cadence最新版软件SPB 16.5及其Hotfix下载链接如下:
9 f! m4 g8 C" W' }( [http://dl.vmall.com/c0t5v9lbyp& f/ H: r: y; |# u3 n, {9 O
Hotfix中只需要安装最新的版本即可。: h# L4 @4 J/ O) x* N- K8 k
3 J, q( Q" a2 i# l* j OHotfix033对以下项目做了修正:
& d* h& R% l6 d/ ?& U5 u- pDATE: 10-31-2012 HOTFIX VERSION: 0330 j' U4 J) t7 y. a4 f
M" Z/ O" p/ J6 \9 sCCRID PRODUCT PRODUCTLEVEL2 TITLE; c2 l" P% Z7 u5 _ Y
===================================================================================================================================! I6 h) `. a; x$ p0 ?
103395 COBALT-COMPILE COMPILE et3compile fails if compile for 3 boards in 32bit mode& h% G: y/ H: h" a D1 S7 g
715653 Pspice MODELEDITOR Change in pin number assignment with model import for capture symbol
* f) ?& Z8 c' O7 ~: F8 E/ _* j745682 concept_HDL CORE Attributes window requires resizing each time DEHDL is launched, o; A1 C, [5 S+ G" _% z8 c
825846 CONCEPT_HDL CORE The module_order.dat file gets corrupted1 h: m4 g K) {9 B4 J
846658 CONCEPT_HDL CORE About Change the NOTE with DE-HDL
7 n* Z# U- L N% W3 J938977 CONCEPT_HDL CORE Properties attached to standard/DRAWING symbol does not propagate to parts placed in the schematic" W' t% R$ p. s( W: J4 a
942044 CONCEPT_HDL CORE ConceptHDL crashes while opening the AMS project
% i: ^8 q9 w, z I( b$ F946640 CONCEPT_HDL CORE Import Design should inherit module order defined in the imported block0 C/ D* K& i4 q5 D( w3 ]
968646 allegro_EDITOR EDIT_ETCH The Cline to Pad spacing not followed for Multidrill pad it is more then minimum spacing
; x3 w' o: [3 x2 s969535 CONSTRAINT_MGR SCM ASA retains information in the DCF file for parts/blocks that have been deleted and this causes problems.
, S. y$ s' G" R" r7 [976723 ADW MODEL_MANAGEMENT SI DML Model has to be provided the Auto Generate function for discrete components on DBeditor
$ y+ Q; C7 n/ |; n6 z981767 SCM UI Add series termination in ASA will crash if both output and input pins are selected.
/ {8 O. i; S7 c" v& V- v8 k/ Z, O& u988355 PCB_LIBRARIAN CORE PDV moving line-dot pinshapes left to right or visa versa places pintext wrongly
; w0 l" i9 d3 o4 T& [' B988438 CONCEPT_HDL CORE Visible constraint disrupts MOVE command
d" y7 {9 N& E# N993562 CONCEPT_HDL INFRA After upreving the design save hierarchy is leading to WARNING(SPCOCD-34).
- _0 |0 v2 a, O+ Y1 o) v6 Y996577 SPECCTRA ROUTE Specctra not routing NET_SHORT connections
]2 z$ I4 E: o. ?8 \' a997992 CONCEPT_HDL CORE Why are Page Numbers not enumerated correctly when multiple TOC Symbols are used? e9 a% Q6 z7 T! w) U# T" e
1001300 PSPICE MODELEDITOR BUG: Simserver crash with encryptedm model# C C! Q# O; F) K$ B6 @
1006400 SCM OTHER Incorrect warning in SCM due to way voltage value is stored in tabular and schematic blocks
- H$ J1 D& s1 V' U( d& h1011502 CONCEPT_HDL CORE Undo has an error on circle in DE-HDL during create a schematic symbol4 Z& ^* q' I" O9 D
1011798 ADW LIBDISTRIBUTION generate a differential report on parts in DB vs parts in PTF while running lib_dist/ R4 g9 k3 e3 g' Y! l! B3 n
1012685 SIG_EXPLORER INTERACTIV SigXP: traceEtchFactor value is not used.( \. y& h6 h. a# V; \/ u+ g7 L
1013656 SCM OTHER create diff-pair should honour diff-pair setup or ask user for positive negative leg
7 A& J: l+ K7 Q1013721 ALLEGRO_EDITOR EDIT_ETCH Routing near a 2x3 multi drill padstack does not maintain the spacing constraints.7 G& b2 {/ M3 L9 \6 V
1014319 CONCEPT_HDL CORE renaming HBlocks leads to crash
9 k+ m7 i. O& |1017724 ADW TDA TDO update should force the schematic to re-read data from disk4 w; U8 ?. r X e
