查看: 477|回复: 4
阿狸狗降版本v0.0.5是否需要安装allegro17.X才能使用?
 楼主| 发表于 2024-11-28 15:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教一下各位大佬,我下载了阿狸狗降版本v0.0.5,但是转换失败,我电脑上只有allegro16.6,请问是否只有安装17.X才能用?错误log如下:
% r# w- i% F, \0 k# z: ?5 y6 D) U1 b) f* |
) \1 O6 v& c% V" W7 Y$ S
THIS DOWNREV UTILITY IS INTENDED TO BE USED IN SITUATIONS WHERE A DESIGN
0 O8 C) i/ U. M5 ?MUST BE DOWNREVVED TO 16.6 AND IS NOT INTENDED AS PART OF THE STANDARD % z$ \$ m* u* c  n" _( F, B3 a6 n
DESIGN PROCESS. IT IS IMPORTANT TO UNDERSTAND THAT CERTAIN DATA WILL BE : f1 T' O! n, M. d1 ?8 H! V% E
LOST IN THIS TRANSLATION.
8 G" c3 W) F2 r2 Z- G* STHIS DOWNREV UTILITY IS DISTRIBUTED "AS IS" WITHOUT ANY OFFICIAL cadence ! ^7 p/ m2 r1 A$ W! j! O; z' m
SUPPORT AND WITHOUT ANY WARRANTY, EXPRESS OR IMPLIED, AS TO PERFORMANCE,
! l* ^1 u8 A" \6 BMERCHANTABILITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. THE ENTIRE RISK
% i. f, C- O% k' @3 IAS TO THE RESULTS AND PERFORMANCE OF THE PRODUCT IS ASSUMED BY YOU.
3 Z: F0 p% h, Q" L( t/ \
Downrev rev 17.4 to rev 16.6 database - 1.brd
' D2 S) n' i* k( Z0 h9 T    - Warning: Some Constraint Manager data and/or new Cross section data may be lost.
. [8 [4 q3 E& f8 W' `    - ERROR: Downrev aborted, padstack SMD_REC_249X305_S375 has new pad shapes not supported in rev 16.  G' J% M  e' \0 g+ a+ V- w
    - ERROR: Downrev aborted, padstack SMD_REC_1800X1200_S375 has new pad shapes not supported in rev 16.0 A& g. N- O  B$ g! }. q1 I
    - ERROR: Downrev aborted, padstack SMD_REC_224X305_S375 has new pad shapes not supported in rev 16.
9 ?/ B; Y9 B/ ~& d: @    - ERROR: Downrev aborted, padstack SMD_REC_545X650-F50 has new pad shapes not supported in rev 16.
1 k6 P2 ]1 Z4 K! J  N2 k7 x- w    - ERROR: Downrev aborted, padstack SMD_REC_1500X1250-F50 has new pad shapes not supported in rev 16.
) B9 u- R8 o4 N2 n2 @5 |$ j    - ERROR: Downrev aborted, padstack SMD_REC_300X800_F50 has new pad shapes not supported in rev 16.1 f( [% A3 `- h* @6 J9 S
    - ERROR: Downrev aborted, padstack SMD_REC_800X410_F50 has new pad shapes not supported in rev 16.
: H  Y$ m* ~. @    - ERROR: Downrev aborted, padstack SMD_REC_1150X2000 has new pad shapes not supported in rev 16.5 L) Q. d( N4 O: ^* m
    - ERROR: Downrev aborted, padstack SMD_REC_820X890-F50 has new pad shapes not supported in rev 16.
0 l: I3 L# f  v' Q    - ERROR: Downrev aborted, padstack SMD_REC_390X890-F50 has new pad shapes not supported in rev 16.. ~% C' }7 a% B; L' M/ J
    - ERROR: Downrev aborted, padstack SMD_REC_1570X3570-F50-NPS has new pad shapes not supported in rev 16.
1 i$ S# _) J: q# Z' {* t8 ^    - ERROR: Downrev aborted, padstack SMD_REC_225X285-F50 has new pad shapes not supported in rev 16.
