急急啊 原理图导入LAYOUT在记事本里出现 Net BANDSW_DCS has less than two pins in PCB net list file. 1 t" z+ A; D2 M7 S0 v. Y. uNet GPIO44_PSM_RESET has less than two pins in PCB net list file.* [1 u5 `1 {5 l% T
Net GPIO26_FM_32KHZ has less than two pins in PCB net list file. : T3 Z' _4 `2 _8 V- @Net GPIO7/EDI_DAT has less than two pins in PCB net list file. 6 ?% t0 |! C( B7 Q! T Z2 INet GPO3_PSM_26MHZ has less than two pins in PCB net list file.6 T7 A- m+ }* N# s9 `9 S
Net EINT1_SLIDE_DET has less than two pins in PCB net list file. W8 u9 o7 _7 {7 k8 i9 tNet KC0L4 has less than two pins in PCB net list file.; J J' _' y, S1 R' _" W! |4 r8 |
Net 850_RX has less than two pins in PCB net list file. , R3 [2 |& @' h# f9 ^6 F6 w# PNet PCS_RX has less than two pins in PCB net list file. 这是哪个地方出来问题啊 求救!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
