查看: 4739|回复: 4
Cadence SPB16.6下载(包含Hotfix005已发布)
发表于 2013-3-15 15:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
cadence SPB16.6已经推出,需要的朋友可以点击下面的链接下载:1 ^( l( {7 G# y9 U
dl.vmall.com/c0pxuzug1s" `5 v' C/ \' d
里面有补丁Hotfix_SPB16.60.001_wint_1of1.exe
8 N4 b/ \& z8 F6 @& o; {  I3 _9 n( q8 D. I
DATE: 03-7-2013    HOTFIX VERSION: 005
' W# U( j2 Y2 ]2 E, D$ k0 ^===================================================================================================================================) q# i. G% f$ ]7 @4 T' r
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE) ^" m& U' z$ L1 v
===================================================================================================================================& C8 p7 ?  P3 L& R$ M9 ?
1067770 IXCOM-COMPILE  COVERAGE         Assertion failed: file ../covToggleCoverageXform.cpp, line 1102; q1 X6 d& ?1 A( a. |0 V2 O
1100442 allegro_EDITOR PLACEMENT        Placement queue shows components whichs are already placed: P6 S% `: P3 `! p& e1 e  U# O
1101555 ALLEGRO_EDITOR DATABASE         Allegro Crash frequently
0 U1 R' [2 B. f1104011 ALLEGRO_EDITOR DATABASE         Place replicate move group of a modules leaves traces behind
, m! w2 ^7 y5 c3 X+ @1104065 SCM            NETLISTER        SCM 16.6 has problem generating Verilog with existing sym_1 view) a8 \3 @% Q! O. \
1104605 F2B            PACKAGERXL       Pins of function swapped part in block not displayed
- C" [: h, \% [- a1104790 SCM            IMPORTS          Corrupt data once SiP file is imported into SCM
! u6 j4 v9 H* i% P& p) n/ }" z; a1105066 APD            IMPORT_DATA      Import NA2 worked in 16.5 "035" but fails in 037 and 16.6
+ M8 i& y3 b1 k2 A, `" f1106323 ALLEGRO_EDITOR PLACEMENT        Unable to locate specific placed symbol on this board as it becomes invisible after placement., b1 x& K; o2 g2 |3 R' d1 }* O5 ~
1108032 concept_HDL    CORE             'Find' option does not list all Components in the Design
, T# T0 C3 A) t$ `3 G6 o; m- j1109080 ALLEGRO_EDITOR OTHER            Window DRC is not working in orcad PCB Editor Professional
发表于 2013-3-15 16:10 | 只看该作者
非常感谢!下载下来安装试试!
    2024-5-31 15:50
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    发表于 2013-3-15 16:17 | 只看该作者
    发表于 2013-6-20 19:50 | 只看该作者
    感谢楼主的分享
    头像被屏蔽
    发表于 2013-6-29 13:29 | 只看该作者
    提示: 作者被禁止或删除 内容自动屏蔽
    GMT+8, 2025-11-5 08:44 , Processed in 0.125000 second(s), 23 queries , Gzip On.
