TA的每日心情 | 开心 2022-9-1 15:16 |
签到天数: 30 天 [LV.5]常住居民I
. O- C. D1 f' U5 X$ A7 J
" T( \# ?+ o1 M/ e$ ^
5 Z7 G: D! L9 D6 A" g
9 K9 t( }& n: M 导出IPC365后,提示的错误的警告是什么意思啊?可以忽略吗?警告太多,删掉了一些。谢谢大家。
3 x# q7 i6 G I0 N. @! @8 s& z/ p# a
# `: P# y2 D( t6 L1 v5 H& s7 m+ k- K6 n2 \4 E c9 z
! ~" x) k: i6 b7 Y(---------------------------------------------------------------------)( x+ @1 p% b- V
$ f, {. E% ~. H( y7 w; I( d( IPC-D-356 )- ]* ]4 W5 L* ]+ d
( )% O9 K8 \% M# V- {# B- Z, T
( Software Version : 16.6-2015S108 )& ]1 [0 x. u' W6 e8 o
( Date/Time : Wed May 17 17:54:05 2023 )! \' R- m9 U- n8 S8 }% Y
( )2 ]$ [ \) |6 `* E# F# @9 ^
, R8 E# a$ \1 s7 u; j8 i; a7 @
2 g0 ?2 F. Q9 {, {7 b: J
L# z! m7 l F, B, o* X: Q* U% x2 LWarning: String SHAPE_REC1_4X1_9D47CIR79V1 exceeds record length on line 97 at column 0
; s1 A; T% N2 d: F; ~Warning: String P1_CN11 exceeds record length on line 30994 at column 20
% G" g3 n3 X; v5 F, N6 \0 t) m+ YWarning: String P1_CN11 exceeds record length on line 30995 at column 200 Q; q9 E; K# {0 l
Warning: String P1_CN13 exceeds record length on line 30996 at column 20, m1 x" X% _: S0 @# j4 C
Warning: String P1_CN13 exceeds record length on line 30997 at column 202 w# g, ^3 @6 s7 E( w
Warning: String P1_LED2 exceeds record length on line 30998 at column 20
# T' Q3 q& y2 C: e. ^# U, aWarning: String P1_LED1 exceeds record length on line 30999 at column 20
% R- T+ F" u: J/ }3 U4 FError: Integer value 18000 can not be written in columns 34-37 on line 31005.* M7 Q9 z! @/ x6 g/ L3 Z6 u- T
Error: Integer value 18000 can not be written in columns 59-62 on line 31005." B" }/ I0 X* c1 W6 G3 o! k# v
Error: Integer value 18000 can not be written in columns 64-67 on line 31005.
/ V: B5 Y3 m" o& W' Z9 j/ A' HError: Integer value 18000 can not be written in columns 34-37 on line 31006.( y: M) q. C3 B6 D; ]( o
Error: Integer value 18000 can not be written in columns 59-62 on line 31006.. U6 L( G6 F' H" M) Y# {7 E' C9 i, s
Error: Integer value 18000 can not be written in columns 64-67 on line 31006.
* u, G( N* G3 d7 A6 _9 {: fError: Integer value 18000 can not be written in columns 34-37 on line 31007.
% v o# g! F% E" S2 NError: Integer value 18000 can not be written in columns 59-62 on line 31007.+ i5 | A2 \/ C- ^( q8 i- R
Error: Integer value 18000 can not be written in columns 64-67 on line 31007.
7 @" J( O# c% \- J) \& ]9 jError: Integer value 18000 can not be written in columns 34-37 on line 31008.
' [0 I& H; |) }. Q/ PError: Integer value 18000 can not be written in columns 59-62 on line 31008.( T# d& }" y0 X9 y7 r ^6 _: Q
Error: Integer value 18000 can not be written in columns 64-67 on line 31008.5 H4 S1 O& t! S/ C- Q* t
Error: Integer value 18000 can not be written in columns 34-37 on line 31009.
1 w U( Y# V: q. G6 ?, q* f+ m+ XError: Integer value 18000 can not be written in columns 59-62 on line 31009.
$ M7 M. h6 r; q# d4 qError: Integer value 18000 can not be written in columns 64-67 on line 31009.
2 `1 D/ h& p- I# NError: Integer value 18000 can not be written in columns 34-37 on line 31010.( x2 v5 s& @$ r; ^ v7 o( p
Error: Integer value 18000 can not be written in columns 59-62 on line 31010.9 K( d5 C; w' N5 R# U
Error: Integer value 18000 can not be written in columns 64-67 on line 31010.
4 e6 L3 \! U) N& P- B* u) o9 lError: Integer value 18000 can not be written in columns 34-37 on line 31011.9 t8 K8 a9 u/ T
Error: Integer value 18000 can not be written in columns 59-62 on line 31011.
" V3 M1 a7 m) U& U( z: d# dError: Further integer value errors suppressed.
0 t. E6 ~+ |5 K: i0 ~7 B3 d! m% H# a$ I) F& i% L8 T- x
1 `% u- b" l ]# h l4 B ~# J------------------------------------------
M% B1 u5 X( bSUMMARY:
9 [) L. i5 b) _/ b5 Y. W Errors: 1129 z6 w- B- T2 g
Warnings: 7833
U% I1 m% V+ P5 U$ H6 X0 o7 |0 v. `: K) {) h* a& F
Info: Most likely cause of "Integer value" errors are:
& J: {- [0 k. P - (Most likely) Coordinates in the database exceed IPC's coordinate system.2 v& j; D& k, J. g/ R$ j
Try setting the database origin to center the design to reduce the large" }) f0 A$ j2 O. X H* M3 _
coordinate values.# R: Z9 g7 M8 i9 t) q
- Large pad sizes. Reduce any large pad sizes.! V8 n* Y" y! W
. I" z- _9 p! L1 b9 C& z/ A7 t1 ~
3 v# p* f' i. v' W |
