查看: 331|回复: 2
{求助}SILK 依照零件本體大小變換 源碼有錯誤
    慵懒
    2019-11-18 15:01
     楼主| 发表于 2025-4-30 16:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    請大佬幫忙除錯
    *WARNING* (reader): a '(' at line 2 was still unclosed on EOF, ')' added
                        at line 69
    *WARNING* (reader): a '(' at line 1 was still unclosed on EOF, ')' added
                        at line 69
    procedure()
        let((texts sym p uFc symBBox assemblyHeight)
            ;; Get unit conversion factor
            if(car(axlDBGetDesignUnits()) == "mils" then
                uFc = 1
            else
                uFc = 25.4 / 1000
            ;; Set visible layers
            axlVisibleDesign(nil)
            axlVisibleLayer("Ref Des/DISPLAY_Top" t)
            axlVisibleLayer("Ref Des/DISPLAY_Bottom" t)
            axlVisibleLayer("PACKAGE GEOMETRY/ASSEMBLY_TOP" t)
            axlVisibleLayer("PACKAGE GEOMETRY/ASSEMBLY_BOTTOM" t)
            axlVisibleUpdate(nil)
            ;; Select all reference designator texts
            axlClearSelSet()
            axlSetFindFilter(?enabled `("noall" "text") ?onButtons `("noall" "text"))
            axlAddSelectAll()
            ;; Process each selected text
            foreach(texts axlGetSelSet()
                sym = texts->parent
                when(sym && texts->text == sym->component->name
                    ;; Get ASSEMBLY layer bounding box
                    symBBox = axlPolyFromDB(sym ?layer strcat("PACKAGE GEOMETRY/ASSEMBLY_" sym->side) ?noFill t ?union t)
                    when(symBBox
                        ;; Calculate ASSEMBLY layer height and set text size to 70%
                        assemblyHeight = yCoord(cadr(symBBox)) - yCoord(car(symBBox))
                        p = axlGetParam("paramTextBlock:13")
                        p->width = assemblyHeight * 0.7 * 0.6  ;; 70% height with 0.6 aspect ratio
                        p->height = assemblyHeight * 0.7        ;; 70% of height
                        p->lineSpace = 0.0 * uFc
                        p->charSpace = 0.0 * uFc
                        p->photoWidth = max(1.0 * uFc, assemblyHeight * 0.7 * 0.05)  ;; min 1mil
                        axlSetParam(p)
                        ;; Modify text properties
                        axlDBChangeText(texts nil 13)
                        ;; Rotate text to match component
                        axlTransformObject(texts ?angle sym->rotation - texts->rotation)
                        ;; Handle upside-down text
                        when(texts->rotation >= 90 && texts->rotation < 270
                            axlTransformObject(texts ?angle 180)
                        ;; Position text at ASSEMBLY layer center
                        let((assemblyCenter)
                            assemblyCenter = list(
                                (xCoord(car(symBBox)) + (xCoord(cadr(symBBox)) - xCoord(car(symBBox)))/2,
                                (yCoord(car(symBBox)) + (yCoord(cadr(symBBox)) - yCoord(car(symBBox)))/2
                            axlTransformObject(texts ?move axlMXYSub(assemblyCenter axlDBAltOrigin('center texts)))
                        ) ;; End of inner let
                    ) ;; End of when symBBox
                ) ;; End of when sym && texts->text
            ) ;; End of foreach
            axlClearSelSet()
            axlVisibleUpdate(t)  ;; Final screen update
        ) ;; End of let
    ) ;; End of procedure
    printf("mcenter command loaded. Use 'mcenter' to center reference designators (based on ASSEMBLY layer)\n")
    郁闷
    2024-7-25 15:18
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2025-5-1 16:12 | 只看该作者
    1.第一行错误
    2.AssemblyCenter创建list时没闭合,里面的表达式都少了反阔号
    发表于 2025-5-1 21:38 | 只看该作者
    括号不匹配,提示的内容不是error 不影响运行。
    GMT+8, 2025-10-26 02:09 , Processed in 0.125000 second(s), 23 queries , Gzip On.
