查看: 2905|回复: 2
[仿真讨论] 好久没发帖,SIlist话题之PCB的损耗可否预测?
发表于 2012-11-26 22:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
故事是这样开始的:有人问树脂含量和损耗的关系。" v  S2 d# M2 x( Q/ C0 N+ ^4 G  \
: I8 u* k7 b- S" z9 bDate: Tue, 30 Oct 2012 08:52:23 +0800 (CST)
: i- K$ h! s8 X! J6 l5 ]- a5 I8 \+ C* w7 I
Hello experts,6 N- r2 z- t7 a7 F) F6 J  L7 L% }8 H
4 S+ H$ x4 ]# h8 b) G> I'm from PCB house.  Recently we have producted some insertion loss test
: I+ z2 S' q( J0 B" r> boards(16L, SET2DIL coupon, IS415/IT150DA/I-Speed Mid/low loss material with : P5 }4 p4 x2 z1 I
> RTF copper foil). We found that the multiply core and high resin PP will " `+ h1 K. h8 T) w5 I5 u" K
> result a lower loss result. It's a trouble to MI engineer.  I would like to
  r5 s5 |" z& ^& j0 U, l> know how to predict the loss base on stackup. Please help to suggest (papers,
# s3 Q- m2 e. ~7 t& {7 C: y> script, free software etc ). Thanks a lot!
% i4 g! V# p. b1 n0 E>
' }4 r# f6 s; C4 e; U! Z>
5 Y; v9 s( ?8 G- d2 Y>; n; t6 ?  U8 r$ Q
> Best regards,
+ N9 ]- P9 l! f  @>
0 x1 o' g2 S; H8 N1 _" D& ~> Terry Ho
: G4 z6 B% T3 E$ \" e
: P2 k2 W' b' f' Q, ^( x然后 Scott McMorrow ,steve weir,Loyer Jeff 这些活跃分子开始依次发表意见.
* J5 \7 ]( S9 L. d1 d3 W, x/ `8 M; `" |  Q* \* @% i2 L, h, \4 K
From: Scott McMorrow <scott@xxxxxxxxxxxxx>8 I1 Y3 ~' C7 {3 U
Date: Mon, 29 Oct 2012 21:02:36 -0400
8 p# t, N$ G/ C! p& D
3 l$ z% g( d; E) R8 THmmm...  I'm in the middle of the middle of Hurricane Sandy.  Power is out.$ d2 y' T0 S3 ?& N7 a
Storm surge is causing the river across the street to rise to unprecedented
/ p1 D; E, C, X7 z' X7 {levels./ t8 b. q) n2 E+ @0 E; i
... and this guy wants us to do his job and suggest free software.4 G, U4 |) P/ W0 K$ e
& j) v2 I+ U# @
: o3 L# v* x5 k0 U- ]# H$ j7 DFrom: steve weir <weirsi@xxxxxxxxxx>+ c3 F4 h7 N, z4 ~' A
Date: Mon, 29 Oct 2012 21:23:22 -0700
; o9 _4 ?* L4 R: N" A: s% r
% B) R; L* W  L/ v3 s, TAs a PCB fabricator I think you need to develop in-house material
# v% f1 }' z3 R% F% G& m4 B2 Tproperties expertise.  Your competitors who understand the materials $ ~' I5 N+ V! @+ }* q& H3 G
they use and their process limits are positioned to get higher yield ) [8 T$ z& L. I5 Z
percentages at lower cost because of their knowledge.5 Y& ]% O+ r( e7 D+ _
0 r( U2 ~9 f# Q- ^' S! s1 sI appreciate that you don't want to spend unnecessary money, but at 5 l7 I! o( o+ i: Q' V# u4 [7 y
least spend the time to learn about what you are using.  I am troubled ( ?; j* N4 z5 b) f* h* L
that your engineer knows so little about the materials you use that he " F3 b0 e0 u# V/ }
is surprised by common results.  Once your company understands materials
/ q5 M" f9 ~4 B3 ?better you may well appreciate the value of commercial stack-up planning / \# ]; w3 L5 [' N; c1 U$ ?. Y
software.
8 p0 |1 p( w. D6 H3 f8 }
( m- J' j9 M, {+ W: OSteve.
