查看: 5187|回复: 27
Cadence Allegro SPB 16.5 Hotfix S028
发表于 2012-9-2 13:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
7 S, Q- U" N" k* `& J
, a( K, j* G) @/ g# F" Kcadence最新版软件SPB 16.5及其Hotfix_SPB16.50.028_wint_1of1.exe下载链接如下:& A. B3 D& S; M$ X! `' U0 K
- E) }4 l+ A% o; H5 Q; e8 j( `http://dl.vmall.com/c037uexo72
2 F" w" S% Z( |( ?6 Y9 \4 {7 e( ]8 F0 \3 r( S  \
Cadence allegro SPB 16.5 的最新(截止到2012年9月1日)补丁S028,对以下项目做了修正:
6 n# T+ v( A. P0 EDATE: 08-23-2012   HOTFIX VERSION: 028
" B* r9 {7 S! {9 A8 \$ f* o===================================================================================================================================6 i$ x5 s4 V0 ~6 b
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
" Z2 t- P# N. J) @. r===================================================================================================================================
5 S- n& D& }; M. t: x320014  ALLEGRO_EDITOR EDIT_ETCH        Differential pair fail to Slide together% ]8 P1 \2 p  y) v" U
400672  ALLEGRO_EDITOR EDIT_ETCH        The Diffpair rule is disregarded because of the insertion of Via.
# Z  D" x7 L/ ~, ^$ M+ {6 i448641  ALLEGRO_EDITOR EDIT_ETCH        Diff pairs do not slide when the xnet is broken# C; I8 q3 I" R/ B2 V( ]
501605  ALLEGRO_EDITOR EDIT_ETCH        Diff Pair Sliding problem$ o. ~  i5 Z3 }( g5 E# q3 ]
731162  ALLEGRO_EDITOR EDIT_ETCH        Slide and Delay Tune on Diff pair tunes only one net when Single trace mode is not ON.
" ]! h+ r% d+ n6 e! v" \  A6 \967082  SIG_INTEGRITY  SIGNOISE         signoise command didn't use Frequency set on Net.. ]2 ?5 n0 D/ I/ \
979958  SIP_LAYOUT     ASSY_RULE_CHECK  Running Assembly Rules Check on sip causes a crash  s) j0 q0 F5 @. L1 b) }" a
984604  ALLEGRO_EDITOR EDIT_ETCH        Error when trying to split via stack
& \  |9 ]1 B* x. Q) p2 @- Q988446  APD            OTHER            Beginning layer regular pad cannot change to Null.
8 O6 {2 @; x' ?# R1 o, J  H; ~995108  ALLEGRO_EDITOR GRAPHICS         Strange unexpected lines show across the oblong padstack
: g$ A, R" Q2 M+ x$ G+ q1 N; P  \/ y1021557 RF_PCB         DISCRETE_LIBX_2A Translator dxlib2iff lists cells alphanumerically inverted.& J' T& Z, V. w6 k: x% ]+ ^+ g
1021568 RF_PCB         DISCRETE_LIBX_2A translator GUI not listing library cells alphabetically in Linux/Unix2 w0 _' _0 ]4 i
1024239 ALLEGRO_EDITOR INTERFACES       DXF pin location is moved when I execute DXF out5 a% F+ j; L* B2 M" @6 ~
1039112 ALLEGRO_EDITOR ARTWORK          Antietch and Boundary layers deleted when Match Display selected
7 h; e7 ]9 \0 u1039751 SCM            SCHGEN           SCHGEN is bunching voltage flags together to the point they're illegible
- H! _! O8 c0 Z: A' f6 V1040584 ALLEGRO_EDITOR GRAPHICS         After installing Hotfix 16.5s026  3D viewer has been impacted..- w* l2 i7 P  T/ p! w  x8 _
1040653 ALLEGRO_EDITOR DATABASE         Cannot update netlist data,  ERROR(SPMHDB-121): Attribute definition not found.
- O8 k6 u, l% j1041368 APD            DEGASSING        The Degas_No_Void properties assigned to Cline does not work.0 L5 |" O$ o! o" x" j: h
1041864 ALLEGRO_EDITOR MANUFACT         Allegro crashes when opening the Backdrill setup menu
8 k! M  O2 S7 X- b# j$ `4 X1042004 SIP_LAYOUT     DIE_STACK_EDITOR Moving die pad layer from top to bottom of package is not change the die stack side
5 ~! a$ F4 R4 l5 y- m9 E1043777 ADW            COMPONENT_BROWSE ADW UCB must support hyperlinks in Database Mode like we do in Non-DB Mode
+ n3 U" Q. K0 X& J, ]' E1043861 SIG_INTEGRITY  REPORTS          Derating values are NA in bus simulation report when derating table is not in working directory
参与人数 1贡献 +10 收起 理由
chensi007 + 10 赞一个!
发表于 2012-9-2 19:50 | 只看该作者
呀,问题挺多的,补丁眼花缭乱
发表于 2012-9-2 22:08 | 只看该作者
Thanks for your sharing !!!!!!!!{:soso_e183:}
    2021-1-26 15:48
    发表于 2012-9-3 08:31 | 只看该作者
    感謝分享
    发表于 2012-9-3 16:27 | 只看该作者
    链接不存在
    发表于 2012-9-3 16:58 | 只看该作者
    期待有115盘的链接。
    发表于 2012-9-3 17:59 | 只看该作者
    {:soso_e183:}楼主好人,多谢发帖,以后有更新的话,还请楼主分享啊,不胜感激{:soso_e179:}
    发表于 2012-9-3 21:07 | 只看该作者
    - f: y4 x' ~9 U% S3 K2 k2 S5 _
    发表于 2012-9-4 08:44 | 只看该作者
    楼主好人,多谢发帖.ding
    奋斗
    2019-12-11 15:50
    发表于 2012-9-4 09:50 | 只看该作者
    感谢楼主分享,正在下载
    奋斗
    2024-1-17 15:52
  • 签到天数: 237 天
    [LV.7]常住居民III
    发表于 2012-9-4 10:58 | 只看该作者
    更新不完
    发表于 2012-9-7 20:07 | 只看该作者
    感谢分享~~~
    9 M3 \) y. f+ O' X/ @8 m刚好用上试试
    13#
    发表于 2012-9-7 23:04 | 只看该作者
    现在不能下载啊
    14#
    发表于 2012-9-8 10:52 | 只看该作者
    不能下载啊
    15#
    发表于 2012-9-8 11:51 | 只看该作者
    没用,破解后不能用
    GMT+8, 2025-11-3 03:53 , Processed in 0.156250 second(s), 29 queries , Gzip On.