. V" b$ Y8 U% f1 j8 R+ A! R    - ERROR: Downrev aborted, padstack SMD_REC_233X323-F50 has new pad shapes not supported in rev 16.7 J6 _, [! n/ m) O# L
    - ERROR: Downrev aborted, padstack NSMD_REC_350X3200_SM450X3300 has new pad shapes not supported in rev 16.4 `6 R$ `4 o5 t+ x, `5 J9 w& ]
    - ERROR: Downrev aborted, padstack SMD_REC_800X2000_S375 has new pad shapes not supported in rev 16.) W& q6 _3 S0 d& y) C& Z
    - ERROR: Downrev aborted, padstack SMD_REC_2200X3500_S375 has new pad shapes not supported in rev 16.
/ |6 X# L. E. C( s( l0 \    - ERROR: Downrev aborted, padstack SMD_CIR230_SM-320_PM-SQ220 has new pad shapes not supported in rev 16.
( F: K3 y; j9 u( B6 ]/ Z, {3 f    - ERROR: Downrev aborted, padstack SMD_REC_375X500-F50 has new pad shapes not supported in rev 16.( N' j- x) T4 E0 _& ]1 a# o
    - ERROR: Downrev aborted, padstack SMD_REC_275X400-F50-NSMD has new pad shapes not supported in rev 16.- _" Q) m3 Z3 p; s6 M7 [6 p' `6 Z
    - ERROR: Downrev aborted, padstack SMD_REC_625X250_S375 has new pad shapes not supported in rev 16.
' T, }; K, W2 F/ \4 f    - ERROR: Downrev aborted, padstack SMD_CIR320_SM-240_PM-SQ240 has new pad shapes not supported in rev 16.4 X' N: M9 R0 E- c, z/ l7 X( H2 ~7 c
    - ERROR: Downrev aborted, padstack SMD_REC_2100X4300-F75-NSM has new pad shapes not supported in rev 16.
/ u% t/ m% p' v    - ERROR: Downrev aborted, padstack SMD_REC_350X630-F50 has new pad shapes not supported in rev 16.
9 N+ B3 q$ a  S" s    - ERROR: Downrev aborted, padstack SMD_REC_300X530-F50 has new pad shapes not supported in rev 16.2 S& N6 X: s6 }2 R' R# D
    - ERROR: Downrev aborted, padstack SMD_REC_800X1300_S375 has new pad shapes not supported in rev 16., ?% {; V# `8 q0 U
    - ERROR: Downrev aborted, padstack SMD_REC_900X2100-F75 has new pad shapes not supported in rev 16.3 i7 i5 ?8 j& A; G4 ^" p- M, A- @
    - ERROR: Downrev aborted, padstack SMD_REC_1200X1250-F50 has new pad shapes not supported in rev 16.
& v3 ?7 w" X. V- Q" i    - ERROR: Downrev aborted, padstack SMD_REC_600X1600_S375 has new pad shapes not supported in rev 16.
6 }1 A0 X$ t* f4 O: J, h3 t    - ERROR: Downrev aborted, padstack SMD_REC_440X180_S375 has new pad shapes not supported in rev 16.* ?5 n; e4 Y- e( F
    - ERROR: Downrev aborted, padstack SMD_REC_300X800_S375 has new pad shapes not supported in rev 16.
$ i/ w9 m4 g  z    - ERROR: Downrev aborted, padstack SMD_REC_900X500_S375 has new pad shapes not supported in rev 16.4 v. H9 d) K7 k: o( S: D6 O
    - ERROR: Downrev aborted, padstack SMD_REC_450X425_S375 has new pad shapes not supported in rev 16., ?4 Q9 Y( h; o* {. J# B. }
    - ERROR: Downrev aborted, padstack SMD_REC_200_250_S375 has new pad shapes not supported in rev 16.& t/ |6 W$ h* ]9 X
    - ERROR: Downrev aborted, padstack SMD_REC_545X813_S375 has new pad shapes not supported in rev 16.
