查看: 2842|回复: 3
创建网表的时候有警告
发表于 2012-7-26 16:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
部分提示如下
) M% Q$ m( R" F; k( X#1 Warning [ALG0051] Pin "VCC" is renamed to "VCC#2" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
% y: U( s3 ~8 g#2 Warning [ALG0051] Pin "GND" is renamed to "GND#3" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).5 I0 Q- q+ X6 M- s* Z
#3 Warning [ALG0051] Pin "AVCC" is renamed to "AVCC#10" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).* w$ {2 a' R6 b5 v# T
#4 Warning [ALG0051] Pin "AGND" is renamed to "AGND#13" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).. \/ z! x1 F. \) ?# K* ]
#5 Warning [ALG0051] Pin "AVCC" is renamed to "AVCC#17" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
" X1 M6 z1 g( p) N/ L( P( V/ S#6 Warning [ALG0051] Pin "AGND" is renamed to "AGND#20" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
( s# g% R/ L" q+ k% U4 B#7 Warning [ALG0051] Pin "VCC" is renamed to "VCC#26" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).: E/ N+ o/ W- Y9 q- _" e$ D7 y
#8 Warning [ALG0051] Pin "GND" is renamed to "GND#27" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
" C9 i  _. e3 Q0 L; G6 y7 [#9 Warning [ALG0051] Pin "VCC" is renamed to "VCC#43" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
; j9 _0 Q! p/ X#10 Warning [ALG0051] Pin "VCC" is renamed to "VCC#48" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).( Y  x: ?, N3 x5 ~( i, D# K
#11 Warning [ALG0051] Pin "GND" is renamed to "GND#49" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
- {. j0 ]$ j! A6 L! z; a#12 Warning [ALG0051] Pin "GND" is renamed to "GND#58" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
: S+ h- P9 Z+ u- `: X. m. [#13 Warning [ALG0051] Pin "VCC" is renamed to "VCC#64" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84)., u# G4 O) K; q  h6 @. F
#14 Warning [ALG0051] Pin "GND" is renamed to "GND#65" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).& f! [' M  ]! v) ]" o! A
#15 Warning [ALG0051] Pin "VCC" is renamed to "VCC#68" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).' F- X- v! h* }5 L2 `5 Q; g
#16 Warning [ALG0051] Pin "GND" is renamed to "GND#80" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
# h" h" @- }: c( b#17 Warning [ALG0051] Pin "VCC" is renamed to "VCC#81" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).: ~. l; g+ @) j; l
#18 Warning [ALG0051] Pin "GND" is renamed to "GND#93" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
' K6 c' ]1 [' {" N- `#19 Warning [ALG0051] Pin "VCC" is renamed to "VCC#100" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84)./ B1 b2 L3 @" c  Q
#20 Warning [ALG0051] Pin "VCC" is renamed to "VCC#107" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
& B; V" p$ |/ b& [( b! o' i+ |#21 Warning [ALG0051] Pin "GND" is renamed to "GND#116" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
6 N' u6 R. b% A5 t* l+ e#22 Warning [ALG0051] Pin "GND" is renamed to "GND#125" as visible power pin of same name already exists in Package CY7C68013PQ128B , U1A: SCHEMATIC1, BUS (43.18, 116.84).
    2023-10-13 15:02
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2012-7-27 08:49 | 只看该作者
    零件包裝的pin 名稱不能相同 ,如果是gnd 重覆可以改成gnd_1,gnd_2 或是將pin的屬性改成power
    参与人数 1贡献 +5 收起 理由
    jacklee_47pn + 5 支持!
     楼主| 发表于 2012-7-31 15:55 | 只看该作者
    好像不是这个原因吧,我已经在封装里设置成power了
    发表于 2012-7-31 21:20 | 只看该作者
    其实是所有管脚都不能重名,"VCC" is renamed to "VCC#68" 就是说软件自己将VCC重命名为了VCC#68
    GMT+8, 2025-10-27 03:14 , Processed in 0.140625 second(s), 27 queries , Gzip On.
