Hotfix_SPB16.60.009_wint_1of1(9号补丁)7 k! P9 Y( n2 Y4 k2 K' l
2 j4 W. Y4 q" L1 S3 l
http://pan.baidu.com/share/link?shareid=418583&uk=3826038294
/ U- ~9 O* e# C6 T9 U9 ]1 i2 S1 @1 S E7 M, `
+ V c6 U+ a0 D" k) \
/ ]! n( h3 y7 rDATE: 05-9-2013 HOTFIX VERSION: 009
' q, m& v! a0 V3 [===================================================================================================================================
* q' }9 f& w {/ \" a: e: l3 ]* eCCRID PRODUCT PRODUCTLEVEL2 TITLE
* V. _3 l+ M/ w1 ^8 ~/ v===================================================================================================================================
: d, O j" I5 j9 s961420 allegro_EDITOR PLACEMENT Regardless of the aspect ratio for room of side The QuickPlace by room command could be placed comp! c' J% s q2 s* K1 x
1079862 ALLEGRO_EDITOR skill Ability to create IPC2581 layer mapping file by Allegro Skill function+ z& i& |: K& J! [8 {
1080734 concept_HDL CORE Repainting of grid lines during pan or by moving window show as solid white lines instead of gray da
- Y- v# F2 v6 h$ ]1104145 ALLEGRO_EDITOR SCHEM_FTB User defined properties do not appear in PCB- A3 C3 b/ |# z* w
1107547 SCM OTHER v15.5.1 tcl/tk code not recognised in 16.6
# _% d, p; w, L- R1110209 CONCEPT_HDL OTHER We can move symbols and wires off grid despite the site.cpm grid lock
; m2 ], f$ E7 {9 j1117825 CONCEPT_HDL OTHER SHOW_CONSOLE_ON_LAUNCH throws an unrecognized directive warning in the schematic editor
; n* y. l5 s5 t% ]3 C1 z1118874 ALLEGRO_EDITOR INTERFACES Oblong pad shapes are not shown with correct orientation after DXF export from Allegro
9 \: x/ u; \' O1121873 ALLEGRO_EDITOR INTERFACE_DESIGN Importing Bundles from Net Groups does not allow any further editing.- K8 s) L P9 `2 O9 p
1122933 CONCEPT_HDL CORE Newly added Toolbars are getting invisible after re-staring Concepthdl: Q! P. [) \4 ]1 y3 ?
1124587 ALLEGRO_EDITOR INTERACTIV The Shape Expansion/Contraction command should also be available in EE mode.$ j C: T6 X: _4 E% h8 N( F0 b* v @8 p
1125895 SIP_LAYOUT LEFDEF_IF Tool crash while moving the slider in the Filter options Macro tab form of the co-design die library manager2 c2 ~4 t: F% z( W! P* x
1125962 F2B DESIGNVARI Custom Text in Variant Details dialog box is inconsistent1 B2 d3 ]- p' E5 N
1126096 SCM REPORTS Two nets missing in report
5 F' R7 n$ I5 g$ O% J1 e1126134 SIG_INTEGRITY GEOMETRY_EXTRACT Attempting to extract topology hangs APD P7 T$ L" M# [1 _; _
1126182 ALLEGRO_EDITOR DRC_CONSTR Shape fillet DRC in same net thru via to thru via was removed after update DRC.
6 H$ K c' R) o: E1 P+ \1130280 ALLEGRO_EDITOR MANUFACT stream_out command in 16.6 seems hard coded to look for a design called stream_out.brd' q6 u$ ~9 p" h% ?( o2 l/ U* R0 e) P
1130737 F2B PACKAGERXL Error - pxl.exe has stopped working
6 |0 S" N3 ]7 f5 e1131650 ALLEGRO_EDITOR PLOTTING PDF Publisher doesnot display few component defination properties in Property parameters8 h3 M- ]+ i' z# N1 o
1131764 ALLEGRO_EDITOR EDIT_ETCH Line segment will not slide using the New Slide.
4 t4 W. H: _( h* t: \ r! {) j7 n1132638 ALLEGRO_EDITOR DFA 'dfa_update' crashes when running the utility on the attached foder.
6 t7 o& I4 @7 y: h, C/ b1133311 ALLEGRO_EDITOR SKILL ?origin switch is not working correctly with axlTransformObject while rotating shapes
. @, h' u; P7 b4 n! G) l# r1133893 SIP_LAYOUT IMPORT_DATA netlist-In Wizard crashes |
