查看: 3135|回复: 12
关于skill安装的问题
发表于 2008-8-1 10:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问高手,我按书上装了skill,为什么打开allegro时菜单栏不见了,而且图标很多都点不到了变灰了,是为什么呀,我是照书的步骤呀
[ 本帖最后由 snow118 于 2008-8-1 10:08 编辑 ]
39.29 KB, 下载次数: 67, 下载积分: 贡献 -30 , 威望 -10
发表于 2008-8-1 10:49 | 只看该作者
你的代码加错地方了。那段代码要和本来有的根目录并列。不要加在最后的end之后,要加在代码段里面。
POPUP "&Skill"
  BEGIN
   MENUITEM "Align Symbol", "align_sym"
   MENUITEM "Align Symbols Center",  "xasym"
   MENUITEM "Zoom to Unused Vias",   "rmvia"
   MENUITEM "DRC Walker", "drc walk"
   MENUITEM "Find Dang Line/Cline", "find_dang"
   MENUITEM "Find Stubs", "find_stubs"
   MENUITEM "Boundery Viewer", "bv"
   MENUITEM "Make Device", "make device"
  END
    POPUP "&Help"
    BEGIN
        MENUITEM "&Help",          "cdsdoc allegro DEFAULT"
        MENUITEM "What's &New",   "cdsdoc allegro AllegroPN"
        MENUITEM "Migration &Guide",  "cdsdoc allegro PCBmigration"
MENUITEM SEPARATOR
        POPUP "&Manuals"
BEGIN
            MENUITEM "&Command Reference",  "cdsdoc algcmdref DEFAULT"
            MENUITEM "&User Guide",    "cdsdoc allegro DEFAULT"
            MENUITEM "&Properties Reference", "cdsdoc allegro PropRef"
            MENUITEM "&Documentation Roadmap", "cdsdoc allegro pcbdocmap"
后面的半段是原来的help的菜单的代码。加在这个位置就可以让skill菜单在help之前了
 楼主| 发表于 2008-8-1 10:52 | 只看该作者
喔,谢谢!我再试试
#ifndef _ALLEGRO_STUDIO
POPUP "P&ad"
        BEGIN
            MENUITEM "&Boundary",  "editpad boundary"
            MENUITEM "&Restore",  "editpad restore"
            MENUITEM "Restore &ALL",  "editpad restore all"
        END
#endif
        MENUITEM "&Derive Connectivity...", "derive connectivity"
        MENUITEM SEPARATOR
        MENUITEM "&Reports...",   "reports"
        MENUITEM SEPARATOR
#ifndef _ALLEGRO_EXPERT
MENUITEM "Topology E&xtract",           "topology template"
#endif
MENUITEM "&Technology File Compare...", "techfile compare"
#endif
        MENUITEM "Setup Ad&visor...",           "setup advisor"
        MENUITEM SEPARATOR
        MENUITEM "Database &Check...",  "dbdoctor"
MENUITEM "&Update DRC",   "drc update"
        MENUITEM SEPARATOR
        MENUITEM "Design C&ompare...",  "design compare"
        MENUITEM SEPARATOR
POPUP "Uti&lities"
BEGIN
            MENUITEM "&Env Variables...",  "set"
            MENUITEM "&Aliases/Function Keys...", "alias"
            MENUITEM "&Keyboard Commands",  "helpcmd"
            MENUITEM "&Licenses Used...",  "license_use"
            MENUITEM "&Stroke Editor...",  "stroke editor"
END
    END
   POPUP"&STELLA"
   BEGIN
       MENUITEN"Align Symbol",               "align_sym"
       MENUITEN"DRC Walker...",              "drc walk"
       MENUITEN"Find Dang Line/Cline",    "find_dang"
       MENUITEN"Find Stubs",                   "find stubs"
       MENUITEN"Hilight Net without TP",  "hl_ntp"
       MENUITEN"Netlist Editor",               "net_editor"
            END
     END
    POPUP "&Help"
    BEGIN
        MENUITEM "&Documentation",              "cdsdoc allegro allegrolaunch"
        POPUP "&Web Resources"
BEGIN
           MENUITEM "&KP&&S",  "http
http://sourcelink.cadence.com/docs/files/Release_Info/psdkpns/algKPnS/algKPnSTOC.html"
           MENUITEM "&CadencePCB.com",  "http http://www.cadencepcb.com"
           MENUITEM "&Sourcelink",  "http http://sourcelink.cadence.com"
           MENUITEM "&Web Collaboration", "http http://collaboration.cadence.com"
           MENUITEM "&Frequently Asked Questions", "http
http://sourcelink.cadence.com/docs/files/FAQ/Allegro/allegroFAQ/allegroFAQTOC.html"
           MENUITEM "&Education Services", "http http://www.cadence.com/education"
        END
MENUITEM SEPARATOR
        MENUITEM "&About...", "about"
    END
END
  是这样吗,可是还是不行呀,麻烦楼上的高手帮我看看,感激不敬!