2 h- B) G) i7 g
: W! ?2 A4 B7 g; DFrom: "Loyer, Jeff" <jeff.loyer@xxxxxxxxx>1 E- d) J1 v# D( P# {  z
Date: Wed, 31 Oct 2012 21:33:48 +0000
' d( A% _, }+ E% x4 P3 a; y/ L. {" |- C) W3 w
! k2 x0 ~9 A( K# _" O! a, |! _I'm surprised at the tone of the responses to this posting (but perhaps I - X; j, f' r, O7 H) B: v
shouldn't be, unfortunately); I don't see anything untoward in it.  I would 9 {/ B# y. r4 t6 e- [
like to provide some context (with some assumptions on my part) for the message
3 e# J& l) _' Z3 W1 ylest other innocent postings meet with similar fates.  I'll also (eventually) 0 |/ i" J/ w# x
provide my answer to the question, as I understand it.
3 m2 M5 T; m$ M+ g8 ]. g, u. V
4 N* P+ |$ O9 y- p) I
. B- T& e+ ~. B! O5 i* b! q, |There is a significant portion (majority?) of the industry which is extremely
& A3 V' V" e- c, G* j; C0 ncost constrained.  For instance, to them rotating a design 10 degrees is $ z& H# q, U: H9 E" w
impractical, much less 22 or 45 degrees.  Thus, they find other cost-effective 3 ?6 l+ G  {$ d
yet effective means of solving problems (such as zig-zag routing), even though % N& C8 g7 f2 B" V" K
those don't appear efficient to others to whom cost is not an issue.
- Y3 v* g3 F0 P% Q) F! w$ c
# d; b* J" G$ ^- n5 B
/ N  I, m4 }" t& {8 D) ]& p% I2 V4 h0 A6 g4 S* r& k- o5 I! Z
There are new pressures being applied to this segment - designers are now not
- A) G1 L8 P* ~- F/ w  Y$ E  C! Ionly requiring impedance control, but are also insisting on insertion loss 0 S5 I/ B0 R% ~3 F  c4 D0 A2 G
control.  This is a HUGE paradigm shift, very similar to what we encountered ) p; a+ o+ X0 h6 J- Q1 ~4 ^
when traceable impedance control was first introduced.  That was a very 3 V9 i7 E3 [5 n" J5 d
challenging evolution, and this will be also.' d1 j4 Q7 P$ W  r5 n& c; b
# K1 R, i2 S) I  T# G' u  K& g
$ S5 m& H! W* |7 ~; D; ^! `% a9 Z) U& C# e7 F
As an example, PCB vendors are now being advised to smooth their copper, after 4 k- k: \% }7 [+ Z$ Y" k
years of purposely roughening it for best mechanical integrity.  It should come
, I3 b. f; b' s5 W+ ?as no surprise that this is not a trivial change, considering the effort that
6 c0 L" l2 F( {0 U& T! [has gone into ensuring mechanically robust designs.
7 _, ?8 x% |! H8 `3 }) P0 {+ a9 [% x4 s- E. {3 R
6 L# Y" y6 d5 t7 N1 G# m
3 ]! |$ K# l! G. ~
Likewise, many other basic assumptions that we've been able to apply for years 0 J0 c) L2 z3 _& ?1 {
are now being drawn into question, and PCB vendors are looking for help to ! v" {& c2 L3 m
intelligently and cost-effectively explore options - "How much effect does
8 U& G# Y* E& z8 v( r6 lrougher copper have on insertion loss?".   I believe Terry is highlighting the
; h5 X3 O7 F' g& F8 f) ~fact that, while there are many tools available for impedance prediction, . s1 M8 ]7 A, i0 g
insertion loss modeling is much less accessible.   I don't think it is
: v" g' x3 D' A" z8 j- xinappropriate to ask if there are cost-effective, reliable tools available to - _' }& m2 O& X7 U* [2 z
predict insertion loss based on a proposed stackup.
* {, M; n4 m; J. j( u+ h
+ j/ E& R) H* J$ J; Q, S
' |5 p3 {" b2 y& Q" y4 v3 [
. V" }6 J. Y4 BUnfortunately, I believe the answer to the question is that there are no
( i! Q5 `2 m  s9 }. m- Areliable, cheap (~free) modelers available to predict insertion loss.  And, the
: w0 \  {$ q# f$ d, [0 Eones that are available require a great deal more knowledge about the stackup
! g# P& C5 N) e. p& A+ ^. wthan impedance modeling does, and that information is not easily obtained.