! Z' L, W  `3 [( n; z0 Q' [8 w/ J( T7 j    - ERROR: Downrev aborted, padstack SMD_REC_398X508_S375 has new pad shapes not supported in rev 16.# z; }6 ~; V: X8 B' O- @7 L
    - ERROR: Downrev aborted, padstack SMD_REC_423X508_S375 has new pad shapes not supported in rev 16." X' Z8 ]! a) v- p, Y" E
    - ERROR: Downrev aborted, padstack SMD_REC_595X813_S375 has new pad shapes not supported in rev 16.: ]3 E7 R6 a$ Q) u) Z
    - ERROR: Downrev aborted, padstack R540X260_M520X240_P085X100X4_PAM_43 has FLASH type symbols used in pads which would not be supported in rev 16.! S/ U- V/ {3 b8 L) x8 b) e0 I: ]5 F
    - ERROR: Downrev aborted, padstack R035X075_M043X083R004 has new pad shapes not supported in rev 16.
4 Z8 U6 P+ ?5 h" M: a1 R2 {& F: l    - ERROR: Downrev aborted, padstack R035X025_M033X043R004 has new pad shapes not supported in rev 16.
7 ~' \+ ?5 {! g0 r4 w; I6 [    - ERROR: Downrev aborted, padstack R020X025_M028X033R004 has new pad shapes not supported in rev 16.
( y: v) R8 L1 X( p5 a    - ERROR: Downrev aborted, padstack U_SK-UMS9230-7 has FLASH type symbols used in pads which would not be supported in rev 16.
2 W3 G8 s8 T& M# o/ D+ F( E4 M" q7 k    - ERROR: Downrev aborted, padstack S030_R0025 has new pad shapes not supported in rev 16.
  ~/ Y4 |0 p: E* ^' v- A9 G    - ERROR: Downrev aborted, padstack S045_R005_M035_P035 has new pad shapes not supported in rev 16.
/ n3 ]8 `6 V8 \* r' c$ o    - ERROR: Downrev aborted, padstack S050_R005 has new pad shapes not supported in rev 16.
9 w7 o8 z  i: ]# j& n0 t7 v    - ERROR: Downrev aborted, padstack R030X050CUR010 has new pad shapes not supported in rev 16.
( ~9 w- R" T! d) d4 `# n- F* u    - ERROR: Downrev aborted, padstack S030_R0025_M025_P0 has new pad shapes not supported in rev 16.$ T9 ]: F0 A2 b: d" m# c
    - ERROR: Downrev aborted, padstack R370X270_M350X250_P060X052X20 has FLASH type symbols used in pads which would not be supported in rev 16.
* S7 h5 ^( E" \/ u% J    - ERROR: Downrev aborted, padstack R075X085_R005 has new pad shapes not supported in rev 16.
$ s) F* @5 G7 e6 c/ y3 |$ Q* w    - ERROR: Downrev aborted, padstack R055X055_R005 has new pad shapes not supported in rev 16.
, l! h& |; ]. F! k( y( v    - ERROR: Downrev aborted, padstack R065X125_R005 has new pad shapes not supported in rev 16.
0 f% ^4 A* W( L* u' b' ?    - ERROR: Downrev aborted, padstack R065X070_R005 has new pad shapes not supported in rev 16.. a( d4 i8 f" P2 e, \- u7 }, z% E# H
    - ERROR: Downrev aborted, padstack R055X080_R005 has new pad shapes not supported in rev 16.
) h' R" U8 y9 [4 ?1 w# D* N    - ERROR: Downrev aborted, padstack R070X045_R005 has new pad shapes not supported in rev 16., R) p. _" u6 L# K9 x' p% x
    - ERROR: Downrev aborted, padstack R070X170_R005 has new pad shapes not supported in rev 16.
