EDA365欢迎您登录!您需要 登录 才可以下载或查看,没有帐号?注册  6 R% [) t8 ]  B- r8 s| 在使用allegro对走线阻抗进行仿真时,选择好网络后点击“start analysis”报如下错误, F0 m1 v* ^* o& h4 S$ S6 e" s& F “Failed to run the IDA analysis because the SPEEDEM Generator executable could not be found.Ensure that Sigrity release 2021.1,ISR5(HF5) or later is installed and the SIGRITY_EDA_DIR environment variable is set to the installation directory.The latest Sigrity software can be installed from官网 ”( J0 t& \0 c( b  I/ _: \
 重新装了cadence和sigrity。cadence版本SPB17.4.0032, sigrity2022.1版本,补丁Hotfix_SIG22.10.100_wint。* L$ d8 `8 r" _9 x/ c1 X) P- H) r$ S
 SIGRITY_EDA_DIR的环境变量值为E:Cadence\Sigrity2022.1\4 m4 B. r3 [, R4 {- N
 仍未能解决问题
 2 \( N& O! q. Z* w( }9 [$ z大家是否遇到了相同的问题
 / |" r  E6 b/ m( ]) P* _6 X