) Q& J8 n% T! ]/ z* nThere are some of us working with a vendor to test their modeler against a
2 n: q( D5 U, V. d0 \+ _$ avariety of stackups and we'll present results at DesignCon.  My personal goal
$ V6 D5 y$ F  e: N8 Tis not so much to test a specific modeler but to judge how effective a modeler : G6 D4 X4 R& y
can be given information that can reasonably be gleaned prior to building with
9 [2 D4 ^2 |0 `6 k7 ~! e6 wvarious materials, copper types, etc.7 ^! c8 d  A) f1 u2 h1 }
# K% d, i& g6 y. X; F; k7 a
$ W* z5 ^* B& y" |
# i( {5 X3 t( x' n
In the absence of a modeling tool, or in addition to one, I believe empirical % F6 C- J- q6 k
data is the best predictor of insertion loss.  To do this, however, you have to 3 w; U0 v$ M- m' L9 y
build a stackup representing the final design, and it's not clear at this point 8 t3 V- k5 k& I2 C9 z
how broadly you can extrapolate those results to other stackups.  But, I know ) [; y& @5 b5 q! M
many material vendors and PCB shops are engaged in similar efforts.
; c3 [$ [4 R) F: H6 b% J  L0 z! K* q1 Q6 P4 w& C
$ `4 ]9 P0 ^0 ]  ~1 B- q6 Q8 c- c% M2 G
I think this is very similar to what we went through with impedance control -
: d) ~8 e- f$ [the shops which most quickly were able to predict and control that
; m9 r$ ]: U/ V/ o: X- |# |5 d4 echaracteristic had an advantage.  I think successful PCB vendors will need
' F3 B4 L9 ^/ J4 Z( y5 U! |reliable modeling software and empirical data on insertion loss for their
- o4 y; I5 }0 a; \  yparticular choices of materials, etc. - they will be able to find the most cost 4 t* E# U/ s, K2 M/ X8 A
effective solution.2 t& o6 S( _7 o) S* W
- B! n* ]  j& \  y2 ~1 k8 c5 ^( J8 B+ C6 y
3 [5 }, M& P6 A5 G
Bottom line: I doubt a reliable modeling tool is going to be cheap, but is ( I! H; \& F7 \- ~+ f& k8 }
going to be necessary, and you'll want to compare any tool you do purchase
- F4 i1 n3 d4 Fagainst empirical data before you trust it.5 @2 u0 A- K* o, Z# X, }
: D2 `8 W& v; S2 Y3 Z
; L/ s0 j; D! E2 q0 [+ n0 i/ K) n+ Y4 a' M
I hope this helps,
% z% g1 M* H! _& w- ]3 {" D, \/ h3 ?, X3 B4 `% {
Jeff Loyer
5 I+ T+ e& `6 ?3 l' f) a$ D1 r2 C1 W9 F/ w  x
% N5 \: G4 |* d1 h* ^
3 g- Y6 l' L7 S8 e" d) ]Date: Wed, 31 Oct 2012 20:14:41 -0700
0 X6 c) T$ G$ n% c4 a3 q( w- j$ z2 r6 m: D7 N1 L3 B
! @6 }0 V/ Z  S6 H/ k5 U0 `
Jeff, given that the only two responses were Scott and mine, I am
9 v' k/ s9 ?6 w# y' I" e) m1 b' j5 [% jsurprised that you are disappointed with both.
; B7 q$ `& e6 \1 B7 U0 f/ R. S; `8 P" j6 {6 `6 b0 s
In a fabrication market filled with intense competition it is up to
! W$ U' C5 T2 q; ^individual players to keep up with the technology requirements of the
2 r& K9 Z1 l4 Omarket or get left behind.  The task is not simple. Depending on how far $ ?+ J+ |& P) r4 v& t% _" _
up the frequency range one needs to go, dialing in cost effective
! z: L; n9 `" f' Q5 X( J" L9 C2 Mprocess requires substantial skills, time, effort and serious money.  It / H/ I+ [* r; r1 ]$ V
represents competitive advantage to OEMs and their partner pcb fab
$ u2 S! X& R8 j. K0 R9 hhouses alike.  Neither who have invested are likely to hand over that : Y+ I; g% [0 X. Y2 H. r
kind of advantage especially when it is so costly to obtain.  N% q0 M3 E" Z# U
9 H. {& {! d) K+ x
I don't mind that Terry is looking for a solution on the cheap or free.  ( n; _6 \5 U, t$ p3 G* j8 G) c
If one could obtain such a sweet deal, one would be foolish not to take
7 `) K6 x7 }" h( H9 ?it.   I am troubled that in this day in age, his organization hopes to 6 L6 F. d1 i3 m
address a sophisticated issue before his technical staff has a grip on . M3 d3 a# Q% x$ I
the basics.   I fail to understand what you find inappropriate about # M9 a; X2 j0 B/ g8 f; W) Y% e  V/ D
that concern.  I would rather yell at someone headed for a cliff to stop
$ K& Y* J! V# e& ~! S. tthan smile and wave.: q7 e$ o% x! T; A# e
1 i/ l: U( W( ?4 m1 O5 T* oBest Regards,4 a' J1 }8 Q' g7 B5 U4 K, z! q( G
* p# z- t: h" y7 S, P, G6 s! k3 a: N
Steve.
