TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
Features- U W* c1 B) N" b3 v
9V to 100V input voltage range
' M! S6 X, B- F- z1.5A/5A continuous output current
8 z, A8 i$ @- L7 F+ d95% Peak Efficiency; D1 J3 y4 b! X& w! O
400µA operating quiescent current
- F" ]4 T. g/ P1 f! i3 L' ^8 r4 ^100V 400-mΩ high-side MOSFET8 a% z% Q2 e: S
Peak Current mode control
& o+ K5 S; Z; j2 E150 kHz Fixed Frequency
7 D H4 Q1 |7 OInternal compensation for ease of use& A; {' Q$ u! M$ U! S
Up to 92% duty cycle
7 L& ?0 @! v0 U& _2 _. _+ `0.8V voltage reference
4 E' M( L" S% b6 a1µA shutdown current. M% j0 i3 G5 U; d; O2 I9 h
3A/6A cycle-by-cycle current limit
6 Z! r0 i9 ^! N' D150ms Hiccup mode short circuit protection, o6 |( K4 L- m* l }4 \: L
Function
1 B0 O! o+ L& J7 NThermal shutdown Function" _' d& b0 w) b$ ?1 D: N. a' _' |
ESOP-8 package' e* B. n9 G+ c0 G) p1 s( z2 h
Applications
. j' c- Z+ S# H+ O. A6 ?! W0 N$ nCharger in vehicle
/ X' l% T" |# ?Battery Chargers
9 A& o# `- K# I- R0 s5 ]Power adapter+ C w! [/ \! i
Typical Application* x: W2 x* f e2 j
Description
% I$ D8 m4 C$ z. h) n% {5 k5 d5 dThe ZCC1005 is a high voltage, non-synchronous4 M: d/ D2 G0 ?2 @7 ^6 O0 L; y
step-down converter operates over a wide range
; X9 X. d: ]% x3 u0 r& U- U. H7 Pinput voltage
* J) b) T8 a( _" E. ^+ g9V to 100V. The ZCC10057 N6 H0 M+ U$ n
integrates a 100-V 400-mΩ high-side MOSFET.0 [3 y' B4 C* V2 _$ a* Z
The ZCC1005 delivers 1.5A continuous load
5 b k! k! Q/ e9 i7 s6 Tcurrent with up to 95% efficiency. The ZCC1005# m* a( R; X7 X, t/ V
operates with fixed frequency peak current control
' a/ V: t/ A# Z2 xwith built-in compensation eliminates the need for
2 ?4 v. T3 G: |/ `. w( j# \external components.
: ]/ G& p( |# m% r1 S7 R5 M) C3 e- tCycle-by-cycle current limit in high-side MOSFET
8 |# l& I [/ `# [/ \protects the converter in an overload condition.
- k# J; w# h) ^. u; ?" W* ]Hiccup mode protection is triggered if the
) V$ V- d5 z# W' Q9 e5 d( P- uover-current condition has persisted for longer than
. @9 k* J% q5 Xthe present time.
: ~) [: ~4 u% F1 m+ rThe ZCC1005 exhibits protection features that
% ^% a2 I' p% y0 fprotect the load from faults like under-voltage,
/ Q9 |5 i4 `0 E1 l% z x& zover-current and over-temperature.. F% O# [( a5 ]' G/ A+ J) G
The ZCC1005 is available in an ESOP-8 package. j: @! q3 a1 Y, u8 X4 W' {4 m
