查看: 117|回复: 0
ZC21550 双通道栅极驱动器替代UCC21550
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
     楼主| 发表于 2024-8-5 17:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    1. Applications
    , Z3 X* {7 e  cIsolated DC-DC and AC-to-DC power supplies inserver, telecom, and industry Motor Drive and DC-to-AC solar inverters LED Lighting UPS and battery chargers2 Q  e6 R9 k& o: A* d
    2. Features
    6 b, T3 S' W. W1 d4 KUniversal: dual low-side, dual high-side orhalf-bridge driver Operation temperature: -40℃~125℃ Up to 33V VDD output drive supply with UVLO Up to 5A peak source and 6A peak sink output High CMTI: ±150kV/us typical 25ns typical propagation delay 5ns maximum delay matching 6ns maximum pulse width distortion Programmable deadtime Safety-related certifications (Planned): ·5000 VRMS isolation for 1 minute per UL 1577with SOP16W, SOP14W package ·3000VRMS isolation for 1 minute per UL 1577with SOP16 package ·2500 VRMS for 1 minute per UL 1577 with LGA13package ·CQC certification per GB4943.1-2022 ·DIN VDE 0884-17: 2021-10) S" g4 Y* ]( d0 v
    3. Description
    8 X: H' k5 ]' ^: J1 @, m% [The ZC21550 is an isolated dual channel gate driveRFamily with programmable dead time and widetemperature range. It is designed with 5-A peaksource and 6-A peak-sink current to drive powerMOSFET, SiC, GaN, and IGBT transistors up to 2MHzswitching frequency. The ZC21550 can be configured as two low-sidedrivers, two high-side drivers, or a half-bridge driverwith programmable dead time (DT). The input side is isolated from the twooutput drivers by a silicondioxide isolation barrier, with a150kV/us typical common-mode transient immunity (CMTI). Both outputs shut down simultaneously the disable pin issetto high. The driver operates with a maximum supply voltageof 33V, while the input-side accepts from 3V to 5V supply voltage. Under voltage lock-out (UVLO) protection is supportedby all the power supply voltage pins. The ZC21550 provides 2500Vrms isolation perUL1577 in 5-mm x 5-mm LGA13 package, 3000Vrmsisolation in SOP16 (150mil) package, and 5000Vrmsisolation in SOP16 (300mil) or SOP14 (300mil)package.) i1 U, d) M6 Y( ?$ M2 I
    % u7 P$ y# \1 _$ w' z
    6 K6 q9 c. y9 Y( `" R# }! I
    GMT+8, 2025-11-6 01:24 , Processed in 0.125000 second(s), 23 queries , Gzip On.