4 d+ q+ w8 ]' w, d. O. {) C( e( L% o; N/ G9 J
5 V+ p& y- q4 j0 n3 K% N" vDate: Fri, 2 Nov 2012 15:37:46 +00007 J; h7 Q4 L/ M2 I! J+ p
# V2 A6 Y% q- b) g  q- M; w+ N: t
0 J* ~0 B7 i; L8 j' Q( |6 s
I realized we hadn't answered the basic question - "why does a high resin 6 Y% O. o2 N0 l0 }
prepreg give lower loss?"  The prediction of loss vs. resin content isn't 7 g# ]0 `! T# q. N
trivial; as Steve said, a tool which allows you to model loss for the various
9 F  R2 B- w, X0 U' ~% ?scenarios should be on your Christmas wish list.  Here are the factors that I
9 [; |: v; x# o- G" F8 Iknow of (thanks to Richard Kunze for clarifying things for me, and I welcome
3 |0 f- h% s5 p/ v8 U1 eothers' data/opinions):. G' |4 g, t# N1 Z. J) c! H
* Resin has a lower Er than glass
8 C7 I2 ]3 n* F# L" O& P0 ]/ L9 _
& [0 m! |! Y0 U/ d( s, E# c     * loss is approximately proportional to Df * sqrt(Er), so lowering Er
, }, I7 f& n0 ~1 d" s+ Jlowers loss
" r: [! ]& P1 ~6 j" ?
5 w& ~& Y, A' C5 f% a     * lower Er allows wider traces for the same impedance - this may decrease
/ ~9 T, S1 Q, \2 ^! J" O! Floss also: h8 i3 O" X4 ?  {: Z
6 ?. t3 L3 k; U/ Z# {# k" p
* But, resin is more lossy than glass, so Df may increase
8 n3 G3 W  n  g0 J
0 Y# M( D( E7 G. R5 a8 P1 f     * for standard FR4 constructions, this is especially true.  The data sheet
: ?) e$ _8 l8 U% @) [; |for IS370HR, for instance, shows Df varying from 0.0177 to 0.0247 (1GHz),
- O( K. c% k2 Udepending on the resin content, g; \8 ~& S% ~: @) I
# d# W6 ?* j: w9 {     * for low loss materials, this doesn't hold.  The data sheet for Meg6 ' j, Y) ]% D7 y
shows Df constant (0.002 @ 1GHz) for all its flavors of prepreg( U) P/ k3 x! n" D
5 V; k, R% O7 T* t* S  {/ e* Where the factors dominate will depend on your relative conductor vs.
* V' U: y# T# W6 ~9 i7 I! Udielectric loss effects: for FR4, dielectric loss dominates at >~1GHz; for 7 y7 u/ I# b- q- h7 a* C
low-loss materials, conductor loss dominates up to much higher frequencies (as
: K: o2 y8 w( Gmuch as 10GHz).! `: `- D' N8 Y3 l
) Z5 F: |  T2 Z6 [' R
9 s& ]0 V; H/ Y, C* j! q0 |' p
8 z- }3 y" r( w& x5 z5 V2 FIn your particular (low loss) case, the lower Er of the resin-rich case is
. P3 k* C* g. c) U% Btrumping the Df change (or lack of) so you get lower loss.5 |5 v3 o% @1 {: G
3 j6 w; ~3 @" U4 @) A
0 t' Z. ^  l" r( s% F
& f1 `6 R* R! Z. _  `+ NOnly a tool which takes into account the properties of the specific material
" d; K% X4 p# p& Q% n6 xunder consideration can be expected to give an accurate prediction of insertion
* k5 Q: y4 R! M0 Z. mloss for various resin contents.
