查看: 825|回复: 1
求大大们帮个说明一下,一个很简单的东东!
发表于 2012-7-24 10:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
@optional Option
The @optional option gives you another way to specify a flexible number of arguments.With
@optional, each argument on the actual argument list is matched up with an argument on
the formal argument list.
You can provide any optional parameter with a default value. Specify the default value using
a default form. The default form is a two-member list. The first member of this list is the
optional parameter’s name. The second member is the default value.
The default value is assigned only if no value is assigned when the function is called. If the
procedure does not specify a default value for an argument, nil is assigned.
If you place @optional in the argument list of a procedure definition, any parameter following
it is considered optional.
The trBuildBBox function builds a bounding box.
procedure( trBuildBBox( height width @optional
( xCoord 0 ) ( yCoord 0 ) )
list(
xCoord:yCoord ;;; lower left
xCoord+width:yCoord+height ) ;;; upper right
) ; procedure
Both length and width must be specified when this function is called. However, the
coordinates of the box are declared as optional parameters. If only two parameters are
specified, the optional parameters are given their default values. For xCoord and yCoord,
those values are 0.
Examine the following calls to trBuildBBox and their return values:
trBuildBBox( 1 2 ) => ((0 0) (2 1))
trBuildBBox( 1 2 4 ) => ((4 0) (6 1))
trBuildBBox( 1 2 4 10) => ((4 10) (6 11))
以上是原文!!
我直接用了些程序试验提示说:function trBuildBBox redefined
以下是我复制的程序:
list(
) ; procedure
trBuildBBox( 1 2 )
想知道我哪里出问题了!!
谢谢!
发表于 2012-8-10 00:18 | 只看该作者
没有错啊, 那个提示是说 trBuildBBox 函数被重新定义了, 只能说明allegro加载了2次, 呵呵:)
或许是别人代码里也有这个东西, 以最后加载的定义为主哦
另外, SKILL以空格为分隔符, 小心 xCoord+width:yCoord+height  这个代码,符号 : 挺好的, 但也要小心由于空格和运算符优先级引起问题.
欢迎Z大回归  发表于 2012-8-10 08:50
GMT+8, 2025-9-11 01:50 , Processed in 0.109375 second(s), 27 queries , Gzip On.
