查看: 964|回复: 0
求教!有一个数据但是不知道怎么定义
发表于 2012-11-28 18:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
如题所示,我想建一个这样的form,现在有一个问题是,form的显示是采用自动抓取的方式,但是我无法定义输入框的操作。
本人是菜,求指教!!
所写代码如下:
axlCmdRegister("zz1" 'CreateShape)
procedure(CreateShape()
        let((CreateShapefile Dmyform)
                CreateShapefile = axlTempFile()
                Dmyform = outfile(CreateShapefile "w")
                if(car(axlDBGetDesignUnits())=="mils" then
                        ZUnit = "mil"
                        else ZUnit ="mm"
                );if
                fprintf(Dmyform "#Created by xml2bnf  perl utility\n")
                fprintf(Dmyform "#Coded by Venkata Ramanan/Santa Clara, CA\n\n")
                fprintf(Dmyform "FILE_TYPE=FORM_DEFN VERSION=2\n")
                fprintf(Dmyform "FORM AUTOGREYTEXT\n")
                fprintf(Dmyform "FIXED\n")
                fprintf(Dmyform "PORT 70 34\n")
                fprintf(Dmyform "HEADER \"Form Field Type Demo\"\n\n")
                fprintf(Dmyform "POPUP <ENUM>\"ITEM1\"\"0\",\"ITEM2\"\"1\",\"ITEM3\"\"2\",\"LAST ONE\"\"3\".\n\n")
                fprintf(Dmyform "TILE\n\n")
                n_layer=axlGetXSection()
                nbLayer = length(n_layer)
                p = axlGetParam("paramLayerGroup:ETCH")
                l_layer = p->groupMembers
;                p = axlGetParam("paramLayerGroup:ETCH")
;                l_layer = p->groupMembers
;                print(l_layer)
;                nblayer = p->nChildren
                declare(layer[nbLayer])
                declare(xw[nbLayer])
                arrayp(layer)
                arrayp(xw)
/*                for(lay 0 nbLayer-1
                        layer[lay] = nth(lay l_layer)
                        name = layer[lay]
                        xw[lay] = nth(lay l_layer)
                        xWidth = xw[lay]
;                        xWidth = xWidth1[lay]
;                        print(layer[lay])
                        printf("-----%s-----\n" xWidth)
                        i = (lay+1)*2
;                        if(mod(lay+1 1)==0 then
                for(lay 0 nbLayer/2-1
                        name = layer[lay]
                        xWidth = xw[lay]
;                        print(layer[lay])
                        i = (lay+1)*2
                        ;if(mod(lay-1 2)==0 then
;                        printf("****nbLayer=%d****\n" nbLayer);test
;                        printf("****lay=%d****\n" lay);test
                fprintf(Dmyform "## Text Field in Form## \n")
                fprintf(Dmyform "TEXT \"%s :\" \n" name)
;                fprintf(Dmyform "TEXT name \n" ) ;right
                fprintf(Dmyform "FLOC 2 %d\n" i)
                fprintf(Dmyform "TGROUP \"Form1\"\n")
                fprintf(Dmyform "ENDTEXT\n\n")
                fprintf(Dmyform "TEXT Width \n" )
                fprintf(Dmyform "FLOC 14 %d\n" i)
                fprintf(Dmyform "FIELD %s \n" xWidth)
                fprintf(Dmyform "FLOC 20 %d\n" i)
                fprintf(Dmyform "FSIZE 5 4\n")
                fprintf(Dmyform "STRFILLIN 5 5\n")
                fprintf(Dmyform "ENDFIELD \n\n\n")
                fprintf(Dmyform "TEXT \"%s\"\n" ZUnit)
                fprintf(Dmyform "FLOC 32 %d\n"  i)
                ;);if
                );for
                fprintf(Dmyform "## Button Field in FORM ## \n")
                fprintf(Dmyform "FIELD OK\n")
                fprintf(Dmyform "FLOC 9 27\n")
                fprintf(Dmyform "MENUBUTTON \"OK\" 14 3\n")
                fprintf(Dmyform "FGROUP \"Form1\"\n")
                fprintf(Dmyform "ENDFIELD \n\n")
                fprintf(Dmyform "FIELD Exit\n")
                fprintf(Dmyform "FLOC 33 27\n")
                fprintf(Dmyform "MENUBUTTON \"Exit\" 14 3\n")
                fprintf(Dmyform "ENDTILE\n\n")
                fprintf(Dmyform "ENDFORM\n\n")
                close(Dmyform)
            myform = axlFormCreate(gensym() CreateShapefile '("NE" "msglines" 0) 'CreateShapefileAction t nil)
            axlFormDisplay(myform)
            axlFormSetField(myform "sub_menuclass" 1)
                when(isFile(CreateShapefile)
                        deleteFile(CreateShapefile)
                        xWidth = xw[lay]
                        if( boundp('xxs)==nil then
                        xxs = "30"
                        axlFormSetField(myform xWidth xxs)
                        printf("*****%s*****\n" xWidth )
;                for(lay 0 nbLayer-1
;                        layer[lay] = nth(lay l_layer)
;                        name = layer[lay]
/*                        if( boundp('xxs)==nil then
                        xxs = "30"
                        yys = "30"
                        rrs = "20"
    axlFormSetField(myform "xWidth" xxs)
    axlFormSetField(myform "yLength" yys)
        axlFormSetField(myform "rCurved" rrs)
procedure(n()
        let(n( ) ;xWidthNumber yLengthNumber rCurvedNumber
                case(myform->curField
; 现在主要是这里的设定不知道应该怎么做,比如说和之前一样自动定义每一个输入框
                        ("GND1"
                                ;for(i 0 nbLayer/2-1
                                ;printf("+++++++++%s++++++++++++++" xxs)
                                xxs=myform->curValue
                        ;Input Field
                        ;Enter Action Here
                        ("OK"
                        ;Button Field
                        ;Enter Action Here
                        ("Exit"
                                axlFormClose(myform)
                        ;Button Field
                        ;Enter Action Here
procedure(DiplayExit()
        axlFormClose(Dmyform)
GMT+8, 2025-9-11 08:33 , Processed in 0.125000 second(s), 28 queries , Gzip On.