# `- r& {% [0 S6 Z5 N    - ERROR: Downrev aborted, padstack R085X200_R005 has new pad shapes not supported in rev 16.
  @! |! v) U- y6 \/ G. v    - ERROR: Downrev aborted, padstack R060X080_R005 has new pad shapes not supported in rev 16.5 O. |1 s$ r3 u8 b+ y  c
    - ERROR: Downrev aborted, padstack R025X052_R005 has new pad shapes not supported in rev 16.8 g& A2 A% f5 v3 \. Y4 B2 |- ^
    - ERROR: Downrev aborted, padstack R260X120_R015 has new pad shapes not supported in rev 16.! ~! E7 m/ y! V) |5 B1 ]
    - ERROR: Downrev aborted, padstack R042X033_R005 has new pad shapes not supported in rev 16.
* I# O. o6 x" w) X    - ERROR: Downrev aborted, padstack R080X200_R005 has new pad shapes not supported in rev 16.
( z  q  f: k  x1 Y( {9 {3 u    - ERROR: Downrev aborted, padstack R060X040_R005 has new pad shapes not supported in rev 16.
. ~5 [; W+ F: k( A/ H    - ERROR: Downrev aborted, padstack R040X050_R005 has new pad shapes not supported in rev 16.8 H. o8 C7 ^$ U' {. f
    - ERROR: Downrev aborted, padstack R100X180_R010 has new pad shapes not supported in rev 16.8 u, q. R  d6 Q% w1 q
    - ERROR: Downrev aborted, padstack R270X100_R010 has new pad shapes not supported in rev 16.3 U: k/ _$ M$ g4 i7 [& _
    - ERROR: Downrev aborted, padstack S025_M033R004 has new pad shapes not supported in rev 16.
( w: l, m& P6 w( n0 N    - ERROR: Downrev aborted, padstack S030_M040R005 has new pad shapes not supported in rev 16.( y; C' k, ^3 }% v8 H" S4 p
    - ERROR: Downrev aborted, padstack R400X380_M390X370_P120X112X9 has FLASH type symbols used in pads which would not be supported in rev 16.
- c& U* g$ }* A, Z9 m& j' u, x    - ERROR: Downrev aborted, padstack U_FILTER_6_250X200_6 has FLASH type symbols used in pads which would not be supported in rev 16.
' D- U8 I: m+ d5 L' s6 D9 s( f    - ERROR: Downrev aborted, padstack R025X040_R0025_M035X050 has new pad shapes not supported in rev 16.
& F+ X9 W5 `* T( l& W8 p: d5 p$ Y    - ERROR: Downrev aborted, padstack R025X030_R0025_M035X040 has new pad shapes not supported in rev 16.# J* N2 @/ z4 q& {3 K, n* b
    - ERROR: Downrev aborted, padstack R103X260CCR015_AXF5DXX12_RIGHT has FLASH type symbols used in pads which would not be supported in rev 16.
& M$ P- X( b# D9 {    - ERROR: Downrev aborted, padstack R103X260CCR015_AXF5DXX12_RIGHT has new pad shapes not supported in rev 16.
" f1 |6 J/ ?; |9 o/ V    - ERROR: Downrev aborted, padstack A150X090OY-060_M145X095_P145X095X020-45 has new pad shapes not supported in rev 16.6 ~0 a2 }7 I( \, X! t$ U+ \7 N
    - ERROR: Downrev aborted, padstack A150X090OY-060_M145X095_P145X095X020-45 has FLASH type symbols used in pads which would not be supported in rev 16.
8 U, J" c7 |1 D, {' y    - ERROR: Downrev aborted, padstack R080X065_DSB221SDN_COM160X120_4 has FLASH type symbols used in pads which would not be supported in rev 16./ n1 E" J  D% I8 Z: W; t) G0 R
    - ERROR: Downrev aborted, padstack R080X065_DSB221SDN_COM160X120_3 has FLASH type symbols used in pads which would not be supported in rev 16.8 g( {* W6 o% h6 o4 V/ N* j' D6 N
    - ERROR: Downrev aborted, padstack R080X065_DSB221SDN_COM160X120_2 has FLASH type symbols used in pads which would not be supported in rev 16.( p/ U  M- Y) F
    - ERROR: Downrev aborted, padstack R080X065_DSB221SDN_COM160X120_1 has FLASH type symbols used in pads which would not be supported in rev 16.. n4 h5 X- _6 P/ i+ m- B" T2 |" t2 r
    - ERROR: Downrev aborted, padstack R215X250_M205X240CCLL020_P0 has new pad shapes not supported in rev 16." M7 n) }  K2 V+ T. Y' q
    - ERROR: Downrev aborted, padstack R025X0325_M033X0405R004 has new pad shapes not supported in rev 16.
