查看: 115|回复: 0
ZCC3633双通道3A,15V单片同步降压替代LTC3633
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
     楼主| 发表于 2024-10-11 17:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    FEATURES. T2 n: D* O, c# r, P5 L: b& F, X
    *3.6V to 15V Input Voltage Range
    ! _7 `, t6 J' Z9 j3 o- m) V, _8 D*3A Output Current per Channel
    5 J$ k5 k5 g4 P4 W+ V' N; l*Up to 95% Efficiency
    " E8 w8 [0 a1 o6 ?9 V*Low Duty Cycle Operation: 5% at 2.25MHz9 y, a. x& O+ G# [% k% U
    *Selectable 0°/180°Phase Shift Between Channels+ b  W* n/ k( q% {5 X4 n* G
    *Adjustable Switching Frequency: 500kHz to 4MHz$ K6 n, `8 X5 t+ ?9 ~
    *External Frequency Synchronization1 S. p# J, ~( P$ G0 _
    *Current Mode Operation for Excellent Line and Load Transient Response4 R' I1 R1 C: }% C, k
    * 0.6V Reference Allows Low Output Voltages
    ' M+ B; f' t+ d  J! b! ?*User Selectable Burst Mode Operation or Forced Continuous Operation
    4 E! P0 @/ E* `; a) e8 t*Output Voltage Tracking and Soft-Start Capability
    * w9 \2 O! o) ^& U( z- y) e*Short-Circuit Protected- g4 |0 A8 T$ b$ {/ ]: N! A- q; X
    *Overvoltage Input and Overtemperature Protection/ |9 d5 k) `0 }9 x4 Z' g
    *Low Power 2.5V Linear Regulator Output6 L- I, T; _4 x6 ?. D, g! n
    *Power Good Status 0utputs- d6 L! T  x! }9 k
    *Available in(4mmX5mm) QFN-28 and 28-Lead TSS OP Packages
    / m: O+ x. ^/ o- W8 {# aDESCRIPTION
    8 W9 v8 w4 B; x7 ]TheZCC3633 is ahighefficiency, dual-channel monolithic synchronous buck regulator using a controlled on-time, current mode architecture, with phase lockable switching frequency. The two channels can run 180° out of phase, which relaxes the requirementsfor input and output ca-pacitance.The operating supply voltagerange isfrom3.6V to 15V making it suitable for dual cell lithium-ion batteries as well as point of load power supply applications froma 12V or 5V supply.
    , q& s! |( I/ CThe operatingfrequencyis programmable and synchroniz-able from 500kHz to 4MHz with an external resistor The high frequencycapability allows the use of small suRFace mount inductors andcapacitors. The unique constant frequency/controlled on-time architecture is idealfor high step-down ratio applications thatoperate athighfrequency while demanding fasttransientresponse.An internal phase lock loop servos the on-time oftheinternal one-shottimer to match the frequency of the internal clock or an applied external clock.
    5 K- I5 l: l% LThe ZCC3633 can select between forced continuous mode andhigh efficiency Burst Mode operation
    # g4 t$ ~6 Q9 }# V) YAPPLICATIONSD# e5 m% L5 [; ]* R7 ?5 P
    istributed Power Systems, V. E" p/ F! c  {( N# I/ z
    Battery Powered Instruments* j! G0 b! `& `- t  `) L( [0 P
    Point of Load Power Supplies
    / q# @# O, V. l( W5 Q2 H
    GMT+8, 2025-11-5 11:23 , Processed in 0.125000 second(s), 23 queries , Gzip On.
