查看: 140|回复: 0
ZCC9509-5V/3A LDO替代RT9059
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
     楼主| 发表于 2024-6-24 15:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    General Description
    9 d/ S; x3 f4 }1 H, I( A* d0 nThe ZCC9059 is a 3Alow dropout linear regulator designed for low dropout and high current applications. This device works with dual supplies, a control input for the control circuitry and a power input as low as 1.0V for providing current to output. It features 3A output current and ultra-low-drop output voltage as well as full protection functions. VOUT can be as low as 0.792V.
    8 }8 ]5 g+ v: e% RThe other features include soft start, under voltage protection, current limit protection, Power-On-Reset function, and over temperature protection. The ZCC9059 is available in ESOP8packages
    + o. E/ N$ H/ k2 Z. VFeatures
    & n' C& {% l. JVIN Range1.0V to 6.0V0 }# f& _& B7 {1 s7 n; `2 {
    VOUT is Adjustable (0.792V Min)
    3 A0 r. M5 d, e' O% \7 xExcellent Line Regulation (0.01%/V typ.) Excellent Load Regulation(0.1%/A typ.); e8 y9 j* d4 \; e4 V
    Dropout Voltage Typically 250 mVat IOUT = 3A Internal Thermal Overload Protection Internal Short-Circuit Current Limit VOUT Under Voltage Protection Ceramic Capacitor Stable5 F; T" n+ ]8 x. X0 w- {& T
    Applications0 B) D# y- F3 @$ L, I* \
    Notebook, Netbook, Graphic Cards Low Voltage Logic Supplies Chipset Supplies Server System1 v  w  s4 F' _
    GMT+8, 2025-11-6 05:05 , Processed in 0.171875 second(s), 23 queries , Gzip On.