1018506 ALLEGRO_EDITOR INTERACTIV Edit copy with retain net of via will assign net to pin! A( `# @; m5 n, j+ \5 q/ ]
1019979 SIG_INTEGRITY LICENSING extracta batch command result is incorrect8 x1 \7 V |3 L3 z
1020746 CONCEPT_HDL OTHER PDF Publisher tool behavior inconsistent between OSs+ g) v& Z7 t4 O L ?
1023051 SCM UI Wrong and incorrect message is generated while adding connectivity in SCM matrix view � DSTABLE-1406 u) W, E8 w* @* n6 ]0 \; j
1023057 CONCEPT_HDL CORE Strange message when opening DE-HDL - INFO(SPCOCN-2055)8 P0 N" C% y& F4 c) h9 F
1023281 PSPICE AA_PPLOT Bug spice advance analysis parARMetric plotter stops after 6000+ runs' \ M9 o4 F. s0 e
1023702 CAPTURE GENERAL orcad Capture/CIS copy and past page to other design Issue' h) m( c( c R: E7 q- s: ^& I
1023807 SPECCTRA GUI Unable to close SPECCTRA using File > Quit or by clicking on standard window red close cross button
7 j# ?/ G- `4 P( M2 o8 n1024890 PCB_LIBRARIAN METADATA con2con -metadataonly does not find footprints
2 S2 i* A; S4 _. L) X; A4 b7 W1024899 PCB_LIBRARIAN CORE PDV symbol pins grid select all does not respect the filtering9 O4 C* y! i( S6 p
1027147 CIS UPDATE_PART_STAT CIS gives ERROR(ORCIS-6274) when updating Part status from Part Manager1028237 CONCEPT_HDL HDLDIRECT Error binding design when generating simulation netlist8 a B" C( D% ]( G# V' f* `" B
1028432 SIP_LAYOUT DIE_ABSTRACT_IF Support pin numbers in die abstract flow/ s5 L/ ` i5 j* p# Q3 y$ a6 F
1029369 PDN_ANALYSIS EMVIEWER EMViewer: Unit of Current Density.8 P5 n1 ]" V3 a1 R8 s
1030591 CAPTURE LIBRARY Library Correction utiltiy locks the library and deosn't frees it even after being closed
3 b7 `% b# x+ E! s% f7 q1031474 CONCEPT_HDL ARCHIVER Uisng Gtar as the compression utility causes the 'delete archive' to fail
" w2 k2 Q5 ^- R* z9 f+ E) A1031765 PCB_LIBRARIAN OTHER librarian_expert feature is kept checked out for two hours
6 ?0 T$ R) y- v# V5 @1032703 F2B DESIGNVARI Enhancement Replace Variant Component form needs to be resizeable( w3 d! \7 B+ } t# S; ~
1033607 CAPTURE NETGROUPS Capture crash if netgroup instance name has square bracket 縖�
/ [2 k( [+ |8 E1033853 SIG_INTEGRITY OTHER netrev crashes when importing logic
$ T9 A" h( r0 B3 f, e1035624 CONCEPT_HDL CORE Options pre-selected when launching base product: S6 ^$ m2 G* E' K3 ^
1036580 ALLEGRO_EDITOR MODULES Module created from completely routed board file has lot of missing connections in it.$ n. {+ n6 {4 q/ U( k, \4 L
1037345 ALLEGRO_EDITOR INTERACTIV Enhance Allegro's Snap-To tools to select the origin of a sub-drawing(clip file), Q0 L: I1 i. H# a5 N+ p/ j) i
1038180 ALLEGRO_EDITOR DRC_CONSTR BGA escapes not being calculated in phase tol; V% j% R& ~4 s4 Z8 y1 T
1038285 SCM UI Restore the option to launch DE-HDL after schgen.% P3 M1 ~, A4 G, P) y# B8 o# ~
1039147 ALLEGRO_EDITOR COLOR Need an option to change color of Text marker and Text select in Display listing
( M1 E5 Z+ T3 ?4 L9 C1040257 CONCEPT_HDL INFRA New license files causing slow tool peRFormance: m1 W& j3 F: o4 Y3 Q$ x% E
1040575 CIS CONFIGURATION SQL database views are not visible in CIS configuration step 2.# o* v' J' [4 j3 s3 U2 t2 C
1040678 ALLEGRO_EDITOR MANUFACT Text spacing is inconsistant for top and bottom SM layer in xsection chart
3 z( l; e/ f' D, u1040869 CONCEPT_HDL INFRA About uprev problems to SPB16.5 from 15.7, u% t1 a: a9 A6 p/ Y M. i8 J$ H7 {& S
1040976 PCB_LIBRARIAN CORE PDV replace pinshape on Linux shows very slow performance compared to Windows/ X. Y. D- K/ Y7 F) L. _! d
1042603 PSPICE SLPS About SLPS simulation interrupt; L x- X7 Y" W8 P: j' g# _
1042695 CIS CONFIGURATION Can't see database views of an SQL database in CIS configuration
" R4 G* Q! t4 R1043339 CONCEPT_HDL PAGE_MGMT The .con and .xcon files aren't being updated.