[ 本帖最后由 snow118 于 2008-8-1 10:59 编辑 ]
发表于 2008-8-1 16:35 | 只看该作者
把代码直接加在pop "&help"这行的前面就行了。
你好像多了一个end..
 楼主| 发表于 2008-8-1 16:42 | 只看该作者
哎,是呀,我现在去了个END,为什么还是不行呀,难道是allegro.ilinit的问题?如下:
; This example file shows how to load Skill files (those with the
;  extension ".il" in the current directory.
; To use copy to allegro.ilinit if to be used by all Allegro based programs
; or <programName>.ilinit if intended for only one program
; Setting Allegro environment variable, LoadSkillFilesDebug will turn
; on printing the name of each file as it is loaded.
setSkillPath(buildString(append1(getSkillPath() "d:/skill")));
unless(boundp('LoadSkillFilesDebug)
LoadSkillFilesDebug = axlGetVariable("LoadSkillFilesDebug"))
when(LoadSkillFilesDebug printf("\n"))
(foreach file (rexMatchList "\\.il$" (getDirFiles "."))
      when(LoadSkillFilesDebug printf("Loading Skill file: %s\n" file))
      (load strcat("./" file))
; Load any ini files (containing axlCmdRegister)
(foreach file (rexMatchList "\\.ini$" (getDirFiles "."))
load("MKDEV.IL")
load("align_sym.il")
load("find_dlines.il")
load("DRC_WALK.IL")
load("Find_DRC.il")
load("boundaryview.il")
;load("x_align_symbol.il" "deargds")
;load("")
;load("")
;load("")
; DstCAM350() is the CAM350 Cross Probe Startup
load( "d:\\pcbenv\\DstCxi.il")
发表于 2009-3-3 17:05 | 只看该作者
我的也是同样的问题,不知道怎么解决,慢慢再鼓捣几遍吧。
发表于 2009-3-5 11:20 | 只看该作者
请问楼上各位,本论坛有书吗,在哪,我想下,谢谢
发表于 2009-5-11 11:16 | 只看该作者
好难啊
发表于 2009-5-11 11:17 | 只看该作者
我的文件则呢么一直加载不了呢???
发表于 2009-5-11 20:31 | 只看该作者
可以尝试下我写得skill
https://www.eda365.com/thread-19064-1-4.html
    2019-11-19 15:59
    发表于 2015-12-14 14:24 | 只看该作者
    问下,你有什么书吗?想学习下skill。
    cadence的帮助文档就有关于skill的很详细的教程。  详情 回复 发表于 2015-12-14 14:25
    13#
    发表于 2015-12-14 14:25 | 只看该作者
    GMT+8, 2025-8-20 14:03 , Processed in 0.125000 second(s), 31 queries , Gzip On.