8 O& a$ [5 c( K9 a7 S    - ERROR: Downrev aborted, padstack R020X0325_M028X0405R004 has new pad shapes not supported in rev 16.6 q- g6 n! V3 X7 g6 ]+ Y4 r
    - ERROR: Downrev aborted, padstack R070X060_R005_M070X060 has new pad shapes not supported in rev 16.
( Z& P7 ]6 T5 e: H    - ERROR: Downrev aborted, padstack R130X060_R005_M130X060 has new pad shapes not supported in rev 16.; W. T% _8 }- L; o. `
    - ERROR: Downrev aborted, padstack S270_P110X4 has FLASH type symbols used in pads which would not be supported in rev 16.
5 V$ `( g9 e% R( T9 F( A    - ERROR: Downrev aborted, padstack R300X114_ECT_818010682 has FLASH type symbols used in pads which would not be supported in rev 16.* }' |% p) U4 x% M" E
    - ERROR: Downrev aborted, padstack R150X130_MS100CCUL020_PS044X4CULL020 has new pad shapes not supported in rev 16.
( n% w% A1 ]7 _& z    - ERROR: Downrev aborted, padstack R150X130_MS100CCUL020_PS044X4CULL020 has FLASH type symbols used in pads which would not be supported in rev 16.+ i  |% e1 }' _. d& k
    - ERROR: Downrev aborted, padstack R015X020_P015X020CCURLR005 has new pad shapes not supported in rev 16.
* V+ d1 q# k4 t! q4 }    - ERROR: Downrev aborted, padstack R015X020_P015X020CCULLL005 has new pad shapes not supported in rev 16.
4 v) L3 g; l" b* F* `# G& a    - ERROR: Downrev aborted, padstack R103X260CCL015_AXF5DXX12_LEFT has FLASH type symbols used in pads which would not be supported in rev 16.
! m" y9 C) `! F; ^2 ~! h    - ERROR: Downrev aborted, padstack R103X260CCL015_AXF5DXX12_LEFT has new pad shapes not supported in rev 16.
2 n9 W2 o+ i# X% m0 e0 W8 j) s* Y    - ERROR: Downrev aborted, padstack R045X050_R010 has new pad shapes not supported in rev 16.$ M) q6 l! ]6 m+ N2 |
    - ERROR: Downrev aborted, padstack R055X090_R014 has new pad shapes not supported in rev 16.2 U$ [  n% t3 c/ }5 k. d6 E5 ]  i
    - ERROR: Downrev aborted, padstack R075X060_R005 has new pad shapes not supported in rev 16.& A; ]# G9 a% U& K1 D) N/ c
    - ERROR: Downrev aborted, padstack R090X165_R010 has new pad shapes not supported in rev 16.
/ F8 Q2 f$ l8 I    - ERROR: Downrev aborted, padstack R025X055_R0025_M035X065 has new pad shapes not supported in rev 16.1 g0 h( b# l* f
    - ERROR: Downrev aborted, padstack R035X055_R0025 has new pad shapes not supported in rev 16.
4 t2 Y* P% c. F, a5 S    - ERROR: Downrev aborted, padstack R112X150_P112X057X2_LTPL-C0673 has FLASH type symbols used in pads which would not be supported in rev 16.+ l4 F! t" |) X6 ?" S* N
    - ERROR: Downrev aborted, padstack R614X455CCLL030_P068X083X40CCLL030 has new pad shapes not supported in rev 16.
