prop in context of top8 X$ F# p& h/ l7 u+ @
1133791 CONCEPT_HDL CORE Cant do text justification on a single selected NOTE in Windows mode.! }% l3 }# X$ s( ~
1134083 CONCEPT_HDL OTHER Published PDF file's hyperlinks do not work fine when user use double digits partitions for page Border.. B6 M. ]; @. K2 ~8 \: G
1134761 CONCEPT_HDL CORE Why does Mouse Pointer/Tooltip display LOCATION instead of $LOCATION property" ?6 X m- @% k' v8 c% @ t
1138586 ADW MIGRATION design migration does not create complete ptf file for hierarchical designs& P% r0 F0 X' e* H+ d( q2 c
1139376 CONCEPT_HDL CORE setting wire color to default creates new wire with higher thickness
; N* ^! o4 ?' b5 }1141300 CONCEPT_HDL CORE DE HDL hier_write save hierarchy log reports summarizes Successfully saved block x while block was skipped
& h4 F: e4 `2 ~" |! _& T4 E2 n1142876 ALLEGRO_EDITOR SHAPE No DRC error when airgap between place bounds exactly zero
: G; {0 `) L! q+ |. F1142884 ALLEGRO_EDITOR OTHER Boolean type user defined property doesn't export to the PDF) q; c8 s! T: A) r0 @1 r) l
1145112 CONCEPT_HDL CORE Warning message: Connectivity MIGHT have changed# B6 x8 o# X8 h# D% x2 b8 T9 ~
1145235 CONCEPT_HDL CONSTRAINT_MGR DEHDL CM gives error when trying to launch SigXP! k$ f6 h, E y5 |& S
1145253 CONCEPT_HDL CORE Component Browser adds properties in upper case
3 q: g7 F$ q: w) |6 b1145284 CONCEPT_HDL CORE Publish PDF crashes DE HDL
! y/ b7 x6 K9 B4 ?, Q1145333 ALLEGRO_EDITOR SHAPE SHAPE boundary may not cross itself. Error cannot be fixed.* c* z; h4 {. k, j" G
1145856 ALLEGRO_EDITOR DRC_CONSTR DRC Line to Thru Pin appear while Fillet be added
- K' p+ a8 ^: j. E3 Z# m! h o }1146287 PCB_LIBRARIAN CORE PDV expand pins and change origin sets coordinates for few pins wrong and places pins on top of each other after collaps/ P: A" k; O \- o) n! L
1146728 F2B PACKAGERXL DCF with upper and lower case values on parts causes pxl to fail" P4 `9 c, n1 C9 C4 |
1147326 CONCEPT_HDL CORE HDL crashes when trying to reimport a block |