: y: e/ P+ l8 {8 j z6 L' b1044029 PSPICE ENCRYPTION Encrypted lib not working for attached
4 L H- L, f1 V6 B# }7 L5 \# T1044222 ALLEGRO_EDITOR INTERACTIV Capture Canvas Image changes working directory/ l' j0 b/ ^0 a
1044264 PSPICE SIMULATOR Why does the 'ORPSIM-15009:This device scales to 0.0 at this Temperature' Error occur.2 K5 I) n* n4 g7 F `6 b" `
1045607 ALLEGRO_EDITOR OTHER Component get placed even after Cancel IDF in form.
, k) I, w# L1 y1045609 ALLEGRO_EDITOR PLACEMENT Statement in the Viewlog for Update Symbol needs correction# w- i2 Q. x1 x3 @4 V
1045694 CONCEPT_HDL INFRA Why to package the design twice to pass the net_short property to the board?& d+ ^: V0 N; Y$ x8 A
1045734 ALLEGRO_EDITOR OTHER Missing padstacks and layers information in cross section chart" J7 _% |% ^, Y4 g
1046929 CONSTRAINT_MGR OTHER Unable to create physical of spacing cset after rename the default cset in design entry.
" o E7 l! b2 W+ [) C+ `1047361 CONSTRAINT_MGR OTHER CM fails to convert static phase tolerance value to database units.# E6 ]+ i% N$ u
1047756 CAPTURE NETLISTS Not adding user defined properties in netlist generated by orDump.dll; A7 _% T' o, M# k8 f8 ?
1047823 CONSTRAINT_MGR OTHER acPutValue predicate text not being displayed at bottom of Constraint Manager window.
' d5 ~$ n, v9 R; D# I1047869 CONCEPT_HDL CORE How do I define a custom pwr/gnd symbol for correct Verilog syntax?
2 K8 \. T$ ]) O6 [* k- ]1049303 CONCEPT_HDL CORE Block rename deletes schematic data immediately in 16.58 f* x: ~" ] J
1049317 CONCEPT_HDL OTHER bomhdl with scm mode not working on RHEL in 16.5
2 l7 K% D6 v; O* o1049399 SIG_INTEGRITY OTHER Toggling z-axis delay in CM shows the same value
% ?; B8 t! ?2 j0 S8 ^1049993 ALLEGRO_EDITOR EDIT_ETCH Loss of Y axis when adding via in manual group routing3 p$ I" Q: P M) w7 w1 }2 V8 ?
1050483 ALLEGRO_EDITOR DRC_CONSTR DRC has been waived but after updated DRC system generated a new DRC.
- P& F, P/ b, E$ w% j$ x1051588 ALLEGRO_EDITOR PAD_EDITOR Pad_Designer library drill report omits some drill holes4 ], H5 k5 J+ A; a. J' W
1052005 SIG_INTEGRITY OTHER Huge difference in Z-Axis delay with the latest hotfix for 16.5 that did not exist in older ISR's of 16.5.+ O8 p+ t% r. \$ W" I9 l1 D3 L9 ?
1052056 ALLEGRO_EDITOR PADS_IN Pads to Allegro translator fails with error message " ARSE ERROR: Wrong label format:Translation aborted."
; X; X, T# Y' o5 R+ G; j5 Q2 i. d1052449 CONCEPT_HDL COPY_PROJECT Copy Project does not update all relative paths in the cpm file
0 y: V2 Z7 H k/ A5 R/ B1052479 PSPICE PROBE Cursor2 (Y2) displays the same value for all traces
% t/ B$ n4 H: u6 L1052753 ALLEGRO_EDITOR DRC_CONSTR Allegro showing soldermask drc only when the symbol is rotated.