+ D. k  i" \0 N" v% Y    - ERROR: Downrev aborted, padstack R614X455CCLL030_P068X083X40CCLL030 has FLASH type symbols used in pads which would not be supported in rev 16.
- [5 q0 m; Q8 w6 n3 M. @4 R* U# E    - ERROR: Downrev aborted, padstack R085X075_R005 has new pad shapes not supported in rev 16.6 W& Q. u0 [7 U9 H2 |
    - ERROR: Downrev aborted, padstack R095X135_R024 has new pad shapes not supported in rev 16.1 [) R+ C5 x- a0 J7 f
    - ERROR: Downrev aborted, padstack R095X045_R005 has new pad shapes not supported in rev 16.( b% a/ n9 U% B$ z9 k1 m" F5 l
    - ERROR: Downrev aborted, padstack R410X310_M390X290CCUL020_P068X062X20CCUL020 has new pad shapes not supported in rev 16.7 v  }! T$ ^8 g2 `# k, W' {
    - ERROR: Downrev aborted, padstack R410X310_M390X290CCUL020_P068X062X20CCUL020 has FLASH type symbols used in pads which would not be supported in rev 16.
8 r/ {8 M- h7 I4 k$ ]4 _    - ERROR: Downrev aborted, padstack U_SPA1687LR5H-1_4 has new pad shapes not supported in rev 16.6 o; A3 V% R0 B( x) e
    - ERROR: Downrev aborted, padstack U_SPA1687LR5H-1_4 has FLASH type symbols used in pads which would not be supported in rev 16.
# m) a! E5 @  Q* @: m- x- ]    - ERROR: Downrev aborted, padstack R073X053CCUL015 has new pad shapes not supported in rev 16.
4 m: U1 A) J, s% {0 ]" k/ Q    - ERROR: Downrev aborted, padstack R051X070CCUL019 has new pad shapes not supported in rev 16.3 ^: ]6 s& E/ ?4 [- @
    - ERROR: Downrev aborted, padstack R073X053CCLL015 has new pad shapes not supported in rev 16.
; b' c  ?; f. f/ D6 V& R$ N( X    - ERROR: Downrev aborted, padstack R720X510_M080X092X40CCLL020_P070X082X40CCLL020 has FLASH type symbols used in pads which would not be supported in rev 16.
) L5 t9 i3 N2 U* G6 c    - ERROR: Downrev aborted, padstack R357X157CCLL030_M119X081X6CCUL0325_P109X071X6CCUL030 has FLASH type symbols used in pads which would not be supported in rev 16.3 H2 C) s* C' }
    - ERROR: Downrev aborted, padstack R357X157CCLL030_M119X081X6CCUL0325_P109X071X6CCUL030 has new pad shapes not supported in rev 16.
* m6 A7 R. a# [  [% X: YERROR: Downrev failed. Database not converted.# K. n! C' D, f4 [  T
5 s# W2 L, Z/ r' B! ], L0 B
3 _# U# t5 V3 r1 Z0 m9 p! g5 s* M. S5 }3 |8 {% a
假如你幸運遇到一個高手, 他肯花時間寫個SKILL, 幫你在高版本先降PAD版本, 但那不是我, 因為我事業沒成, 所以沒那功力.  发表于 2024-11-28 20:34
看一下英文, 降失敗的原因是高版本的PAD格式, 降了在16.6不支援, 只能在高版改PAD再轉降版本.  发表于 2024-11-28 20:29
 楼主| 发表于 2024-11-28 15:45 | 只看该作者
用电路精灵打开也是提示ERROR: Downrev aborted, padstack SMD_REC_249X305_S375 has new pad shapes not supported in rev 16
发表于 2024-11-28 21:01 | 只看该作者
17.2版本有的焊盘类型16.6版本里面没有,需要把这些焊盘改成支持16.6 的焊盘类型,就可以降下来
GMT+8, 2025-11-4 01:35 , Processed in 0.140625 second(s), 24 queries , Gzip On.
