查看: 3043|回复: 12
Hotfix_SPB16.60.007_wint_1of1已发布
发表于 2013-4-17 14:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  [- F+ v; E( m
6 U$ p* T8 ~* F1 a百度网盘下载
% [5 j+ v/ z) q6 h. B  m0 M4 Q( Z3 I4 @8 ~
http://pan.baidu.com/share/link?shareid=395304&uk=3306465230
参与人数 1贡献 +2 收起 理由
dmzy007 + 2 支持!
 楼主| 发表于 2013-4-17 14:37 | 只看该作者
- h1 \" r3 H- T7 ^8 F% D% q0 d8 C" J8 x
DATE: 04-13-2013   HOTFIX VERSION: 007
7 ?- K9 T( \6 Z( y6 {# a1 y
5 Z9 i* C& E) x, g+ r0 Q2 ~) j===================================================================================================================================/ T8 t- f5 E; T9 {* p; _. I
! h4 T1 _' V6 G( Z' vCCRID   PRODUCT        PRODUCTLEVEL2   TITLE: e5 O+ p( V8 d0 o% f
. }& L: g: i4 U===================================================================================================================================
7 G% _0 c! ]" ^3 _
  A% ]! C8 m. `: A. n1107397 SIP_LAYOUT     PLACEMENT        Place Manual-H rotates die' [; G' q- Y' P
1111184 ALLEGRO_EDITOR PLACEMENT        NO_SWAP_PIN property does not work in 16.6
1 P' k3 l9 i2 D1 ~. o) E1112295 APD            DXF_IF           Padstacks offset Y cannot be caught by DXF.' L. ~! n; D: {4 ?3 s; T) w& [
1113284 ALLEGRO_EDITOR INTERFACE_DESIGN Rats disappear after moving components5 m( ^4 Y3 A& j
1113317 CONCEPT_HDL    SKILL            skill code to traverse design not working properly, p4 r  C) k! J. S" b2 |
1115491 ALLEGRO_EDITOR SKILL            telskill freezes command window
6 }0 T6 b+ N' p/ W9 j1115625 ALLEGRO_EDITOR SKILL            Design extents corrupted when axlTrigger is used.
- R+ U$ L0 Q% Z1115708 ALLEGRO_EDITOR INTERFACES       Export DXF is outputting corrupt data on one layer.% J1 K/ A) |0 z0 w$ P  d8 ?6 x
1115850 ALLEGRO_EDITOR GRAPHICS         Text edit makes infinite cursor disappear2 q$ A% M" p: ?  N- z
1116530 ALLEGRO_EDITOR MANUFACT         Import artwork show missing padstacks3 v4 A% h" @# u( s
1117498 ALLEGRO_EDITOR DATABASE         Why does dbstat flag LOCKED?) J) c/ @' `, Y  ]' D( \9 a
1118407 SIP_LAYOUT     DIE_EDITOR       net connectivity is getting lost when running die abstract refresh* Z% X. \/ Q3 p+ F
1118413 SIP_LAYOUT     DIE_EDITOR       pin number is getting changed when running die abstract refresh
7 G  P: A0 q- E. C0 p, ~+ o, U1118526 CONCEPT_HDL    CONSTRAINT_MGR   Upreved design now has Constraint packaging errors
; w. ]. V* g5 X3 Y$ k1118830 ALLEGRO_EDITOR SHAPE            Performance issue when moving/refreshing shapes in 16.6
2 @+ [0 w2 D  z1119784 ALLEGRO_EDITOR INTERACTIV       ipickx command gives drawing extent error inconsistently2 ^$ P2 |1 K7 W( e
1120469 SIP_LAYOUT     DIE_ABSTRACT_IF  use different padstack for different, but look-alike bumps/ h" p) c* |+ |  `' I( {& J+ y5 H3 s
1120669 CONCEPT_HDL    CORE             DEHDL crash on multiple replace of hier blocks. P" Z% e$ x( d0 G: Z) @
1120810 ALLEGRO_EDITOR EDIT_ETCH        Cannot slide cline segment.
发表于 2013-4-17 18:36 | 只看该作者
谢谢您的分享
发表于 2013-4-17 21:58 | 只看该作者
谢谢您的分享
发表于 2013-4-18 08:28 | 只看该作者
/ r2 x- o* R, P$ y3 h# s2 v% q谢谢
    奋斗
    2025-9-10 15:12
    发表于 2013-4-18 10:03 | 只看该作者
    xiexie.........
    发表于 2013-4-18 16:53 | 只看该作者
    装上去了,S006出现的BUG,此版本是一点没改。
    发表于 2013-4-19 09:20 | 只看该作者
    刚打了006,再等一等吧,老打补丁也不是办法。
    发表于 2013-4-20 13:31 | 只看该作者
    谢谢分享!
    发表于 2013-4-27 10:54 | 只看该作者
    谢您的分享
    发表于 2013-5-4 19:40 | 只看该作者
    谢谢分享。
    发表于 2013-6-12 16:18 | 只看该作者
    楼主能否给发一份
    & m7 u' L6 A7 n, ~- [Hotfix_SPB16.60.007) g0 S; d& U3 }+ W6 [. T, P
    Hotfix_SPB16.60.008! G' @/ G) }, x3 W3 L# e$ N8 g' q
    邮箱:txqtomton@sina.com
    + @6 a2 {; r8 P谢谢
    头像被屏蔽
    13#
    发表于 2013-6-21 14:46 | 只看该作者
    提示: 作者被禁止或删除 内容自动屏蔽
    GMT+8, 2025-11-5 07:17 , Processed in 0.140625 second(s), 27 queries , Gzip On.
