cadence最新版软件SPB 16.5及其Hotfix下载链接如下:
5 M4 e& d3 U, m0 ?5 Thttp://115.com/file/c2tka4t6
$ K) i: [7 \4 x4 p4 A( vHotfix中只需要安装最新的版本即可。) T: e* U+ C9 i5 o' @
Hotfix025对以下项目做了修正:
7 {; w; A; b% LDATE: 07-5-2012 HOTFIX VERSION: 025" O- z# t/ z& h1 c+ {! L
===================================================================================================================================- o1 {$ _# U4 L& Z
CCRID PRODUCT PRODUCTLEVEL2 TITLE) n& i) r4 Y! f/ S( O7 \' {6 T4 {
===================================================================================================================================; @3 d& e/ ]2 m! H/ E9 [8 c0 U
859855 SIG_INTEGRITY GEOMETRY_EXTRACT OddSegParallelOffset env doesn't work if Enable CPW Extraction is checked.
" I( N J2 g) j8 e1 Q1014275 CONSTRAINT_MGR OTHER F2B: DiffPair cns was not updated if DiffPair Name didn't match./ c& K* D j' }2 k( n: q4 f+ i3 v+ R
1019414 allegro_EDITOR INTERFACES export DXF creates pin offset in 16.5
7 f0 [1 r! H4 a4 k: P/ j1019688 ALLEGRO_EDITOR INTERACTIV moving dimension symbol in 16.3 crashes allegro3 [1 Y/ @' Z v
1022563 ALLEGRO_EDITOR INTERFACES IDF_In do not import Arc correctly when IDF and Allegro accuracy are same.
% ~, t$ |$ R2 [+ g# N, Z1023892 SIG_INTEGRITY OTHER Need Custom Variable to control signoise.run uprev from 16.2 > 16.5 to control reading of DevLibs variables1 h" ]( W: S# q; E* z9 F
1023939 APD COLOR Assigning a color to a group a second time fails after "clear net color overrides."9 j }/ I1 a2 N- [) F
1025402 SIG_INTEGRITY LICENSING Show Element window does not display and Allegro crashes.
3 K# U V- \# _! v8 t; F" H! q1025957 SIG_INTEGRITY OTHER Same net parallelism reports DRC errors on straight line segments
8 k2 l. K/ B2 U. {$ Z8 f$ x1026401 ALLEGRO_EDITOR skill axlPolyExpand returns incorrect information when expand
6 n) k5 r8 u H/ h2 l {( [3 J
t5 u, a' Y% b. U5 k/ }; I9 ?共条评分 ) @6 m! O( x: |. Y+ ]5 _
# i* j3 s* q; w. Q8 Q7 A |
