查看: 1001|回复: 4
Allegro生成表網表的問題
发表于 2012-7-12 11:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
請教各位大大8 j: d0 k; N6 v6 R6 x# s3 u
3 {' I( J6 z4 N" [# i, O小弟使用Allegor 15.7生成netlist時一直出現下列訊息
! ?+ c! m) k+ g( \, L+ L6 ~$ u% `. B: @; U, H% l" x% h! x% N
8 e5 }$ c' ?1 b  c) J2 T2 t
! v; n2 V4 e2 E2 N2 Qlog顥示的錯誤大約如下,該怎麼處理呢
/ B4 X- U1 R3 A8 @3 j: U! F; X% Y0 ?6 U. z2 T% y
#56  WARNING(304) Device/Symbol check warning detected.3 P+ X" Z- f! M
( i1 D! U  \4 SSymbol 'OSC_14' for device 'CLOCK_DIP14_OSC_14_CLOCK' not found in PSMPATH or must be "dbdoctor"ed.
+ _3 u% ]1 Q" P  P
5 d  H4 ?' e" X$ J+ [#57  WARNING(304) Device/Symbol check warning detected.
# g9 l" t# \$ ?4 g& z; x* r# [2 \& ^5 T% G2 I" l; S
Symbol 'SOIC127P600X175-8' for device 'CY2303_SOIC127P600X175-8_CY2303' not found in PSMPATH or must be "dbdoctor"ed.
6 g9 I; h/ }9 V9 K, x* p# I
# A' W+ ]5 o: F: L+ }- X#58  WARNING(304) Device/Symbol check warning detected.  V0 L8 d4 l* N7 y8 E
# s) p2 N6 W. X) ^" {* }Symbol 'BGA272DSP' for device 'TMS320C6713GDP_BGA272DSP_TMS320' not found in PSMPATH or must be "dbdoctor"ed./ @! n0 r! Q  U) W$ Z
3 z0 Z# O# h5 S7 ]6 N#59  WARNING(304) Device/Symbol check warning detected.
' X6 ^) D6 }# E: V/ p9 s: J1 g  u
Symbol 'SDRAMTSOP86' for device 'MT48LC2M32B2B5-6_SDRAMTSOP86_MT' not found in PSMPATH or must be "dbdoctor"ed.0 e  P4 J! B; k0 \, h
$ ^4 r: D# n2 n  m#60  WARNING(304) Device/Symbol check warning detected.
6 Z4 K( G6 x5 D0 R; P* ?2 E8 K( j; D3 W/ Q
Symbol 'SST39VFTSOP48' for device 'SST39VF800A_SST39VFTSOP48_SST39' not found in PSMPATH or must be "dbdoctor"ed.
发表于 2012-7-12 15:40 | 只看该作者
你把它提示的这几个元件重新生成下device和psm文件,更新下试试
发表于 2012-7-12 21:17 | 只看该作者
warning,可以忽略操作,如果确定放不下来,那你把这几个封装,重新打开,再重新存档就OK!!
发表于 2012-7-13 11:09 | 只看该作者
是啊。楼上说的对,一般出现ERROR才必须要解决。wanging一般不处理可以直接导入的。楼主应该把ERROR截下来。呵呵。
发表于 2012-7-13 11:59 | 只看该作者
封装问题,检查一下封装库和路径
GMT+8, 2025-10-25 09:40 , Processed in 0.140625 second(s), 26 queries , Gzip On.