+ u+ y0 P" _* M$ n
( M# s4 n; z& A+ ^" U. O
: D/ a2 M0 h( c1 H4 B, g* s# b- o# |+ _/ @9 n3 @- e  J
There are also environmental effects (I haven't heard or seen these stressed at
6 ?' Q1 i1 y9 y* N# U: M; sthis point, though that may change soon):2 t& i' a' e' u- _. s
$ `4 N6 @" _. \( V: P, P/ @
* Higher resin content will absorb more moisture, and thus your loss will be ) |% y5 u# v. i* n0 \# p
more susceptible to humidity effects
$ b* R" h/ T  h* e# D! T3 w. J! ^- i/ ]6 e- K
* There's a difference in how the various materials' Df changes w/ temperature
1 ^$ i# g, X+ U' S# E8 o- more at DesignCon
7 l/ \" e" r  O, m* w1 @, A4 J
8 G7 H" x. d7 N6 u
, C9 m5 G. G8 @! p  \& s' T  M
) N3 o4 U. f. l3 y, U7 e. j7 EI hope this helps,; ?7 V+ h, K; G! l2 B
" I4 P  m! t. qJeff Loyer1 r; ]- H  i4 I4 ~  J9 S' |8 r- a
& Z1 p3 o/ n* [6 n& ?! d
2 k, L# c/ g4 @% q; ~Date: Thu, 8 Nov 2012 09:12:46 -0500
. U( h7 k4 j$ e% d6 F" h- v4 v5 u0 q9 C2 j2 ^
3 W# r- e( k4 Y; G- T! B" t" SJeff
6 b4 ^, J1 w' F7 xA few quick comments.  Although the tanD of Meg 6 is stated to be flat, it' N8 ?- S8 D# N- o. f
is not if you measure it.  The manufacturer reported characterization in
" ^/ [4 I' Q- g; h( N! F! c# F* h+ fthe data sheet is not correct.  Causality is violated when tanD is flat.
7 ^% z4 a9 l  w: n$ C7 ~) T% l
) X& r2 @( F; q6 z' a6 NLoss is generally due to molecular dipole losses in the material.  It can
2 o: \, i+ {9 |/ x) K2 Gbe low for high Er, as is the case with ceramic.. x4 J* P4 Y) l2 ]
4 \) Z3 ?  u# X) D* qHygroscopic loss is due to molecular polarity. Polar molecules "glom" on to* C; U" P+ E# F$ _1 c
water molecules, which are also polar. Same property makes the material' a: p8 g( F- R8 j# d& Y
extremely "sticky.". u$ ^- U6 Y! D4 Q4 R% h0 n
5 j5 C: Z2 A! d' ~8 S0 f& y# q
The paper that Jason Miller of Oracle and I wrote for DesignCon last year" v$ N: h( m/ _' H. F& _2 M5 J' W
covers some of the impact of temperature and humidity on measured losses.
/ T2 |( D! r2 n6 B5 r+ h$ d/ T9 f I don't have access to my storage server right now, otherwise I'd give a5 m# W3 @/ |2 p6 y. V. z. ^; [
paper citation." j9 q- l8 G7 g, t6 U' C8 C4 n& A
$ i; Y8 H8 n. z3 Y
regards,% o) }% x( ^- X4 e5 n4 ^
3 M4 V  D0 z# @& H5 x# PScott
$ C- Q) p. x$ u) f- S7 _9 Z
( q, ~* U) N; fFrom: Kirby Goulet <kgoulet@xxxxxxxx>
( u' q% Q1 f3 [! EDate: Fri, 9 Nov 2012 11:08:49 -0800 (PST)- Q- ]# h$ F6 W5 h6 A1 h+ L
: x& ^9 c* P6 |' F 1 K- |& ]9 R8 E$ J0 R$ p4 W
It's not production quality software but you could try the mdtlc calculator to ; L5 d8 W! u" @' b
experiment.  I tried Jeff's example and it seems to point to an explanation. 9 @2 F/ t2 g9 e) E
The source code is available so you might extend it to do what you want if you
, C& X/ \: X1 l# I( i  U; Y+ Ghave more time than money.2 x8 B+ |/ s/ H! ]* n# W- J
It looks like a race between loss due to increasing loss due to resin and ' f3 |6 X3 L4 v1 S
decreasing loss due to wider traces.  There is a bigger increase in the resin
' N4 v% k: x) J" ccontent for the IS370 case over the IS415 case.  Not only that, but the IS370 - I( g( L" H3 R" ^1 J2 |: S! o
resin is lossier: 0.0169 versus 0.02984 so the winner is increasing loss.
$ f% p/ }+ e( s1 Q& I0 r
9 l! s* h! i/ A, j+ TFrom the field solver, % e5 H& f; ~- F# }: G6 {/ X
  i+ t6 b* Q8 S" ^- d8 h
IS370: the effective dielectric loss went up 14.7%.  The perimeter of the
3 {; E3 H; |1 _7 @0 ]conductor went up 3.6%.