, w3 m9 T: }- U8 p0 n, E% L& m1052817 CONCEPT_HDL CORE Getting packager error after renaming nets/ |# Z% s8 ^- X
1053319 CONCEPT_HDL INFRA Change in property scope in windows mode is not retained% A& l, Q5 n: s& D8 E
1053602 CONCEPT_HDL OTHER Using the attached .NDX/DML files causes a lot of delay in invoking Tools > Model Assignment.: n. Y9 W6 z$ J
1053660 CAPTURE PROJECT_MANAGER Find Part Pin name or number is not working7 d) I7 S$ [' b- M
1054010 CONCEPT_HDL CORE MAKE_BASE. \# b+ p; V! J2 h9 \7 h* r5 R2 c
1054235 ALLEGRO_EDITOR PLACEMENT Cannot place alt_symbols for mechanical parts.
: [) F. Z1 g) K V; H1054846 CAPTURE PROJECT_MANAGER Crash on pressing Esc key
; K' J% e- H6 E6 d; x1 [1055328 CONCEPT_HDL COPY_PROJECT Project Manager - Project Copy# |5 T j; K* r: G" Y
1055729 CIS GEN_BOM Standard CIS BOM per page is not working correctly with option Process Selection- {; Q1 x- w M) G4 L% l
1056418 ALLEGRO_EDITOR OTHER PDF exports the blank text markers whether or not the markers are visible.. r: |+ @8 ^: P" i3 `
1057003 ALLEGRO_EDITOR SHAPE Z-copy to create RKI does not follow board outline) E# V, U4 [% T6 ]8 j
1057976 ALLEGRO_EDITOR DRC_CONSTR No Same net Spacing DRC on attached design.$ v2 z2 X8 c# p! G+ c; q) b
1058364 ALLEGRO_EDITOR skill axlTransformObject() is moving refdes text when only symbol pin is selected for move
$ x9 F1 |. p' H0 P: K1058940 ALLEGRO_EDITOR INTERFACES IDF(PTC) out command output wrong angle value
8 l0 ?7 Q' t. l1059901 CONCEPT_HDL CORE Global Property Change and <<OCC_DELETED>> property value.+ C& {2 L& M4 W9 _
1060428 CONCEPT_HDL CORE ADW Flow Manager Copy Project fails to complete
% M$ L+ S4 S& y$ z2 m1060589 F2B PACKAGERXL Packager Fails with ERROR(SPCOPK-1053): Cannot find a ppt part that matches the instance properties.
$ E4 B5 n3 M/ l1061172 CONCEPT_HDL CORE Unable to delete Voltage
) B: V" N: `7 W8 W; g' J1061424 CONCEPT_HDL CORE Customer creates <<OCC_DELETED>> property values.
, X' Z0 Y, `8 f6 `2 C) e7 x( v1061659 ALLEGRO_EDITOR DATABASE Unable to return drawing origin to 007 o2 ]- s6 v" o- ?2 C/ H
1062532 CONCEPT_HDL CONSTRAINT_MGR Our customer saw different DIFF_PAIR contentsevery time they invoke the Constraint manager.7 p B" w! Y2 U, z
1062558 APD DXF_IF If set both in X and Y offset DXF only get one and not get absolutely value in 45 degree rotation
# `+ ], l- |$ p5 k1064707 CONCEPT_HDL CHECKPLUS Rules Checker core dumps on design
( M0 A% g* n. \1065124 PCB_LIBRARIAN SETUP PTF properties cannot be deleted from the setup in PDV
4 _* Q4 ~+ K4 _3 i C: o) K1065745 SIP_LAYOUT DATABASE The logic assign net command crashes the application
! j$ K" o0 \) L. T- D9 H8 U1065860 ALLEGRO_EDITOR REPORTS Design crashes when running a padstack usage report# N( a2 J' g. e4 h
1066051 ALLEGRO_EDITOR TESTPREP Auto Testprep generation creates TP with Testpoint to Component Locatin DRC
" X0 K- v3 A+ j# S; A' n% M1066318 CONCEPT_HDL CREFER Issue with LOCATION visibility in flattened schematic
& k7 c# }8 h' f' _& c1068425 F2B DESIGNVARI Out of memory message in Variant Editor while 縞hange properties� command6 r0 c* Y% }& e u7 F: _; m0 @
1068966 SIP_LAYOUT DRC_CONSTRAINTS DRC update aborts on this design with ERROR -3000067
6 M- j. c( \4 W4 H% b' W1069215 CAPTURE DATABASE Capture Crash on usnig a TCL utltiy to correct design
* K5 g6 h9 s- a0 c1069517 SIP_LAYOUT DIE_EDITOR change die abstract pins tab default action from delete to modify
' V# P+ Z1 R, K8 g7 E
' A' u- a% v; F8 u, m6 S0 g |
