查看: 98|回复: 0
ZCC103数字温度传感器芯片替代TMP103
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
     楼主| 发表于 2024-11-25 18:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    1 Features- d' ^- _% n8 J" Z' v% r4 i
    Multiple Device Access (MDA):
    + m  w" F% c8 ]6 c5 T# u/ T) mGlobal Read/Write Operations
    : Z* U" q, i; g2 cI2C™ and SMBus™-Compatible InteRFace* S; }0 J. [/ A. g/ ^9 f9 {- {: w
    Resolution: 8 Bits) M; }2 |3 p) Y( Q/ I4 a4 U6 |* \4 w" r
    3 Description
    0 z) g& S+ ~; c: FThe ZCC103 is a digital output temperature sensor in$ J2 I6 Y; f; o4 w3 F& q
    a four-ball wafer chip-scale package (WCSP). The
    7 S% H/ ]3 W& |3 T% B9 [ZCC103 is capable of reading temperatures to a
    7 c5 e8 i. Z9 o1 n+ aresolution of 1°C.7 s, D. U7 \: I% y5 R" O: J4 R
    The ZCC103 features a two-wire interface that is
    9 o) i* U1 C- a! Ncompatible with both I2C and SMBus interfaces. In
    1 k! @1 @1 y, b7 Vaddition, the interface supports multiple device
    4 n0 ?" {% `6 o) t! raccess (MDA) commands that allow the master to
    6 v2 d5 J" x( b" c/ `2 o2 ^7 Ycommunicate with multiple devices on the bus/ }" V  j8 j; H* G- U& a# S
    simultaneously, eliminating the need to send2 g6 E! o3 ^( O  [
    individual commands to each ZCC103 on the bus.
    9 F! d1 a% @0 j# {7 [Up to eight ZCC103s can be tied together in parallel
    0 i4 E& ?0 m; [4 i. R4 {6 {and easily read by the host. The ZCC103 is
    5 I' d1 F3 _* R' @: z0 Z. G: nespecially suitable for space-constrained, power-
    . }' E1 `3 B1 i8 @sensitive applications with multiple temperature2 r- O. `( r7 d
    measurement zones that must be monitored.* c* d* v" [" s1 y8 s& T2 V8 M
    The ZCC103 is specified for operation over a  F# @9 ?9 Y: @- ?, H3 G: L
    temperature range of –40°C to 125°C  I' M- }- m. e; y( X0 J
    .Device Information(1)
    1 R: ]5 n( r2 k% l: A) j. qAccuracy: ±1°C Typical (–10°C to 100°C)- w5 b+ o4 U9 O  ]/ W9 e; ]! v
    Low Quiescent Current:
    : B' c" ?, A! T/ `3-μAActiveIQ at0.25Hz
    ! F( K9 \6 @4 F8 W8 j; p6 F1-μA Shutdown& w. V) L4 w; @. j/ r8 ?& J: l
    Supply Range: 1.4 V to 3.6 V
    1 w, ?. {0 e! |( x& _9 p5 o) tDigital Output  F) w5 s! ]) b: ^5 `' |
    " p4 L& i# ~% `0 y- K$ R7 _+ e- a
    & G( z7 N6 J' }5 o" O
    GMT+8, 2025-11-5 08:44 , Processed in 0.156250 second(s), 25 queries , Gzip On.