$ C# A6 z6 G! O- V: x! k) VIS415: the effective dielectric loss went up 6.7%. The perimeter of the
' T4 D8 O& c2 R' \2 |. L7 gconductor went up 5.7%.
* z8 H% a( K: B7 D9 Q0 B) M; m3 S" ~% N
In the second case, overall dielectric loss is a smaller fraction than the , O9 Y( w. N6 v2 n) t5 v9 A
first case.  The missing bit of information you need to add is the conductor
0 k5 d- u0 C4 }9 Zloss.  M, k7 M7 r% _# Y- _# L5 D" r7 T  J
3 K$ }0 `: `3 h0 qINPUT PARAMETERS:; a; \/ s+ k: \, w
4 t6 r' {& g) i) [8 S
      Layer             Thick   Specifications % F! W' c- G5 N8 s
      Copper Plane Top   1.30    Opening w=0.0  offset=0.0
; D* y# i8 _6 t! i- S( M! W      Laminate Layer 1   3.90    Resin Content  57.0% 3.4-4.9 ! u5 J/ ~' T, ?% A
        Signal Layer 1   1.20  4.3-7.2-4.3  Etchback=0.000 f+ `4 Z3 S2 b- ?' n' X- n
      Laminate Layer 2   3.90    Resin Content  57.0% 3.4-4.9 $ A/ r/ w& T+ l1 b4 m$ f1 ]0 g
   Copper Plane Bottom   1.30    Opening w=0.0  offset=0.0
. ]! t6 _5 O9 a" ]% `3 c  I& R$ f
" V! w! G! c6 F% n- V      Layer             Thick   Er    Loss Tangent
; W' ^( [+ s3 c# R      Copper Plane Top   1.30  3.20
0 M  i9 P% S, M' P+ f7 Z      Laminate Layer 1   3.90  4.02    0.02100
+ C8 j% t! F, C4 L& C3 d        Signal Layer 1   1.20  3.38    0.02984
" ]6 \( ]0 g6 p' b' q      Laminate Layer 2   3.90  4.02    0.021005 ]: P& w- z* I$ _3 X# ?3 r# C
   Copper Plane Bottom   1.30  3.20
  j% S$ B, M& D3 A! k8 u+ K6 C
5 W4 _$ U  l& u4 g6 @* x7 t DC resistance by dimensions:
! ~/ H" t& H  S& T& c7 W9 |" B Rdc_trace_1= 131.53      Rdc_trace_2 = 131.53  milliohms/in 20C
: n" A5 _9 Y( J - M4 I2 [4 u1 q- D" a) r; a
DC resistance by pixel count:/ B* O) q) k$ n4 A  |
Rdc_trace_1= 131.531     Rdc_trace_2 = 131.531 milliohm/in
, i# L0 D. r# l8 q3 ] C_odd      =   4.221 pF/in    C_even =   3.968 pF/in
1 c& l/ w* H+ |7 Z. T9 l Er_odd     =   3.923         Er_even =   3.947) E4 A, h% B+ ^* F
Loss_tan_o = 0.02212     Loss_tan_e  = 0.02184  : z2 `; W) o9 X: {0 @& d
Delay_odd  = 167.801      Delay_even = 168.314  ps/in.
2 Q* m6 [* v0 y8 b1 Z& l0 y. Q0 s* O Z_diff     =  79.501  ohms   Z_comm  =  21.209  ohms
4 h9 f0 j1 F- o2 n
4 Q( W, ~8 {5 {4 Z; J+ nSimulation pix map 122 pixels high by 800 pixels wide.0 H# a. a9 W: d/ ]6 n
293824 bytes allocated for bmp.
+ _; M4 F! J+ g( n& {& g6 I% y # b9 n# L. V( l$ ~- E  i, N
INPUT PARAMETERS:
4 v- w4 ^3 P4 L: }$ L- w
$ z2 e4 i/ G- U* U+ ^# N      Layer             Thick   Specifications 7 F- m! p/ v. o
      Copper Plane Top   1.30    Opening w=0.0  offset=0.01 }) _0 a  _/ w+ i, Q% e' r, m
      Laminate Layer 1   4.20    Resin Content  75.0% 3.4-4.9 / P* ]* r' @7 H# t# ]( E: J9 w1 ~2 @
        Signal Layer 1   1.20  4.5-7.0-4.5  Etchback=0.000 e% P# D/ j* b2 R, Y* l) W" N
      Laminate Layer 2   4.20    Resin Content  75.0% 3.4-4.9
6 R" ^- i/ G& `8 }6 ^* y: o7 {   Copper Plane Bottom   1.30    Opening w=0.0  offset=0.0- J( I! ^/ W. X! g. r* b
' B4 Z# M" X" ]' W& z7 c* u      Layer             Thick   Er    Loss Tangent& \0 p  f. y8 f( X  g5 [. d4 W; c
      Copper Plane Top   1.30  3.20   8 D4 [" i: Y1 Z$ o
      Laminate Layer 1   4.20  3.75    0.02470 ' y9 `/ A9 x4 B( n* c0 y
        Signal Layer 1   1.20  3.38    0.029848 X, ~6 K# t% p, l+ T
      Laminate Layer 2   4.20  3.75    0.02470
9 }: |: \0 G) ?' ^8 T7 S   Copper Plane Bottom   1.30  3.20
  f& B" A# V; D) w7 l9 Z/ d. e % ~) \1 V6 k- L8 k+ [
DC resistance by dimensions:+ `1 O4 ~  d' W# p0 ~
Rdc_trace_1= 125.69      Rdc_trace_2 = 125.69  milliohms/in 20C1 H7 d3 C: P# u/ g$ g' U
' t, b# X; P/ B DC resistance by pixel count:3 S+ o3 F7 o6 o) Q: v( N  g
Rdc_trace_1= 125.685     Rdc_trace_2 = 125.685 milliohm/in
$ `; @" A. X7 z7 S0 t C_odd      =   3.929 pF/in    C_even =   3.624 pF/in
3 v6 X9 \7 X# q. b8 O7 x' U7 r1 ] Er_odd     =   3.694         Er_even =   3.710
: M* m* a1 {$ ~( J3 E3 z' I2 y Loss_tan_o = 0.02537     Loss_tan_e  = 0.02518
, s! b+ Q  `; A2 t4 j8 _) B: B Delay_odd  = 162.844      Delay_even = 163.195  ps/in.
+ Q, o2 i5 j% H2 L+ S! G, H Z_diff     =  82.900  ohms   Z_comm  =  22.519  ohms
5 a) U2 l2 W6 o
, C9 l& ]# E+ J( H. f* CLog file save name:1 a# Z" R2 ~( t8 S/ }
mdtlc_12100946383.txt
2 y6 ^! c% c% W+ b
& e! D" b4 G7 P/ H& @$ uSimulation pix map 118 pixels high by 780 pixels wide.3 A2 |; O, j9 j# l' K0 e8 {; i& Y) h
277144 bytes allocated for bmp.# ]( ?7 ]2 c: J: w
/ P/ }  i: l$ Q2 [; F
INPUT PARAMETERS:
1 j, k- c' k% l1 O: _; F " \$ R8 k# [: ~" \, c
      Layer             Thick   Specifications 1 s" b7 {1 k, B. V8 H$ x
" u9 K7 A6 d7 q  |' N      Laminate Layer 1   4.00    Resin Content  45.0% 2.6-5.1
; |+ o0 ?' b/ |$ e; m! a# n! t$ q        Signal Layer 1   1.20  4.1-7.4-4.1  Etchback=0.00
6 o/ ^4 z  q% o% o' |( k      Laminate Layer 2   4.00    Resin Content  45.0% 2.6-5.1 # j  x* Y7 K5 V$ `- `
% g4 V) g0 Y7 l: X' X % o& f% _8 h; G2 n. N# \  x
      Layer             Thick   Er    Loss Tangent3 J2 m7 a" R0 g, i: F2 X
      Copper Plane Top   1.30  3.20   . S3 P+ m+ Y1 N4 d0 m+ A
      Laminate Layer 1   4.00  3.98    0.01140
) R" E3 Y& t2 `  }# f) H        Signal Layer 1   1.20  2.64    0.01690
- n" w/ {1 t# h- }0 H3 R) ~      Laminate Layer 2   4.00  3.98    0.01140
, w: b3 g% k- Z0 B5 g! S- u   Copper Plane Bottom   1.30  3.20" L, P  [5 R) g6 g) z3 k+ W- ]. g
! z( f# Z+ ?7 ]- @1 e5 ] DC resistance by dimensions:3 a, H7 g4 A  b0 d' W2 N
Rdc_trace_1= 137.95      Rdc_trace_2 = 137.95  milliohms/in 20C
( o3 u! S+ Q! F; V7 g, D ; J! m; r, a8 g- o
. F. ]$ x* s" Z, V Rdc_trace_1= 137.947     Rdc_trace_2 = 137.947 milliohm/in* A- I9 s$ v) B- d$ P( y
C_odd      =   3.910 pF/in    C_even =   3.695 pF/in
# @/ w+ B# J% I4 r3 _+ f: x Er_odd     =   3.769         Er_even =   3.817, [* d! b. U4 D' \' |0 ]
Loss_tan_o = 0.01202     Loss_tan_e  = 0.01189
' }! M) t; K1 _' `/ f5 z8 J Delay_odd  = 164.490      Delay_even = 165.524  ps/in.4 d( d$ P2 `- A/ b3 K2 W
Z_diff     =  84.134  ohms   Z_comm  =  22.396  ohms9 w0 P( w/ ~2 d, t. [
9 V0 Y; H' w- R
Simulation pix map 118 pixels high by 795 pixels wide.
+ ^& a, K4 m9 F/ f3 s  H0 g/ G282454 bytes allocated for bmp.8 c3 C6 l9 Y7 t; h# h& {. J# [
; H' {0 g( ~" h! i; B
INPUT PARAMETERS:, q0 ]0 ?5 }2 t+ I2 }
7 b4 }& P: Q) I$ [
      Layer             Thick   Specifications 0 B! z$ {1 J) m) @+ _) }5 p
      Copper Plane Top   1.30    Opening w=0.0  offset=0.0- E$ L( _+ ]; O# |- e" [# f7 b5 I9 L/ ?
      Laminate Layer 1   4.00    Resin Content  54.0% 2.6-5.1 . L; A2 H. Y) ~2 ~
        Signal Layer 1   1.20  4.4-7.1-4.4  Etchback=0.00
- r! @# T6 a) j3 a6 C1 b      Laminate Layer 2   4.00    Resin Content  54.0% 2.6-5.1 . F6 ?0 N( A& g6 \- O8 J
" d0 t3 C2 m3 E( S* u # S9 ~. ^$ B# w
! h( r/ p, J2 I# c  U5 u      Copper Plane Top   1.30  3.20
7 K2 O5 |, c, I/ T: R      Laminate Layer 1   4.00  3.76    0.01230
( Y$ w- J6 P  I% ^5 _        Signal Layer 1   1.20  2.64    0.01690, x; F9 g9 v. z& A. `  ?
      Laminate Layer 2   4.00  3.76    0.012302 B' a# I3 |! o$ C" ~6 S' p
0 H2 L: x9 \  G1 O
2 n5 S* P; e1 ]: g( L2 } DC resistance by dimensions:' ^% P2 K; `" e0 C; P$ Z6 N# R
Rdc_trace_1= 128.54      Rdc_trace_2 = 128.54  milliohms/in 20C
. M* L6 C) V/ m0 s 1 y+ t6 b! g7 Z$ M
DC resistance by pixel count:% j/ u5 d7 z" q6 _' N2 S
Rdc_trace_1= 128.542     Rdc_trace_2 = 128.542 milliohm/in
$ x) ]5 X* h% z/ j% i C_odd      =   3.865 pF/in    C_even =   3.623 pF/in6 p/ n% s, t) q) t5 B+ y
Er_odd     =   3.588         Er_even =   3.631& ?" E" _- z8 j
Loss_tan_o = 0.01283     Loss_tan_e  = 0.01270
) _& P" t& K9 G5 M2 q( o Delay_odd  = 160.480      Delay_even = 161.455  ps/in.: e, r: }3 y2 r2 P
Z_diff     =  83.041  ohms   Z_comm  =  22.280  ohms
7 V; }" S+ V( l( }% O
0 D) j) d1 C) `% l看完之后,我有一事不明,我总是分不清奇偶,不知道这两者到底如何区分,亲,你能告诉我吗?
发表于 2012-12-1 14:21 | 只看该作者
我以前也分不清奇偶,后来强行记住了even是偶,搞的后来一看到odd,就要先想even是“偶”,odd只好是“奇”了,很是麻烦!
/ ^2 H1 F& M" C' `, {2 x" v2 x0 Z你这一提醒,我以后可以换个记法了:odd是3个字母,“奇”数个字母;even是4个字母,“偶”数个字母。哈哈
参与人数 1贡献 +4 收起 理由
beyondoptic + 4 方法很给力
发表于 2012-12-23 21:19 | 只看该作者
晕, 版主居然转贴到这里来了!. Y7 I3 V/ w4 ~( R5 r2 [
汗!!!{:soso_e110:}
GMT+8, 2025-8-3 11:55 , Processed in 0.156250 second(s), 27 queries , Gzip On.
